View Full Version : Honda Prelude
- Does anyone know where I can get a cheap pair of new headlights for a 97-01 prelude?
- Exhaust ...more power ???
- before and after ET after FD
- Tranny rattle,can anyone help??
- My misfire problem rises again...
- More proof ap1 rears fit on a prelude.
- fuel and injectors dont fit right!
- Help, Problem with Tps!
- PCMs?
- 01 Honda Prelude HELP
- Removing Underdrive pulley-bolt is out
- coilovers
- New to the fourmes
- JDM Climate Control
- Auto Cluster w/ manual tranny
- Eibach and H&R Spring Rates
- Antenna, Weather strips, speaker questions :)
- Boosting 94 si
- What Color "H"?!?
- what do i need to lower my car the right way?
- Just dropped in motor, I can't get it to spark
- h22 vtec head on h23 block practical?
- Prelude SiR?
- 94 Prelude Si -> JDM Mugen SiVTEC
- Plastigage results for built H23vtec
- B20A JDM SWAP
- Using base LCA on SH
- Alternator/starter rebuild ???
- After market stereo
- Ebay rotors
- need help
- intake install..extra plugs??
- throttle body
- tint
- New Shocks or Low Milage OE
- Valve Adjustment- locknut torque
- Need Help with trouble code P0700 & P0758
- 4g radiator mounts
- Block question for turbo
- h22 skunk2 cam help
- Prelude Exhaust
- anyone need a tune?
- change tranny fluid ???
- Antenna ? EH ! ?!
- vafc II plug and play
- bb6 foglights
- will a rad from a 93 vtec h22a fit a 96 h23?
- Prelude Bulb size
- evap 2-way valve?
- righ23 oil sending unit
- 93-96 and 97-01 intake manifolds the same?
- rim/tire sizes on 4WS equipped 4th gens
- Need Calipers 94 Prelude Si
- Brake Systems different in Si vs. VTEC?
- Another VTEC question
- what part to put hondabond on?
- 5th gen suspension???
- Best Deal ever and i missed it...
- Ebay(World Suspension)? Has anyone purchased Tie-Rod Ends from them?
- 98 Prelude H22A4 w/ seized block
- AC keeps turning off
- 92-95 Prelude brake conversion
- Need help with vtec
- Odessy 545C Battery - Good to start?
- Can't find screw to adjust my idle
- F22C1 pistons in a JDM 93-95 H22A1 V-tec engine
- Chadil Itb's for the H22 anyone
- heater control lights help
- 93 H23 Prelude f/s
- Power steering thing
- -Intake??-
- Reving Safely at 9Grand on H22
- Buyer Beware OsakaJDMmotors.com
- Euro-R intake manifold owners...get in here!!!!
- What is this? CAn i remove it?
- high compression h22
- What will get me more power?
- H22 Lower rotating assembly
- Request for GC/Koni install help
- searched- cold start valve removal
- JDM Center DSP speaker(s) setup
- tranny swap. worth it?
- RSX steering in our lude
- question on part
- 1997 Prelude Reliability
- JDM red H symbol
- Synthetic oil to High Mileage oil ?
- Swapping to H22a from Prelude S Single Overhead Cams
- Adjustable lower control arms
- H22a1... How much can I boost?
- JDM sidemarker install question
- another idle prob. question...
- timing belt replacement questions
- Wire tuck, Battery Relocation, Fusebox Relocation
- AUTOPOWER roll cage in a 3 gen ?
- Swapping to H22a
- another rim question. 4th with 17"s?
- Underhood Fuse Box diagram :searched:
- Just Died
- Dropping the Motor
- can i switch the sleeves on my coilovers
- F22 Header
- Need better engine mounts
- Estimated whp? tach vid inside
- Cylinder misfire
- '93 Si 4ws H22A LSD Swap
- Prelude LSD ???
- When should I use seafoam?
- H23A blue top?
- ProScan tool for OBDII vehicles
- 92 prelude S, digital gas and temp guages not coming on anymore.
- mugen lip, oem lip?
- a set of koni yellow / gc combo for base should fit for SH as well?
- Tie Rods?
- JUST BE WARNED>>> STAY AWAY FROM GENERIC CAMBER KITS
- cams
- fuel & temperature display
- H22 Distributors: JDM vs. USDM
- Crower Camshafts??
- Kimini: A book on building a mid-engine Honda-powered sports car
- h22 tranny 5th gear grind and no reverse
- another tire question
- Converting to Manual rack...what is this part?
- oil pressure light flickering
- JDM LSD Automatic Question
- oil pressure sensor access
- I have a 98 Honda Prelude!...Engine Problum
- Swapping an H22 into a 2nd gen?
- Stainless Steel or Ceramic Header?
