View Full Version : Honda Prelude
- Prelude and Accord Engine Bay?
- Is it ok to lower tha rears only?
- Header/Downpipe Q (Searched)
- All motor improvements?
- 5th Gen Prelude Headlights
- What else would I need????
- Just installed my JDM DSP sound system
- New build 91 2.1 won't pass emissions
- How much power can stock h22 rods support???
- dohc h23 distributor question??
- Vacuum hose pics required...
- H22a4, H22a1, H22a8
- 94 si leaking something - what the hell?
- timing belt quick question
- H22 Crank Removal
- Scraping my current Boosted engine setup, advice please?
- help......
- recomendations
- quaife lsd, will it fit?
- Suspension - Lower control arm
- Where can I find a before and after dyno!
- Urgent, doing a tuneup and need to know how much oil for H23 engine?
- 2000 A/T Lude making a Weird Vibration...need advice.
- Brake Grease
- Anyone with a 5thegn lude and had a bad auto tensioner
- Problem with jdm headlight lighting
- Tokico Illuminas/Springs
- how to tell
- tranny swap
- ? car won't start
- P72 in a 5th gen Lude....
- RS*R TI2000...
- Does anyone want a free build? FRM Compatible pistons in the making...
- VAFC and O2 sensors
- 2 part intake question
- enough fuel from stock injectors?
- 2point6 version 1.2
- and then there was life.... partial life
- FS: Rear seats and panels. HVAC equipement 94 Prelude S/Si/VTEC
- 94 Si automatic changing the cv joint?
- Oil Leak! Trying to get ideas of why oil is coming from here and what it is........
- h22a4 head torque specs?
- SWAP PROBLEM
- tanabe rear tie bar?
- Ground wire problem??
- 1981 honda prelude engine swap
- Running Rich??
- New timming/Balence belt SOUNDS of LOUD
- 4th gen sunroof
- 5th gen prelude OEM exhaust
- AEM/Venom Fuel Rail
- Idle Sounds loud/tapping
- itr steering wheel on a 4th gen lude???
- tapping noise..
- need pic of egr vac control valve please thanx
- BB6 strut bar
- Apexi Super Grounding Kit
- Machine shop in reno nv??
- welding front cross beam?
- Ecu Question
- accord front end on prelude?
- Removing plug from connector (atts ecu / main ecu)
- Better handling for street: Stiffer Rear OR Softer Rear
- whats your gas mileage?
- MSD with nology on a 98 lude help
- Suspension slams on every tiny bump!
- Quick question
- my clock went crazy!!
- alternator needs to be relocated
- Someone please help me- what is this?
- 5th Gen: CD Player
- Euro R manifold modifications
- Stupid Question About 5th Gen
- bb6 and bb4 rails ... please help
- Which car has a F20b engine?
- wut trans fit on a h22
- prelude flywheel
- need help identifying part
- JDM foglights
- will it make a diff?Fuel Pre Reg
- Car won't go in gear!!!!!!
- H22a issues
- 98 Prelude Master Window Problems
- prelude vtec eating too much gas on regular driving!
- How often do you change your o2 sensors???
- Jerking at higher speeds and acceleration
- urethane lip kits
- how much?
- SH balljoint removal
- camber kit?
- MIL code 61 help
- Need info on Atts Tranny
- hondata tuning on 91 octane? (100 oct)
- Prelude cranks
- Ran car with no oil
- No AC when i went OBD1 on my BB6
- 4th Gen. Hiro Lip install help
- Check engine - Primary heated oxygen sensor slow response
- bb4 prelude sunroof **question**
- Where is the EGR solenoid on a 5th Gen.
- Eibach Pro Damper kit
- tranny help cable or selector trouble!!!!!!!
- my setup for the h22 obd2
- where to buy wings west WWRS kit for 4th gen ?
- whats wrong with this tranny? pics!
- 1990 Prelude - Lots of problems
- some questions
- couple of ?'s
- quick wheel/suspension question
- Just a quick question regarding my auto trans
- Would a SH tranny fit on a base tranny?
- What 5th gen prelude models did england get?
- Dash light conversion
- Check Engine light and gas cap
- V2 Cold air?
- Which Aluminum cam seals?
- H22a4 Crank H23A1 Block.....
- JDM H22A: A little confusion!
- intake system for 90 prelude si?
- h22 timing ? please help this is the only thing i need to get up and running.
- QUICK QUESTION!!!!!!!!! HELP PLEASE
- why do chipped ecus suck?????
- Tell me about jdm H22A auto transmission reliability issues
- f22?
