View Full Version : Honda Prelude
- Ever had a clutch problem like this?
- 98 prelude runnin lean
- Picture request - Intake Manifold
- Where to get Tranny side mount???
- suspension advice
- Need Prelude Help
- Throttle Body?
- Help! Idle Problems!
- I'm looking for alternatives...
- Getting my motor redone need some suggestions
- he says its a sr prelude but i dont no ???
- will a 95 or 96 prelude si tranny work on a 98+ prelude?
- Quck question or help with turn signals
- Going turbo
- How would a p72 work?
- installing head (need help)
- Exhuast and Dyno's
- Taking of the center console of an Auto... (4gen)
- Dyno 2000 Engine Simulation
- VTEC won't engage?
- gen 4 tyres, what is the max width that could fit?
- have i got this right?
- valve adj. nut 12mm?
- H22 SWAP DECIDED
- best 1000 dollars to spend on a stock 92 SI
- Do I need this clutch damper? (pix)
- My turbo prelude
- good news about camber kit for 5th gens
- problem with taillights
- 2001 Prelude seats
- 92-96 Prelude Tail lights
- geez, so sorry
- 5th Gen Springs on 4th Gen?
- check light question?
- Calgary, Alberta- Tunnig Shops
- ? about greedy turbo kit
- fuel injector question
- How much gas mileages you guys get on your Ludes all models.
- Max amount that an H22A4 can be decked?
- Checking engine light after long time....posible?
- o2 sensor
- Damn inconsiderate theives!
- engine codes
- Question about valve cover????
- Quiet Exhaust
- Current State of my lude!
- Tire Sizing
- Prelude will not rev past 6500 rmp......... Advice needed!
- Someone broke into my car
- h22 head bolt torque specs
- ACT streetlite for H22?
- VTEC -> Legend caliper worth it?
- H22a timing
- neuspeed race springs read please if you had/have
- AXLE/ ALIgnment question.....
- sh tranny change out the driver side axle mid shaft connector
- Tranny Options
- Hard to find lude parts?
- Need help fast... Dizzy problems
- Exedy Cerametalic 3-puck
- 10-94 headers
- Repairing Jason Kidd's JDM P13 from DOA status, no 56K 800x600
- 3rd Gear Grind. Fix now or later?
- MSD 6AL (parts need)
- Question on changing headlight on 98 Prelude???
- High-Flow cat & OBD2
- HELP! Axle leaking and bar broken
- flip down visor
- H22 ENGINE SWAP QUESTIONS
- Gauge Color Change
- h22a pros and cons
- 2K lude motor into 94..do i need adapter mounts?
- Will a Fields Vtec harness work with a VAFC ver2 ?
- Tein High.Tech Springs
- 4th Gen Magazine Articles
- Valve cover gasket
- Where can I find...
- car is hard to start in the cold
- Shops in San Diego, CA that do engine swaps....
- SO SO SO SORRY FOR BRINGING UP SKUNK2 IM AGAIN!!!!!
- need a f 22
- Direct Port in a h22
- Recomendations of Radiators? OEM = $$$!!!!
- Torque Specs?
- has anyone heard of ..
- Help on Prelude oil leak recall???
- Newer tranny with older engine?
- Driveshaft securing nut on hub assembly...
- can i use prelude vtec rotors on 1992 si prelude braking systems?
- h22 w/ h23 tranny...
- H22/H23 Distributers
- water temp and volt gauge install
- oil catch can hookup how to
- Prelude in snow video plz?
- euro r manifold install question
- heat not workin well ?
- Good Header and Air Filter for 2000 Honda Prelude SH
- anyone running 235 or wider tires on a 5th gen?
- butterfly plate
- where is a/c condenser??
- ENGINE SWAP questions.. need help!
- aem cai weight with filter?
- HELP ASAP!!! FUEL PRESSURE GAUGE PEGGED PASSED 100
- H23 CAMS
- PRELUDE SR WHATS IT GOT?
- which tire size to get...
- Would a 97 lude head unit work in my 94 civic
- Car hard to start when gas is low
- For Those Running with Skunk2 Stage II Camshafts
- wheel well cover
- What to do for quick/cheap speed for a H23A???
- JDM h22 vs american
- Prelude ECU computer questions
- anyone have an el cluster laying around?
- burning oil smell
- balancer belt
- Need help wit trans problem !!!
- No Heat In 89 Prelude Si?
- those with 18" on 5th gen........
- how many teeth on the h23 water pump? (searched)
- JDM H22A + Nitrous....
- Motor Question?
- 1500 idle? (searched)
- 3rd gen ludes represent
- Spoon magnetic plugs?
- H23a Cam gears
- Destroyed motor, what you all think...
- Anyone heard of a JDM H23\VTEC Motor Stock?