- Megan header collector Mod
- Alarm system
- Replacing front sway bar end-link
- HELP!! ATTS FLUID
- Shifting problems.
- jdm h22a firing problems = not firing in cylinder #1
- Prelude 94 2.2 vtec Engine light
- 93 lude axle bolt size
- Upper Ball Joint Replacement
- H2B in a prelude???
- soft brake pedal, im a little scared to drive hard now
- does anyone who lives around poughkeepsie ny have prelude injectors they want to sell
- 16x7 40 offset? 5th gen
- Progress rear sway bar compatibility??
- head swap help!
- Question for last gen Prelude enthusiasts.
- 350Z exhaust on a Prelude
- Does anybody know the price of a new timing belt system?
- new suspension squeak
- Brake Light on Dash Keeps Comming On?
- 2001 lude....help
- Lowering springs or coilovers
- Problems with Toe
- 240cc injectors, instead of 345's, bogging?!?
- First time nitrous, just a couple unanswered questions...
- suspension specs
- Stock Motor + FI = ?? Most PSI on stock Motor
- Exhaust question
- H23 Turbo
- Handling
- Wrong Rims Offset
- 5th gen engine swap question
- After hundreds of dollars, all I needed was a Fuel Filter to stop my car from stalling!
- Anyone on Skunk2 Springs?
- tranny question
- custom exhaust
- Strange sound from the front end...
- EL swap problems in 92
- Need M2b4 Help
- 1990 Honda Predule! Help!
- 1/4 glass removal
- suspension specs?
- h23 throttle body vs f22 throttle body
- Fidanza Aftermarket Drive Shafts
- Miscellaneous Questions from a noob. Please help!
- What else to check to fix low idle?
- Bad Suspension? Tein SS Coilover Gone Bad?
- Stupid Throttle control question.
- Turbo on engine w/170k?
- Vtec Not Working
- gas and check light?
- Machine Shop in Charlotte metro Area
- prelude 4th gen cupholder
- P28
- h23 lude swap h22
- JDM H22 pistons fit in a usdm h22a4?
- Removing Crank Pulley Bolt
- can sum1 help walk me through a turbo setup in a 92 lude sr 2.3L
- How do/did you like your BB4 Prelude?
- oil leak somewhere on the passenger side? Not oil cooler oring
- Weird Engine hesitation
- Misfire Codes after Seafoam
- pics
- Got a very crappy brake problem , how do I fix ?
- replaced oil pump, small problem
- tis is my lude
- whats diffrenece between USDM H22 Vtec solinoid and the JDM h22a?
- this is my lude
- Will a 92-96 Prelude transmission (5SP) mount up to the 97 Prelude?
- What wheel is this?
- Reducing Wheel Hop
- coverting your hard brake lines to stainless steel braid lines...
- Getting Rid of the S2k Wheel MYTH!
- weird prblm with my 94 prelude vtec
- Headlights 92 Prelude S
- All-Motor Mods on 170k 97 SH
- ok how do you tell a jdm lude from non jdm??? can ANY one help plz????
- any A/C gurus here? need ideas..
- Big injectors, idle question
- Where to buy Sensors
- Proportioning Valve
- Starts then dies in cold weather when the motors cold
- whats the diffrence bewteerna bb6 and bb7 prelude??
- apexi turbo timer wiring harness
- Looking for a rim centerpiece...
- Nissan 240SX RSR ExMag Exhaust
- 4th gen suspension clunking
- 1999 turbo prelude
- h22a4 blockshizzlee
- IAB question (searched...but get even more confused everytime I read a thread lol)
- Help, replacing fuel filter!
- may be picking up a 2nd gen lude
- FAST
- 5th Gen WWRS Lip Kit & Sh Wheels + other things
- tiptronic, poositble?
- WTB H22 front tranny mount ASAP
- megan racing header
- jdm h22a gets hot, then getting cel 22 - help?
- Stock s2k rims on a bb6? what ya think?
- fuse box remover
- 1990 prelude sr/options
- 1st gen timing marks??
- heat doesn't enter cabin vents...
- Prelude Mugen Parts. how much would you pay for them!?
- 1993 Prelude Si 2.3L
- H23A swap to H22A - NO FUEL!!!
- just got a 99 prelude, require help
- Compression #'s...
- f22 oil pickup tuber vs. h22 oil pickup tube
- EGR Removal..
- Brake Kit
- Is the F22 oil pump and the H23 oil pump the same
- Head Light Problems ?? Please help.
- polishing/cleaning parts...
- F22b questions?
- 1991 Si CV shaft
- bad oil pump?
- h22a block on a h23a1 engine
- 93 JDM h22a with chipped out p28, Wat do u think about a manual Vtec Switch????
- oil pump gen4
- 16' Rims with higher profile Pirelli tyres?