- Can I rre-use the H22a Head studs????
- Dilemma....spend the cash on ITBs or go with reworked stock mani/big tb/ and velocity stack
- weird question about RWD..
- for peeps who has acoord type r lips
- Recommended tuners in or near Portland, OR??
- window tint question
- hitting curb part II
- Anybody know where i can purchase this part?
- Exhaust Question....
- Automatic Transmission Question?
- fog light = yellow or clear?
- Question about the H22a
- techno
- How to remove EGR nuts without removing IM
- Aem Fpr problem
- wheel question. will these fit?
- Found some damage on the outside of my spare H22A1 block, is it serious? See pics.
- H23 Start up
- new battery and o2 sensor and now the car wont start.....
- P28 VTEC in F22 non-vtec... will it work?
- Longest lasting SS Auto tranny so far
- how much would 92 prelude Si rims cost?
- LED Taillights
- Need Help taking my fog lights off and rewiring.
- My new TB, what do you think?
- Prelude throwing Code 43
- why is my H22 acting like this?????????? WTF
- for peeps w/ accord rear lip
- What to look for?
- Almost there..help with axle removal please!!
- Easy Headlight Question. Please answer quickly.
- need some help
- your topspeeds with h22a
- Pic of your 5 lug swap on the 4th gen
- liscence plate bulb?
- koyo radiator
- 70mm Throttle bodie from BDL ( STR )
- Need help with swap (castle nut)
- "stock" OBD1 H22A4 running Bill Gates RICH
- limited slip differential
- Play in the gear shift lever
- Hedman
- Optima Red Top - which model #?
- Fiberglass????
- Carbon creations hood
- EDM rear bumper light
- k2motor.com
- high horsepower oil pump failure???
- Cleaning up engine bay - remove things
- Vtec not working.. already search didnt find anything..
- The Official: Prelude Exhaust Sound Clip thread.
- No IAB Plate....Good/Bad?
- please direct me in the rite thread i cannot find it if my life depended on it please.
- JDM high beams....
- What Size speakers fit my stock locations on my 2000 Prelude?
- what will get me to about 190 whp?
- Anyone got a pic of a VSS (1992 Si)?
- tranny problem
- 4th gen oem jdm fog lights
- Taillight short (i think)
- How is this possible?
- Cleaing IACV-searched
- question regarding front license plate holder (searched)
- Hood Pins
- Rota grid
- Car won't start!!!
- I need help with identifying the 4 pin connector in center console...
- AEM EMS or Greddy E Manage
- vtec solenoid gasket question.
- APEXi power intae filter adapter
- searched, value jdm rear lip
- turbo and tranny
- obd0
- Hard to start when cold...
- h22a4 overhaul
- Oil catch Cans
- P72 ECU swap
- Distributor O rings?
- Prelude speakers
- times
- KYB AGX/Eibach Sportline owners PLEASE LOOK!!!
- how much hp on stock tranny
- exhaust rattle
- car won't start :(
- cattyltic converter test pipe?
- Short Shifter- Where to get one. . .-SEARCHED
- i got a ? i would like to know something
- Tanabe exhaust question
- evap controll canister where is it ;pcated???
- why are my gears grinding?
- Installed a strut Bar with questions
- Honda Connectors
- noob ecu question
- Lowering Car ?
- Need a new cat, magnaflow??
- Is this harness from a Prelude of any year?
- quick question on boosted prelude
- Removing resonator box - how about the "intake control diaphragm"
- what is a p12 from?
- Winter Tires Sizes?
- help with swap, which ecu?
- h22 swap from hell almost done, but now no vtec
- turbo on ebay
- Window tint percentage on prelude
- What is this sensor???? please help thank you.
- Prelude (5th gen) Coilover install?
- new doors or have bodyshop fix it?
- Transmission Help?
- I heard the best way to go with bars is front strut bar and rear sway is this true?
- Stock prelude with CAI, inline fuel pump? h22
- JDM BB4 no sunroof prelude -> picture from inside
- prelude turbo kit
- obd2 injectors
- different IAB plug?
- skunk 2 intake manifold
- tranny rebuild
- Tein Coilover Owners...
- I call this the OH SNAP!!! thread. My Timing belt broke at 65mph, story inside..
- prelude challenge
- Please Help!!! Strange electrical problem with fuel pump
- h22 swap problems
- h22 swap ecu problems
- Weird 5th gen bogging problem..
- 5gen rear suppension knock sound, help........I know again
- crank pulley key wont come out!!!! any help
- Ingalls Installation on a 1992 Prelude 4WS
