View Full Version : Honda Prelude
- cam seals
- fog light switch question
- more "testing waters"
- 93 Prelude Vtec before/after time slips
- Coolant in the passenger compartment
- interested in buying a 94 prelude with a 97 JDM h22 motor swap
- Anyone paint their gen 4 jdm headlights?
- Shocks......... Opinions
- Can anyone estimate how much it will cost to fix my lude?
- Pic Request: 97-01 Prelude Mugen Spoiler
- APEXi World Sport Exhaust
- ebay coilovers, too good to be true?
- My H22 Build
- How does/doesn't this work? (Thomas Racing Chip)
- heat gauage question
- Clutch Issues
- Built motor won't start, please help.
- Clutch Problems (already replaced master cylinder)
- where to find new motor
- new clutch
- JDM Gathers stereo?
- Creaking noise when applying brakes
- AEM EMS New, Never installed
- Head gasket type s...
- torque steer
- H23 VTEC?
- ARP stuff confusion- please help
- cooling system question
- 5th Gen Prelude Spoiler/Wing?
- h23 to h22 checklist
- 92-96 fog light ghetto switch
- spark plugs??
- Quick Quesetion - very quick....little black box....
- SH vs. Base model question
- Clutch acting up...
- Honda certified Q??
- 1990 prelude spoiler led removal?
- Replacing Rear Wheel Stud on 4th Gen
- 89si mods
- Help me diagnose problem VIDEO this time!
- TuRBo or Supercharge?
- v-tec and non v-tec exhausts
- brake lines to master cylinder
- a/c control panel and defrost
- How Much Tranny Fuild Do I Need?
- smelling alot of exhaust!! Help!
- Just Installed motor: Tranny won't shift into reverse, PLEASE HELP ASAP!
- 01 lude SH ignition and timing maps
- 92 4ws
- what kind of part i this? (pic inside)
- mixing coolants cause burnt smell?
- OBD2-OBD1 conversion
- Msd Blaster SS coil question/tach adapter
- intermittant no start,89 prelude si
- 97+ RevHard Intake Filter Ideas?
- GREDDY/HONDATA/APEXi VAFC
- does 225-45-17 fit on da 4th gen prelude
- Jackson Racing Supercharger Belt
- Complete valve job or just the one(s) that leak.
- Unorthodox Racing: Tuner series vs. Ultra S series
- 4th gen exhaust on 5th gen?
- jdm h22 timing/distributor instal help...
- cooling fan
- knock sensor problem
- VTec Problem & VTec warm-up period... HELP
- Shock Settings???
- a.c control panel
- KYB AGX & GC
- jacks.. straight racing ludes.. weight loss,
- Engine wont start if warm
- h-beams or i-beams rods?
- Exhaust silencer affecting a/f ratios and cpu settings??
- RSX-S Gauge Cluster in a BB6?!
- How much for a swap
- Map Sensor CEL Please Help
- loss of power please help!!!!
- a/c compressor question
- Type-S Compression ratio?
- 92 prelude- 97 h22 type s swap?
- Bumper Cover?
- Anyone have experience with D2 Coilovers
- Are all CF hoods created equal? Your experience with ebay hoods
- Tires size for 16X7 wheels
- Flywheel/clutch worth it?
- trAnsmission problem.... please help
- Quick Q: Do I need the MSD Tach Adapter with my MSD SCI and Coil?
- Kinda poll- what kind, size of turbo do you use in your preludes?
- idleing problem
- *new prelude owner* need help with 3rd gen suspension
- Mobil 1 Extended Performance
- short ram or cold air intake on 4th gen prelude si
- side markers......
- At cold idle, revs climb up and down until warmed up
- tranny code f22b
- '01 Prelude Mis-fire
- what oil should i use?
- JDM half-mast antenna and switch wiring
- Crower stage 2 cams breaking
- h22a and h22a4 arp head studs different?
- Clutch line thickness
- Lucas oil stabilizer
- pictures of an oem h23a1 block and pistons
- please help b4 i make a mistake
- how do i take off the intake manifold?
- Paint
- Prelude cams
- question on ecu swap
- Where to put my motor...
- Fuel Pumps a1 vs. a4
- Recharging 94 prelude ac compressor.....beat the heat.
- h22 auto to manual tensioner, need instruction...
- Where's the videos???????
- h22 killer
- will this size wheels and offset work on 4th gen?
- hissing sound coming from teh front
- HeLP... SUSPENSION
- automatic button mystery
- Broken Knock Sensor
- Idle problem
- Clutch or tranmisson Problem?
- 16" vs 17" Wheel/Tire Size Question
- Seibon Lude?
- Can I use the regular Koni Yellows for an SH that has H&R springs?
