View Full Version : Honda Prelude
- NEED HELP......ASAP PLEASE
- intake manifold or exhaust?
- Making the H23 VTEC
- Anyone know how i can
- I need some IAB/butterfly help/advice...
- timing advance
- Short Geared Prelude
- Which Clutch?
- Air Filter Question
- Difficulty of Oil Pan installation? 4th gen
- best turbo for H22a motor?
- What does the Si designation stand for
- Measurements: Type-S Piston
- Need parts. Or where to find parts. Header questions. Any other SC prelude owners in SC
- Koni sport struts and H&R springs or Tein Basic Coilovers
- 89MM H22A vs 89MM H22A4
- What do I HAVE???
- Neuspeed sport springs
- distributor help
- So I spent $800 and they fucked my car up...
- Can you tow a prelude with the engine brace removed?
- crank pulley
- Speed Limiters? Who has them and who doesn't
- engine keeps turning over, no CEL?
- Engine Dress Up
- anti photo license plate covers
- Projector Headlights
- help help!!!!! engine code 67
- Nitrous in a 99, basically stock.
- none sleeving piston???
- Test drove a '00 Prelude tonight...couple questions
- h22a4 swap
- 4th gen Manual Parts for 5th Gen?
- Need help Identifing Cams
- Sway bars...
- F20B rev limiter
- H22A distributor cap?? HELP!
- gm 3 bar map???
- obd1 ecu for h22a type s
- Need help please
- LS 5th in a lude tranny??
- G2 Interior Styling Paint
- idling low after warm
- Need 5th gen pic with Eyebrows
- help, my car is gonna blow!!
- H22 Rebuild
- 95 Prelude Electrical Problem
- h22a1
- How to add transmission oil to a 94 prelude si?
- help! leaking fluid?...dont know what it is
- Weird rumbling sound? please help!
- NGK plugs for sh.
- Should I retire the Accord...
- SC prelude back from the dyno
- prelude lip
- late 80s Prelude w/ B20...Will the valve cover fit a 1998 B20B?
- need some help with 5th gen ecu codes
- Legend calipers on a 4th gen
- prelude rpm jump
- Code One and Code 43
- New Setup Questions
- Balancer shaft oil seal !!!!!!!!!!
- Type S to build H22?
- tein differences
- Brake system upgrade.!?
- Glass Packs!! ???
- Turbo folks (CA especially), what do you do when your smog check is due?
- questions, problems, hassles.....help plz
- my engine is spiting oil... pls help
- transmission is all messed up
- lug patter on 88 prelude?
- engine wont start...
- Ebay: Cheap effective part of the day #1!
- Pulling Check Engine Code, 4th Gen
- Replacing 5th gen brake pads
- prelude not low enuff!?! help
- Which coilovers will dump the shlt out of my GF's newer gen lude?
- where can i buy an m2b4, now????
- h23 intake manifold gasket
- Which aftermarket Muffler?
- So what exactly is.......
- F/S H23a head and LSD for 97 and new lude
- I need new syncro's for my trans
- motor mounts + high hp h22's
- what kind of work can be done on an H22 for 7k?
- retrofitting SH tranny to work in base car
- Need paint in Wisconsin (midwest - tristate area)
- Running very rich when i give half trottle or more and in vtech i am a dully
- Compression Test and Oil Consumption Question?
- Rare-ety of SH rims?
- Question on basic rear lower sway bar installation...
- 5th gens with HIDs: i got a question for you
- Sea foam sucks!!
- wiring problems with a 3rd gen prelude
- custom fuel feed hose
- HELP!!!! URGENT
- Parts?
- 4th gen console conversion possible?
- hotter plug on H23???
- Engine not starting..
- Check Engine Light ??? ATTS LIGHT ???
- gauges
- how close are the H22 and the S2000s F22
- Resonator questions
- New H22 swap....some cel's.....
- Ecu pinout for a 94 si prelude ?!?!?!?!?
- BB6 5th gen JDM H22A Swappers: What ECU are you running?
- Bought an auto tensioner today. 94usd! Yikes.
- witch one?
- JDM courtesy light
- Euro-R Engine mods
- Precision SC 50 Turbo... need info quick
- Purge control solenoid affects idle and gas mileage?
- Pasenger side door mirror and housing for a 97+
- Broken Radiator cap...inside
- 92 Prelude needs engine.
- abody use these cam gears?
- Antenna
- Broken LSD..?? H22
- f22 to h22 question?
- Portflow reatiner installed height??
- How much power can the stock h22 valves/retainers take?
- euro-r manifold install
- block ruined during sleeve install? please help.
- what is wrong?!?!
- Are F22 Motors any good?
