View Full Version : Honda Prelude
- Brake cylinder w/ video
- Intake
- ecu pinout
- '86 prelude question
- Tuning Vafc by looking at dyno sheet
- freakin brake dust shields!
- Suspension removal (rear)
- can't get going over 55 or 60
- question for you h23 guys
- Need advice on putting F22 Accord/Prelude S 5th gear in H22 tranny
- Does anyone have GM Syncro mesh for trans fluid
- help lude wont start
- HELP!! all i need to know is which wire is the stock tach wire 5th gen!!
- h22a head on h22a4 block? headgasket?
- what size are clutch bolts?
- WITCH ONE???????????
- got a bad vibration
- Mugen Exhaust ??????
- Which F22A6 parts will fit in a H23A1?
- Rear Wheel Drive?
- Moroso products for ludes?
- 1999 Prelude Ecu code questions
- need help
- 100K VTEC model Lude
- Whats next for more power
- 3000rpm idle?????WHY???
- Rebuild H23
- Best Exhaust for 96 VTEC model?
- Lowering of stock seats.
- Golden Eagle intake mani Bore
- VAFC HELP (APEXI)
- prelude cambering problem?
- Is it fairly easy to adjust your...
- anyone running a gen4 h22 header on a 5th gen h22a4 sh??
- Difference between injectors
- 4Bidden Motorsports short shifter???
- might sound stupid, but?
- Syncro's........
- possible to post and "contour" IABs?
- IB Wiseco Specs?
- Valve assy, bypass control
- Pre-Paint Prep : Give me all your prep. tips before I drop her off at the shop.
- 4G rear camber adjuster 'seized'...
- Cant get my injectors in.
- 2001 Projector Headlights
- jdm p13 questions...
- ABS light will not go off
- Anyone have this kind of intake???
- Brake master cylinder replacement *help*
- How to read error codes? + Whats in a Technical Service Bulletin
- 88 lude S
- my car is over heating need help
- ride height
- What's the function of the Power steering Pressure switch??
- grinding noise after lowering
- Finally finished my Swap!!!!
- any probs with eagle rods?
- Need Help Type SH tranny
- HPOC (Hawaii Prelude Owners Club)
- h23 vtec blew after 3 runs
- ??'s about hondata/header
- taking out A/C unit....
- 4th gen vtec sterio diagram needed
- Idle jumps up and down.
- Ghetto turbo f22
- Osaka Motors and Knock sensor ?
- How do I obtain/pull the codes from the ECM
- you guys ever used pro clutch?
- Neld installing my msd ignitions
- car idles like a V8!!
- Just back from the drag strip
- Found a lude' are they asking too much?
- h23 : quartz of oil ?!?!
- How wide of tire can I go?
- Engine lopes at idle on B20A5
- Apexi pipeing
- Help.. how i open a h22a tranny?
- brake lamp...?
- Whats "Pressed-on"?!
- Turbocharger?
- How to get AC out??
- ECU help
- where to buy darton sleeves
- adjustable fpr help!
- For all you Old School Prelude lovers out there!
- sick of the cel. is there a real fix.
- Alignment Question...
- IS TURBO SAFE???
- oil pan different for SH then base?
- H22 head help PLEASE!
- B21 help
- Which vtec motor should i use! help
- Locking VTEC mechanisim to degreeing the cams?
- H22A pistons in a H23A, how much compresion?
- --Need Advice Planning Sleeper Setup
- Rough ride... noisy...?
- B21A1? Any good?
- h22 pistons, H23 rings?
- BB6 Fog Lights
- HELP! is needed with vacuum lines
- VAFC on a 5th generation prelude
- Fix for vibrating noises coming from the trunk area: 4th Gens
- Fujitsubo Legalis R exhaust system
- 88 Lude si trani
- 88 Prelude swap
- F22slow to vtec?
- Anyone heard or have experience with H23 Crower Camshafts
- Spark Plugs
- 92-96 header and downpipe on 97+ h22a4
- fuel system reccomendation??
- G3 Where to find CEL codes
- WHat do ned to know about Preludes?
- Mod JDM F22B, Boost JDM F22B or do an H22A Swap? (4G)
- Please help, installed built H22, won't start
- Miles on engine? Miles on car?
- is there a JDM prelude steering wheel?
- H22A4 VALVE ADJUSTMENT QUESTION!!!! NEED HELP!
- For all of those who have thier front license plate removed...
- Transmission problem...1998 SH.
- Trans Question
- lowering springs/alignment question
- NEED HELP: Prelude/Accord lowering springs
- Change steering wheel, need adaptor hub part #
- OK GUYS GOT A BIG QUESTION IS A F20C motor swap possible into a prelude??