- Can someone give me the run down of a 5thgen prelude running down a striaght line with a GSR?
- JR Supercharger and Turbo Combo
- What websites can I go to and find a driverside window for my 98' prelude.
- Oil pressure switch pinout(simple)
- LUK clutch
- Radio Antenna
- Removing emblems...
- Totalled my Lude...
- M6HA tranny, what year of prelude?
- Prelude high pressure fuel line problem
- Oaks Racing Prelude Burn out - Can someone host?
- Buy for the car or for the engine that's the question?
- new fuel filter..?
- qestion about turbo kit!
- turbo kit?
- hood latch
- does 5th gen intake fit on 4th gen?
- 95 h23 prelude si Cylinder Head
- Need Help From a pro
- Temperature Gauge is Acting funny..
- Lean Racing Short Throw?
- Which one folks?:...Fuzion, Sumitomo, Kumho, or Nitto...New Tires...
- Rocker arm wear
- always getting power?
- m2f4 tranny..
- m2f4 tranny...
- Springs drop
- Who here has replaced slave cylinder?
- I need some help
- dc headers question
- NEED HELP ASAP
- help with code 9 and code 22
- Thinking about buying a prelude
- how do you move from middle perch to bottom perch on koni yellow
- Prelude inner joint
- Lacking power???
- Play in shift fork...Throw out bearing?
- Just installed motor, bad oil leak, please help.
- prelude drag racing springs?
- Steering Wheel???
- Please help with my turbo setup!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Euro R intake manifold
- Please point me in the direction of a c/v joint write up.
- JDM parts, thermostat and transmission seal
- how much to turbo a stock h23
- My Old Block (H23 VTEC) - Tear Down...
- FOR SALE 92 SI lude performance mods
- Downside to going with the lsd on h22 swap?
- prelude roof spoiler
- MOMO floor mats
- 92-96 lude short shifter adapter???
- quick question h22a1 or h22a4?
- front bumper/fender removal
- boggin in all gears
- 89 prelude a/c type????
- finally got the motor running decent and head gasket fixed
- h23 manuel tensioner conversion?
- Dyno: ITB vs I/TB/IM setup
- which replacement rad. cap to buy
- anybody no a thing or two bout tranny's? HeLP!!
- Looking for information on specs for h22 vs h23-vtec
- '98 'Lude Alternator
- hondata
- CEL and Running Problem Help-!????
- Right headlight bulb keeps blowing...now having issues with HID's
- 6 Puck Clutch Question
- DC Sports Header fit stock H22A4 collector?
- Just got my fully built h22a1 out the dyno, bad #s
- how often to do these...
- a/c help
- Question on TSB information
- :sigh
- Temperature sensor?
- funny noise
- Length of Euro R Intake Manifold
- Going from a auto to a manual
- 4th and 5th gen billet replacement mounts, for those who are interested...
- 99 vtec issue
- Sold Tranny - Buyer Claims Problems with It! Help!
- H22 head on h23 block
- Cigarette lighter fuse?
- try make alittle power on a f20a sohc engine
- F22B Distributor (picture link)
- Intake Mani sucking oil through the PCV?
- Bleeding clutch
- Does this sound like a bad voltage regulator??
- Prelude Lights
- Let's say I wanted HID headlights...
- Can I put omni on my SH ?
- Suspension Help
- 5th gear's a little rough...
- will f22 sohc dizzy work on h22a ?
- I need a new cb exhaust!!!
- Tein Flex vs Tanabe Sustec SS reviews wanted
- Will 17X7.5 Velox VX Novas fit on my 5th gen?
- Very Stupid Question-
- Turboed H23 Help
- what manifold are you running?
- how to wire and make a h23a external type distrubutor on to a 1990 accord with a jdm h22a?
- humming noise somewhere from intake?
- I need parts for a right side drive 1995 honda prelude
- Problem! I need to fix asap! Please Help!
- MSD coil blaster 3 coil
- Easy Question.....Need definate Answer!!!
- MSD coil install
- electrical gremlins or vacuum line woes?
- there is a short somewhere my car keeps cutting off can somebody help?
- taking valve cover off
- Vtec
- Majestic Honda part number for Prelude VTEC thermostat
- Exhaust questions...HELP!
- 90-91 Zenon Kit with brake ducts
- different brands
- Weird Problem
- Question about wheels?
- using auto wire harness in a manual car.
- How to tell the differences in h22 heads?
- looking to buy a lude
- Weird redline.
- ECU questions. Pease help!
- Video of my 13.52 Run @ Sacramento Raceway
- need help solving shifting problems (searched a ton already)
- Some Problems
- Harm to h22a engine without O2 sensor?
- 97 Prelude Cams??
- Will 97-01 side mirrors fit 92-96?
