View Full Version : Honda Prelude
- how to aff fuel with vafc, please help
- swapping for an h23
- 2.2 VTEC Overheating
- Next Acura RL to use ATTS-like system
- Noob prelude owner needs help : front speakers
- Help with a new h22 in my lude
- what engine do i have?
- Zex in a 98 lude ... ruined my idle....
- stock lude vtec sticker ???????
- prelude event's and meet's ???
- Bad Clutch..?..Or Tranny?
- VAFC settings on built N/A h22a1 engine
- Help-header hell (h22)
- Decent Prelude forums
- Strut Bar Question??????
- Max power on OEM H22A4 headgasket?
- What are the Pros and Cons of H23block with H22 Head
- where to buy alternator
- 5th Gen Bumper Problems
- removing emblem glue
- Flywheel Pilot Bearing? HELP
- weird thumping/clicking noise? cv boot?
- cam shaft journals on an 89 prelude si (DOHC)
- Turbo both oil and water cooled?
- rod knock????
- Tail light replacement..i've searched
- dot 4 fluid safe for 4th gen?
- why isnt my car turning ON!?
- ARP torque specs for H22?
- clutch judder
- I'm new here....
- Exedy or ACT?
- -HELP- h22a turbo? Prelude SH?
- a question for the h22 people
- Set up plans as of 5/28, check it out and critique away...
- FAILED emission's again.. but getting closer
- headlight brows and door sills
- what plugs for turbo h22?
- H23 non-vtec.....is it fast??
- What size ignition wires are best??
- 5zigen spring rate?
- How long did your stock clutch last?
- How good is an OBX Header?
- Trouble Shifting
- The Science Thread
- Quick question, Whats the most hp/tq out of a turboed h22????
- 4th gen lude questions
- Starting problems
- Any 1 piece headlights other than JDM?
- Exhaust set-ups improving fuel efficiency?
- camber kit necessary for 1.5 inch drop w/tien springs?
- Clutch/Tranny problems with good description...Help please =/
- idle surges low...
- Bigger Rims = Less power?
- Honda told me that preludes are designed to burn oil
- stamp vs merge collector? prospeed header qs
- 92-96 or 97-01 header? (bottom half)
- Legend calipers expiriences
- Si Header?
- Si?
- H22A
- Difference?
- Low g-tech HP ratings on stock 97 SH
- 92 Prelude SI worth $4000 before mods? Should I buy...
- wheel lug dementions?
- H22A NA Power Mods
- jcwhitney is upgrading systems, get 10% off until June 3rd!
- SFP manifold
- Review: JDMShit.com's P28 H22a Race Program
- I got 2 ECU codes... can anyone help?
- Scatter sheilds?
- want to convert h22 hydrualic tensioner....
- type s cams....are there any markings
- torque specs on the bolts for the header?
- Bogging Problem with JDM H22 Turbo Setup
- turbo automatic
- question regarding teh 4th gen 4ws system
- best cam for our car?
- Greddy SP 2...Exhaust??..Any Good?..Or Tanabe Hyper Medallion?
- Charging system light and brake light
- jasma exhaust
- prospeed and AN-r
- How to ruin a motor 101 - Hydrolock
- Have you replaced Engine
- LEAKING CLUTCH FLUID :(
- 1988 Prelude PROBLEM!
- How hard was it for you to find your prelude?
- Question regarding future hybrid suspension setup
- oversized rod bearings....reliability issues?
- installed my smsp header on sh today!!
- What color is the check engine light normally?
- Replacing Lug stud
- f22 power steering pump on h22
- Turbo & fuel related. True/False?
- how to fix back window trim ???
- Lug Pattern Question
- msd or vafc?
- Anyone watch 2-Wheel Tuesday on Speed? 05/25/04
- problems with my timing belt?
- Buying 5th gen prelude
- b20a turbo cuhz
- i am new here ......this is my prelude
- tranny qeustion
- Need a pic of a 4th Gen ECU and how to find it
- thermal cl on 5th gen
- Retrofitting the R12 prelude to R134a - anyone???
- 4th gen VTEC auto-tensioner
- SRS system...
- AWD Prelude?
- airbag removal help?
- humming sound ?
- 32% tint
- prelude trunk parts
- what exaust..
- Some Updates..CF sunroof
- need pics of legend caliper swap
- do it yourself suspensions upgrade
- valve adjustment specs
- H22A4 info...
- H23 si ran low on oil
- my 91 prelude
- SPEEDOMETER HELP
- CAI?
- 1994 Prelude Si ---> R-134a or R-12?
- bolt to tension pulley belt broke in half....HELP
- will these baddest wheels fit
- skunk 2 coilovers
- koni yellows with tein springs?
- Walbro FP Application question...