- jdm tail lights
- AEM pulleys and unorthodox
- prelude flywheel question..from accord..fitment?
- Common reason for an AC compressor to stop working??
- JDM head and USDM head
- headlight relay
- question about falken azenis tires????
- Tananbe Springs vendor?!
- Specs h22a4 large journal crankshaft...ASAP
- Need 92-93 Prelude foglight switch pics
- H23 -> H22 how-to?????
- Installed: Espelir JGT500 exhaust
- Little help...
- tunin up a h22a without spending any money?
- AC filter replacement
- evil h22a, why do you leak oil!!!!!
- Special offer for H-T members on Prelude SPK (sunroof plug kits)
- Type SH CaMs
- FYI - Found cheap Azenis in NY :thumbup:
- new trans problem
- Straightening steerting wheel 4th Gen ?
- wideban o2 sensor
- 1988 Prelude Si seats Information needed....Please : )
- no boost
- H22A swap not starting
- Big thanks to Crower R&D! (custom cam pics inside)
- Radiator Question - T03/04 Turbo
- lose connection?
- EGR problems...need help!!
- timing belt broke
- should i do it or not?
- Turbo sizing
- Shifter Cables Going To Transmission?
- Searched...Need H22a Camshaft specs......ASAP
- 1986 Honda Prelude engine code?
- installing skunk2 valves
- Road racers and autoXers. Need your help with spring rates
- n InIntake question need answers ASAP
- All Motor Build Check List...
- help with lights??!!
- Tire Advice
- OK guys and gals heres a good question!
- H22 and H23 intake the same?
- Help!
- 4th gen Foglight wire Q's?
- conversion/h22teg w/AC & Power steering
- FOUND A CAR! WOOT!
- Oil consumption?
- What Header for 5th gen
- F22A questions
- just got the tranny job done, but i have a few ?'s...
- bang for your buck-advice for my new H23-anything can help.
- supercharged lude
- Front cross members.... are they the same for 4th anf 5th gen???
- 5th Gen : Routing Compressor IC Piping?
- type S pistons valve pockets
- timing???
- Gas tank drain plug?
- Will these wheels fit?
- f20a -h22a
- camshafts for h22a4
- PROSPEED HEADER RECIEVED!!!!!
- black soot on bumper, and smoke in high rpms
- H23 VTEC Build...
- 94 Prelude Steering Wheel SHAKING!!
- Prelude SH question
- Air filter?
- What should i do about my prelude, keep or let go
- requesting pictures of 97-01 ludes lowered
- what grit to finish cylinder wall on a h22a4.
- jdm cams????
- difference in cams
- what bushing is this
- Sparkplugs..........Your opinion
- Getting a CEL when lowering VTEC with VAFC2
- hey guys exhaust question?
- Question for those with Hondata(5th Gen)
- PLEASE HELP!!! valve adj nut fell into oil flow hole!!!
- Belt around the cam gears suppose to be like this?
- supercharge better than turbo...?
- cryotreatment?
- h23 vtec help
- resistor box interchagable?
- 4-1 Header?
- johhny race car IC 5" - good for 14b setup?
- wierd question - i think i'm missing somthing..
- 4WS Removal
- 95 Prelude
- swain coatings
- What RPM to shift at on stock tach
- ~~**NEVER Found PROBLEM for 96 VTEC...HELP!!!**~~
- h22 oil filter
- Weirdest Idle ever!!!!
- Need Help Building a Turbo????
- Petition for an intake manifold
- Best suspension set up
- H22A intake manifold
- Stock bottom boost or NA?
- REV valves/springs/retainers. Any good?
- CEL codes means what??
- need help quick! tranny code h2a5?? from what motor?
- Question about injectors for my turbo lude
- help! question on re-locating battery
- Greddy header collector question
- aem help
- Bolt Size for cat-back exhaust (Greddy SP 4gen)
- Help plz Balancer Shaft remv..timing setup ect..
- How do i change my shocks?
- SuperCharger?
- Stock catalytic converter
- SI? VTEC?? mama!
- Hooking up resistor box in 5th Gen
- Part Number for Fog Light Accessory
- Head gaskets?
- question for those who have done the M2B4 swap...
- issues with lining up the tranny...
- Alignments
- Cheap coilovers?????
- Qs about traction bars
- Prelude Castor Kit
- obd2 distributor on obd1 h22 swap
- h22a swap Understeer/oversteer question?
- 96 prelude f22a1 - do i have peak and hold injectors?
- TEACH ME PLEASE!!
- Prelude all motor?
- Crack in Cam/VTEC Solenoid holder!