- prelude type s pistons
- are all 92-96 prelude brake rotors are the same ?
- AWD Lude?
- for those 5gen luders w/ 18"s.....
- replacing alernator...?
- bearings ( main, rod)
- What should i do with my prelude
- JDM H22 Question
- clutch hose
- does the 1996 lude' come stock with a H23?
- Best ways for free or cheap performance
- what is the stock hp and motors 4 a 92-96 lude
- Going to look at a prelude tomorrow.
- h23a q's
- Preldu Wheels
- Eibach camber kit
- how much are h22 just the block, worth?
- What is the best brake fluid?
- Map Sensor wires on throttle body for 2000 Base 5sp prelude
- WHO BESIDES DC, PACESETTER,GREDDY
- 6 puck sprung clutch...
- Common Problems with Gen 5s
- Overrevved
- What is this part? (pic)
- Looking for a bolt-up Carsound Cat for h22
- HAS ANY ONE BUILT H22A SUPERCHARGED MOTOR? #HP?
- is this a legit jdm prelude VIN number?
- ES Motor Mount Inserts review
- hybrid
- Ignition install help!!!
- Whats the jdm lsd tranny code for a 4th gen? What about the 5th gen?
- Exhuast issue
- HOw to remove butterflies from an h22a1
- AEM pullies
- quick tech question about sleeved h22a1 blocks
- Engine rebuild gasket set
- headlight repair help
- Boosted B21A
- H22 with nitrous?
- Whats wrong if your clutch is Slipping?What stage clutch do you recommend?
- h23 or h22 head for turbo?
- h22 dyno #'s 198hp 148 tq
- WTF This Is Gay... Headlight Question...
- lsd?
- what is the torque specs on tighten the crank pulley bolt for 1995 vtec lude ?
- reset your ecu..?
- Alternator!!
- exhaust manifold gasket question
- timing issues after putting on gude head package
- Idle issues, please help!
- Lowering the Lude & Changing Struts
- radiator
- H22A tranny oil
- raising compression on h22
- What are the absolute best shocks out on the market right now?
- some frame damge
- 93 SR/SI starting problems, HELP!
- Recolaborate my gauge cluster
- Automatic LSD Tranny
- HELP: f22b to h23a conversion
- Calling all users with lowered cars or catbacks with pictures of them!
- intake mani studs
- Heat air and AC air is Dead. Help Please.
- car wont start i believe the immobilizer is at work
- Any Honda racing facilities in the USA?? If so, where??
- GM Syncromesh question
- Someone check this for me
- Low Cost Suspension Setup?
- I REALY NEED YOUR HELP!!!
- hating on the LudeS!@!
- is it possible to do a ecu swap between two 97-98 prelude and have it still run?
- H22a Turbo and H23a Turbo, Which is faster? at the Same PSI?
- I need HELP! Oil Jet Control Questions???
- Bypass Valve
- light weight ur pully removal?
- Pipping ? on exhaust
- alignment question
- Whats up with S2K pistons in a h22? anyone done it?
- Best All Motor Setup
- H22A4 distributor wiring... wires don't match diagram
- help me quick
- Anything specific to look for when buying a 1989 Prelude? Problems?
- Does anyone have tein basic coilovers for their 97-01 preludE?
- did my h22 about 5- motnhs ago and havent had the speedo/odometer working.
- abs locked, light comes on
- HOW DO I WIRE IN V-TEC????
- rod bearing replacement (H22)
- RS Machine Billet camshafts are now available
- ABS lights On? What is the problem?
- WTB: JUN pistons and rods
- H23 5spd Tranny Pkg.
- crank differences
- H22a Full Rebuild
- is there a difference between h23a throttle body and h22a throttle body?
- V-AFC II on an H23
- VAFC controller
- 2000 prelude SS to run 14s all motor
- replace 2nd gear?
- Ground control springs. front/rear?
- What size are my stock injectors?
- can a 94-97 SiR accord ecu be used on jdm H22
- H22A Piston Reviews
- question about ported IM and larger TB
- Question about the Tanabe Sustec...
- How do u take off Crank Pulley???
- ideling problems with the lude
- JDM Digital Climate Control in 5th Gen?
- quick h22 cylinder head Q?
- 93 prelude rear side window?
- hmmmn
- CKEVanity Plate Ideas
- questions about mount for a tranny swap~
- Keychain doorlock and alarm setup
- Not something you see every day...
- quick piston ring Q
- who sells accord euro r or ATR trannys?
- h22 kamikaze header?
- Major Tuneup List (look good?)
- where to buy the mugen aero kit for 4th gen ?
- Stock airbox features?
- is there a difference between at motor mounts and mt motor mounts?
- my car keeps over heating at night and long idle?
