PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 [173] 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Thickness of the STock H22-Closed-Deck-Sleeves
  2. semi-overheating? rad. cap?
  3. Intake Manifold
  4. anyone know how much boost can an 01 type sh hold?
  5. Diamond White Pearl?
  6. Brak
  7. just swap in a f22 in a lude and now has mad clutch slippage?
  8. Adding oil without draining.
  9. Type-S Front Cut
  10. Head studs? ARP 208-4304
  11. base exhaust fitting on an SH
  12. Wiseco's????
  13. Is tuning your car smog legal?????
  14. SH Header problem
  15. 5 speed prelude SI using Auto trans engine Harness.
  16. Clutch Break in.....
  17. cam timing tdc question
  18. Timing belt help
  19. Part # for Prelude Sir Type-S camshaft?
  20. h22a+BOOST
  21. 5th Gen Suspension Questions, Spring Rate and Ride Height, Ect...(searched)
  22. anyone had trouble installing a phantom grip??
  23. stuttering: from no back pressure / broken exhuast?
  24. stutering problem
  25. idle problem
  26. Need help 93 Honda Prelude with H22a1 motor
  27. What are 1993 prelude spindles made out of?
  28. Need advice about a Prelude
  29. help with bleeder valve
  30. Rear drive Prelude..is it possible?
  31. Missing cam caps
  32. wheel alignment
  33. Swapped H22- CEL
  34. 1999 Prelude SH
  35. What are real HID's
  36. Golden Eagle 440 cam gears
  37. Prelude Type S Strut Bar
  38. F22 swapped to a H22 prelude problem can anyone help?
  39. Sterring wheel removal...4ws lights on
  40. which is which?
  41. speaker wires on 97 lude???
  42. 95 Prelude JDM fog light help
  43. Megan header collector size - JDM h22
  44. converting 4 lug to 5 lug on a 4th gen lude
  45. T1R exhaust system
  46. 4 sale euro R manifold
  47. good coilovers/lowering springs?
  48. Rod and Main Bearings-Were to buy?
  49. Pistons-Were To Get?
  50. Passenger Side Inner CV joint separated on suspension swap, plz help
  51. About to buy a bb6?
  52. Skunk2 Stage 2 cams in, Now What?
  53. fuses...
  54. New Koni Yellow with Neuspeed Springs not riding right. Any Opinions?
  55. skunk2/euro-r/stock dyno?
  56. who would win between a stock 01 prelude sh vs a stock 02 civic si hatch?
  57. Alternator dead
  58. jdm h22a balance shaft
  59. How do you remove the rear seats?
  60. Nopi St.Louis - Any Prelude owners going? Oaks Racing
  61. HELP! How do you remove the steering wheel from a 5th gen prelude?
  62. Prelude, Accord hubs?
  63. boosted H22A
  64. h22a swap .. several questions (pics)
  65. h22 crank journals....are jdm and usdm 92-97 really the same?
  66. msd coil and h22 internal coil question!
  67. msd coil and h22 internal coil question!
  68. clutch for turbo prelude
  69. Help me out.. AC parts
  70. Rebuild or not to rebuild? That is the question.
  71. First time flushing, did i do it right?
  72. a/c recharge?
  73. Definable Knock Control
  74. do h22's have this?
  75. Engine noise Low rpm H22a
  76. where is the thermostat located
  77. prelude seats!
  78. Question about the 4th Gen CD Changer
  79. Question about scanning!??
  80. Things to look for when buying a 5th Gen?
  81. **FS: 01' hondA preLude w/ gooDies!!!!!
  82. Anyone has phone # of SSAUTOCHROME
  83. Cheap coil overs and springs
  84. HKS Dragger exhaust or Apexi N1 exhaust?
  85. Catalytic converter bolt / stud pitch, thread, size?
  86. 1997 lude Q's about auto to manual help ?
  87. 4th gen vtec; 3rd gear lags
  88. vafc 2 users...
  89. Is it possible to buy Prelude'97 in good condition for 5.5k (NY)?
  90. bleeding gone wrong
  91. will a jdm m2b4 fit on a 1997 prelude chassis?
  92. TRouble finding 89 prelude compressor control unit, please help
  93. Two cruise ports on the tranny?
  94. where can i find....
  95. wondering if i have a clutch or tranny problem
  96. is aftermarket flywheel worth it?
  97. Help finding a/c control unit on 89 prelude
  98. Im a trader. Had a few b series now going big block h22 baby!?????????????
  99. Skunk2 Valve train questions
  100. 4WS Crappin Out
  101. h23 pistons in a h22?? h22 rebuild
  102. Stock Header + 2.5" Collector + 2.5" all the way out. Good for a stock H22?
  103. wheel alignment
  104. wondering if i have a clutch or tranny problem??
  105. how many of you have welded your diff?
  106. clutch master or ACT
  107. F22A - H22a conversion - Crank Pulley? ECU?
  108. H22 Clutch Choice Advice!!
  109. JDM
  110. Engine Mounts
  111. exhuast interchangable after h22 swap??
  112. removing center console on automatics...
  113. Newbie prelude owner w/ a Newbie list of questions...
  114. 5th gen rear sway ber removal question
  115. 3rd Gen Integra stock rims fit 4th gen prelude?
  116. slim fan help
  117. How much for a typical h22 engine buildup (rods, pistons, sleeves)??
  118. Are 92-93 7 spokes heavier than 94-96 sawblades?
  119. All motor Golden Eagle sleeved 5th gen startup problems
  120. Proper radiator fan operation, 94 H22A1 Prelude
  121. wrong part # for h23 tensioner??
  122. Getting Tuned Next Sat.. i have some Questions
  123. how do you know if your thermostat is going out?
