View Full Version : Honda Prelude
- I Need a huge favor!
- JDM H22 vs USDM H22 camshafts...Difference?
- tranny question (no flaming please)
- H23 Prelude and 94-97 Accord VSS the same?
- need help on rod selection..
- 5th Gen - EGR port cleaning
- OMG crazy noise/vibration at 5k ::VIDEO::
- MSD SCI Wiring
- Fabricated Heat Shield
- 5th gen jdm foglights?
- headlight issue?
- Vavletrain Upgrade
- Valve Adjustment Specs for JDM H22
- New to prelude.... have a question
- Check Engine Light on when cold
- Car Audio
- heat controls only work sometimes
- Euro R manifold
- rattling
- 2001 Honda Prelude FS- Make offer
- New owner...
- H22 Type S Intake Manifold..
- New Exhaust Fit
- a type-s conversion
- tranny
- swaybars
- fuse keeps blowing
- are your mods influenced by fads?
- shiftknob/boot
- just pondering a v6 engine possibility
- SS Tranny Problems.... myth or reality?
- 5th gen dash in a 4th gen
- how many quart oil i need to buy for my tranny?
- What big name companies make SH headers?
- what engines will fit in a lude
- squeezing sound(like a leak sound) when acceleration
- type-SH ATTS pictures
- got the tokios for the lude
- 4th gen Foglight bulb
- sidemarkers
- front radius rod Zero play bushing?
- Replacing timing belt
- cam gears on stock cams
- Which ECU is the best for the JDM H22?
- fuel filter
- powdercoated/painted si wheels on 4th gen.
- egr cleaning
- 5th gen Suspension weights
- help!!!
- 4th gen seibon cf front lip
- MY car is posseessed!!!please help
- another what if...
- Opinions please. Good price to start with?
- What if...
- Loose steering, front end grind
- so im getting an m2b4 tranny
- Solid Mounts - Where can I get some now?
- APEXi VTEC controller
- another dumb question from me: Torque
- Update on rattling/ gurgling sound on 5th gen
- Jdm motor or not?... b18cstamp...
- Knocking sound from engine bay
- pics of newly-installed RSX seats, plus some other pics of my car just for the hell of it
- CEL + 8 long flashes = TDC sensor?
- blow off valve
- Shock Knock
- After Market Gears?
- Power antenna wiring question
- 4th Gen JDM H22A coil mount
- 5th gen heated seats (search)
- cleaning engine bay and painting heat-shield
- Anyone have experience with E.S. motor mount inserts on 4th gen?
- speedomeer
- 5th gen base leaking oil!!! WHERE???? got pics!!!!! Help
- SRI in the winter months
- 4th and 5th gen Rear Caliper/rotor Question
- weird idle problem
- FW friction disc
- H22A Pilot Bearing
- anyone got a lean short shifter for sale?(san diego)
- Battery Keeps Getting Drained out!?
- 3g Prelude F22/H22 swap mounts
- will a 15 inch wheel fit a 5th gen?
- VTEC for my 94 prelude 2.3L
- what are your prelude's next 3 upgrades?
- Prelude exhaust swap
- H22 type-s camshaft dyno plot
- carsound cat question
- over heating issues, i already searched!
- People with Spoon Calipers on BB6
- Intake Manifold and Camshaft choice?
- White 1999 Prelude "Whats the official name and paint code?"
- new starter, loose bolt?
- USDM ECU on JDM motor?
- H23 Header Size?
- H4 H3 input wattage and output brigtness
- any 5th gen base models with SH energy suspension bushings?
- H23a avg life?
- widest wheel to fit a 5th gen Prelude?
- auto, stick, auto-stick
- h22 head weight
- tire size question.
- LSD from H23to F22?
- Rebuilt blown turbo car still smoking badly. any ideas!!!!!
- Thinking about getting prelude 97+
- honda dealerships fixing your car...
- Clutch issue...
- Car lost/leaked its enite oil pan capicity over night!? WHY?
- o-ringed head & block
- header studs
- Question before driving to DYNO
- 3rd gen lude weight? h22?
- cd player cage
- SH transmisison?
- Delete a/c what belt needed?
- Self Head Polishing
- which throw out bearing????
- Quick Alternator question
- Induction kit & Exhaust For Prelude 1991 Si 4WS
- totally removing A/C unit on 89 honda prelude si
- dyno time being donated for us all!
- retro fit hids
- Why not supercharge?
- what kind of turbo for H23
- JDM and USDM head...
- will 92-96 seats fit a '86?
- Would SH Tranny Mount fit on 5th gen base tranny?