- 1990 LUDE 4WS B21 Motor
- Skunk2 Intake Manifold V.S. Skunk2 PRO SERIES Intake Manifold
- KMS springs and retainers with crower stage 2 cams?
- hondata
- SIDE DOOR PANEL
- Anyone have an AutoPower Roll Cage?
- starting problems
- Cam Gears
- All motor, Safe for Nitrous??
- Head Swap please help
- Buying a 4th Gen Prelude
- H23 Build
- B20A3(Carbureted), Swap to Fuel Injection?????
- Any adverse effects of...
- f22a1 or f22a4 cam, intake, and exhaust manifold?
- Bump Stops in 5th gen
- dumb question.. i know
- broken into hood latch question
- Will 4WS work with p28?
- Just a few questions im curious about for 5th gens
- Distributer Cap
- take out amber in tail lights
- taking out A/C...5th gen
- Idle
- Not sure what to do/what do I need for this compression?
- OK, finally got my tranny out...jus a couple of Q's
- License Plate relocator
- Wiring Diagram for 4th gen ( H23A -motor with A/C and 4ws)
- HIDs
- Black housing 4th gen headlights, DIM....not as bright as USDM headlights.
- code 9???
- Getting a 92 si lude on Friday!! Got a question...
- p28 in a prelude??
- Car radio rear speakers wont work... wiring?
- Backpressure ???
- B20a5 head swap
- Carbureted Idle Problem...Surging....Dying...
- check engine light come on after driving a while 5th gen prelude
- !!!!someone stole my VTEC HELP ME FIND IT!!!!!
- 4ws steer preludes... lots of codes are thrown, does moving the computer mess it up?
- HIDs in a 4thgen?
- Motor Mount
- 94 Vtech pin layout ! HELP ASAP,
- What type of solder do you use on your preludes electronics
- Piston to valve clearance?
- 2000 Prelude ecu location?
- AT Tranny fluid question for 5th gen
- shiftknob
- 5th Gen Prelude Auto to Manual swap
- Intake Tube Thermal wrap/paint?
- AIR diffuser for 4thgen preludes???
- rear ball joints...wtf?
- wich turbo to go with?
- Throwing CEL Code 7, NEED HELP BAD!!!
- 98 honda prelude starting problem
- Muffler tip Question
- Looking for rpm wire?
- RMF header, what about exhaust
- I bought this car...
- RMF = Randy Monroe's Finest... so what if it is on an Accord?
- Mugen accord lip
- H22 Vaccum problem? 4th Gen
- JDM climate controll install in 5 gen lude :)
- 2nd gear grind
- what happing if u run an automatic p28 ecu manual h22?
- type s cams
- anyone have picture of where the idle screw it at on the h22 motor?
- Engine Builders?
- what size tires can i fit on stcok rims
- WS2 vs Thermal
- 4th gen gas/temp gauge problem
- a/c control backlight
- Tranny WONT go into reverse....help help!
- JDM Fog light switch
- Will ground control coilovers from a 1990 integra work on a 4th gen??
- Pennzoil Synchromesh.. where to get it??
- gauges
- bought some h22 type-s cams
- which cams to get
- 97 lude thermostat
- Trunk Rattle
- 94 prelude stalling in cold weather
- PICS of my stage 2 ported head install. 56k grim reaper
- Probably Stupid Questions
- H22A4 Head on H22A1 Block
- Did the bearing failure test
- Climate Control
- Blown oil seal (?) 93 Prelude S series....Help
- 97' Suspension Question
- KYB AGX Shocks - - Will they fit a Type SH or not?
- Clusters
- MSD ignition
- whats beter internal or external coil? h23
- Damn Tranny Grinds H22A
- Wheel Weight, Does it matter that much?
- hondata nitrous controls?
- JDM Headlight H1 bulb question
- reverse indiglo gauges
- Dual or Double wishbone?
- Type S Prelude
- Am I driving the wrong car??
- Prelude that won't start sometimes.... $#)@(*&%)@
- Fidanza short shift adapter
- Check valves???
- prelude gauges
- know nothin about 'ludes
- sh and not sh exhaust
- Considering H22 swap into 4th gen.
- Megan Racing Strut Bars on a 93 lude
- Is anyone running stock valve springs w/performance camshaft?
- Exhausts: SMSP vs. MUGEN
- OEM floor mats...
- Exhaust for a VTEC prelude
- Around radio code.
- bumpy ride in the morning
- Crank Pulley
- new motor from honda
- Just got a 01 SE!
- Need 5-speed P13 or P72 Ecu....anyone?
- motor cuttin off....
- 4g Swaybars
- 4th gen rear strut removal
- 2 clutch engagements? wth?
- FARK!!!!!! ALOT of help needed.