- First Ride in a 98 lude.
- Muffler or full exhaust?
- cheapest place for types pistons and what method is there to honing for these pistons
- Newbie
- Transmission for H23
- difference between h22 transmissions?
- 98 prelude ecu wiring diagram
- s2s1 cams in, now dying at 7 copletley , please help
- str intake manifold h22
- cost of h22a engine and tranny with ecu
- how can you tell the diffrence between a h22a and a h22a from a type S engine
- weird vtec prob on h22 turbo civic hb. please help..
- h22 and h23 cam caps / holders...the same?
- fuel pressure or starter?help!
- Dataloggers
- Prelude totaled
- oil pressure sending unit, thread size?
- 4th Gen Progress Rear Swaybar Clearance Issue
- I want to Know My Car (sources??)
- How do i find my ecu and check the codes?
- Side moldings on 97+
- Red Key Fiasco..........(#3 continued)
- could a bad starter cause problems?
- suspension thoughts
- Next mod for f22b?
- should i buy an fpr
- Pilot Bearing???
- My engine is acting up, suggestions??
- Thinking ahead, need your guys' imput please
- motor mount questions
- Suspension Questions
- H22 head build diff options/Questions
- Anyone have any pictures of a crank? A lot of ??? HELP
- sharing my setup
- question bout wheels
- Stock Dynos
- OB2 sensor and CEL popped up. Need help ASAP Please!
- Radiator Question (help!)
- 94 prelude catback fit 92 accord?
- Getting my transmission rebuilt in a week.
- - PLEASE HELP - AC Compressor question - JDM H22a/ Sanden TRFO90
- throttle body spacer
- Tanabe Racing Medalion...OR....Skunk 2..????
- Walbro Problem
- turbo kits
- 2001 Prelude tranny Problems
- H22 bogs when VTEC hits at WOT
- HONDATA IS HERE!!!
- muffler issues..
- Can the H23 bottom end handle the high redline of VTEC?
- Help i need the deck code
- Changing OBDII ECU to OBDI... What else do I need? Can it be done?
- Mitsubishi Evo VII Injectors
- Fuel injectors?
- Starters
- H22 Redline?
- E-brake light
- 2nd gen motor swap
- HI FLOW CAT TALK
- I want to turbo my 97lude....pls help me out...!
- installing a hondata gasket on a 97+ prelude
- how do you wire from external coil to internal coil on h22a
- h22 on h22a4block
- should i try dsm 450cc's? on the dyno
- Prelude stalling
- question about exhaust fitment??
- N/A build fueling Q's
- Fitting bucket seats in a 4th Gen Prelude
- request pics of a ported h22a head
- No spark from ignition wires..... what could be wrong?
- How hard is it to put an H22A head on an F22a block?
- new dash gauges to install...
- Just got a 98 Lude SH
- curious - motor sounds
- Best place to run wires...
- Timing belt, clutch, and ECU upgrade
- Need info on the 95mm crank from the DOHC VTEC H23 in the Accord SiR T wagon
- exhaust a thought
- 1992-1996 Prelude VTEC Greddy Stainless Steel Headers...PROBLEM!
- modding dc to 2.5 collecter
- need help on h22 swap asap
- distributor problems
- Jackson Racing V-Tec Controller???
- ? for those with MSD 6AL...
- Need AC and PS diagram
- H22A/H23A Crank Pulley...
- Should I buy '87 Prelude 2.0Si
- Should I buy an '87 Prelude 2.0Si
- h22a tranny
- Help on H22 swap
- Weird noise when starting in 1st??
- CEL codes 6&7 how to fix ?
- hondata ecu's
- please help!!! STR throttle cable bracket question
- help with AEM v2 intake
- Apex'i VAFC Stock Settings (I read the whole VAFC post)
- H22 and H23 ?'s
- what is minimum compression ratio for 1995 jdm h22a
- driver side mirror
- Changing the headgasket, remove the IM first?
- Just got back from the dyno.
- another h23 in the making
- 5gen: common to have LCA bolts seize?
- 98sh buildup...
- another 3rd to 2nd question
- ECU QUESTIONS!!!
- just wondering
- EXTREMELY high oil pressure??!
- Does a 94 + adjustable strut bar fit a 97+ lude?
- automatic car tries to "gear down"
- Reverse wont go in for anything.......
- Pic of "H23A DOHC Vtec" -> question about distributor
- tuneup help / radiator fan and idling / bumper lense screwhole help
- Anyone buy from www.autopartselect.com?
- prelue drivetrain layout
- Exhaust Question
- 5th Gen shock hat used on a 4th Gen Prelude. Can it be done?
- Replacing Valve Seals... How?
- about the prelude...
- Oil Pump Difference