- ported head question
- question about tires
- tourque specs
- Legal Hid color in Virginia
- Switch Off H22A
- Why does my thread about timing pulley dissapeared?
- Idle hesitation
- Is this possible?
- 93 lude
- budget minded suspension
- 5th gen prelude vtec injector code
- Temp Gauge Not working!!!???
- f22 -v- h22 oil pump are thay the same and can it fit the h22 and work well
- questions about alignment
- Thermal exhuast sound ?
- Best Turbo for H22?
- JDM and USDM
- Cam Cap Bolt Torque Specs???
- H22A4 swap
- headlight bulbs
- Another tensioner question:I have a H22 and also a......
- 1992 jdm prelude foglights
- 92-96 Prelude camber kit
- 2point6 making a little progress
- ECU upgrade question
- Painted SE rims?
- what to do with.....
- LSD???
- Chipped ebrake chrome button
- bearing width for Big end side of rod question
- 92-96 P12 Stock Ecu F/S
- How to pull this pulley? Pic inside
- k series trans
- power locks from 4th gen vtec to 4th gen s
- HID foglights?
- BACK SEAT REMOVAL
- auto meter shift light
- h22 in a 3rdgen
- 2nd gen help
- 4gen JDM Climate Control complete kit with plug&play harness !!!!
- tranny ???
- Tracking Prelude SH
- H22 at 12k+ rpms?
- 92 Prelude Front Lights Question !!
- !!!!!!!!! Need Greddy evo 2 sound clip !!!!!!!!!
- Anyone heard of the Pipercross Viper induction kit?
- H22A Turbo Guys..... Is there a turbo that can do this?
- where can i find H22a manuel transmission for a not expensive price?
- H22A and 92 Prelude Question
- Tranny mounts
- Rod weights
- 1998 Honda Prelude weird noise.
- DIY sidemarkers
- Looking for reviews of JRSC Prelude
- 4th gen with tan leather interior?.....request
- H22A engine idle problem.
- clutch problems
- H23 Prelude SE: Hesitation around 3000 RPMs and speedometer issue..
- Auto to Manual Tensioner Conversion
- need advice on performance upgrade....
- How are ludes with high mileage?
- Do the calipers on a 93-97 lude have 1 or 2 pistons?
- Egr value engine light question?
- Normal headlights won't come on! '91 'lude
- swap dilemma
- 5th Gen On Speed Last Night
- vtec controller
- all Gears pop out easily, tranny issue!
- will a 2000 block work with a 93 h22 head?
- Which Fuel pressure regulator for h22a?
- 5th Gen Gauges Question
- Whats wrong???
- Need Help? Need questions to be answered (New to a Prelude)
- A Logical Plan for Modifying Your NA H22a
- Prelude Forum
- Suggestions? after short ram, headers, exhaust, coil overs? 4th gen 2.2 vt
- 97 5th gen drain bolt leaking help!!!!!
- righthand-drive prelude to lefthand-drive
- i want to know what is the cause of my transmission leaking
- problems with ATTS
- will USDM ITR rims fit on 97+ preludes?
- Total confusion!! Need help, ign prob maybe?
- keeping it simple and street
- Serious Problem
- Any ideas of what Kit shall i put on my 98 prelude
- Okay here we go again
- Thumping when touching sparkplug wires?
- JDM prelude Type S airbox: Ups and downs?
- intake installation
- Keyless entry question.
- How to hardwire into the fuse box
- 4th Gen Roof Spoiler
- 4g Prelude Axle, Ball Joint and Misc Suspension Work
- Prelude Shift Linkage All the Same Size?
- compression and horsepower
- Energy Suspension HYPER-FLEX SYSTEM Complete Master Bushing Set
- Light/Electrical Problem
- are these any good?
- car pulls to the right
- want to see a tear down of an h23?
- Best kind of lowering springs?
- anodized/poweder coated calipers
- i need help choosing springs rates for my 5th gen
- how much should i offer
- M2A4 Tranny with LSD
- ACT clutch problem?
- H22a1 help
- anyone got a detailed write-up(searched could not find)
- Cold Engine Idle Problems!?!?
- CB radio lude?
- Wanna earn some points/privilege back?
- What ATTS code did you get when you had too much whp? (Oil pressure sensor?)
- 92 prelude Si rear seats/ center storage
- tranny and clutch
- Type S Camshafts Into Black Top BB6
- painting heatshiled Help???? decided to keep it!!
- Headlight color and brightness: H4 lowbeam, H3 foglight
- gauge needles
- manifold choice
- tires constantly go flat after a couple of days
- First things to do
- 89 prelude $200