  124. Reverse Speed problem on 4th Gen 94 JDM BB4 (H22A)
  125. vaccum brake booster
  126. 2001 Euro R in a 92 Prelude not Starting. I know the problem, what to do about it?
  127. 92 prelude engine cut-out
  128. Just bought a 98 Prelude (and timing belt ?)
  129. 4th Gen: Draw-tite Trailer hitch installation question
  130. clicking noise when braking... help
  131. 1995 Prelude VTEC how much?
  132. 35 Nitrous Shot W/Auto Trans
  133. ground control coilovers vs. tein s-tech
  134. 92 Armrest/Glove box question
  135. NX Kit Installed, Up and Running Pics 56k die
  136. Purchasing an 89 Prelude, Need a bit of help
  137. tring to increase speed and hp
  138. Vtec killer cams on a 01' euro-R h22 engine.
  139. wtb Azect rear bumper skirts 4th gen
  140. b20a
  141. Waterpump + Thermostat Replacement
  142. Anyone know the specs of the H22a valves?
  143. Jackson racing supercharger with stock intake??
  144. Where online can i purchase 95 oem prelude springs?
  145. where are ALL the VIN's for a 4th gen?
  146. Need Help concerning 93 prelude si
  147. H22a/a1/a4 rods different???
  148. h22 front motor mount, how vital? 4th gen
  149. '87 prelude questions
  150. plug wires
  151. thinkin about buying a 5th gen lude....
  152. calling out ALL motor h23
  153. needing Ideas for exhaust
  154. H22A1 Pricing...
  155. NO VTEC....?..help
  156. Anyone know where I can order a high flow direct fit cat for a Prelude SH?
  157. Code 1 or 10?
  158. Friend Needs Tuning
  159. Two questions about the OEM kit...
  160. S2K Start Button
  161. Is the OEM bodykit only for the front and rear?
  162. tranny problems
  163. QUESTION about final drive gear prelude SH
  164. Switching GC springs front to rear
  165. Quick question..
  166. my lude
  167. 98 auto to manual swap
  168. What EMS to use to keep ATTS?
  169. idle ??
  170. ECU for a Prelude BB1 H22A Engine (190hp) with Auto Transission!?!
  171. Antena anyone?
  172. 4th and 5th gen rear mounts
  173. Question about Koni yellows for front of a 92 prelude (brake line)
  174. Rods, Mains, And Crank, Measures Wierd-,
  175. 96 Prelude VTEC Stock Skidpad?
  176. 92 prelude running lean
  177. noises when turning
  178. F22 to H22 wiring question.Please help
  179. Compression
  180. f20b swap
  181. Where can I get a Jdm Thermostat?/ the right one to fit.
  182. sleeving f20b
  183. cams and pistons in a f20b
  184. jdm H22A in a Civic EK .. ***THROWING lots of ECU trouble codes***
  185. H.P
  186. 182hp 152tq details inside !!!
  187. black smoke
  188. Where can I get an H1 harness?
  189. N2Oed Luders. Post your setup/times.
  190. Walbro fuel pump ??
  191. blown h22.......
  192. I need help!! my lights turn on by them selves!!
  193. MSD Ignition Controller and turbonetics fuel install?
  194. CL H22 Turbo- Its not your fathers oldsmobile
  195. battery stolen...??
  196. 90 lude throttle body...
  197. Question about 1997 Prelude
  198. cruise control not engaging
  199. CEL Code 22
  200. axel nut torque
  201. h23/vtec wont start
  202. Tire Size 225/35/17
  203. Trouble deciding on wheels!!!!!
  204. Shift Points!!!!
  205. Oil filter adapter for oil pressure/temp senders
  206. stinky H22 problem
  207. wheel alignment
  208. H23 all motor build
  209. blown engine due to tranny??
  210. Distributor and ignition problems?!??
  211. H23A Clutch problems
  212. Weird idle problems
  213. oil pan gasket
  214. Can headers be exposed without the headsheild?
  215. Rs-R vs. Invidia Cat-back Exhaust System
  216. 4th gen 17" wheel , tire sizes
  217. catback exhaust for 01 prelude SH
  218. injectors?
  219. JDM Gauge CLuster ?!!?!?!?!?
  220. Problem starting car.
  221. Thump noise coming from the passenger wheel well?
  222. how to check for codes (check engine) 93 Si
  223. looking to trade or buy
  224. Looking for 5th gen grille emblem
  225. alternator & bracket question
  226. Anyone know the demenions of the radio console in a 5th GEM PRELUDE?!?!
  227. Which h23, or h22 had 10.8:1 compression?
  228. ls vtec on 90 lude?post up your ls vtecs with the box style lude
  229. question about alarm.....
  230. exhaust
  231. 95 H22 and 98 H22 motor interchange
  232. 1994 Honda Prelude Si For Sale
  233. New axles installed, now feel vibrations under loads
  234. JDM H22 Red Valve Cover
  235. Please help me find this lip
  236. 2001 Base Model Upper Control Arm Question!
  237. need help with fuel filter, bout to say fock it
  238. Sway bars, hollow vs. standard, any experience?
  239. pic request - 4th gen lude with any aftermarket seat.>bride, sparco etc.
  240. JDM Turnsignal question
  241. vin # on engine
  242. is the 92-96 prelude vtec front wheel hub 36mm?
  243. A/C problem
  244. 92-93 fog switch location..
  245. H23 bare block weight?
  246. Turbo for 3rd gen?
  247. Hood Options
  248. are prelude 4th and 5th gen pulleys interchangable?
  249. tunning poblem
  250. FS Auto to manual tensioner conversion
