View Full Version : Honda Prelude
- Is it good to port a h22?
- Stall problem
- tires are rubbing
- what is the best spark wire to run on a n/a h22a jdm?
- boring an h23
- low oil pressure
- Ignition Problems
- Do 3rd Gen headlights fit on a 2nd gen.
- h23 rich oil and eating gas any ideas
- h22 ecu pinouts
- Alot of Carbon on Muffler
- Help
- The Official Prelude Exhaust Thread
- So what exactly is wrong with my prelude?
- ways of identifiying tranny?
- Power Steering Pump :: JDM H22A vs. USDM H22a#
- Brakes
- HELP! got some Q's about a 91 prelude and b20's
- wiring up H1's to "running/parking" lights for JDM 1 peices?
- gears behind headlights?
- Do you consider the Prelude to be a Touring car?
- code 9/keyless entry prob/stock radio
- H1 HID kit.
- Where to get JUST a manual tranny...
- Where I can find full pillar pod for my lude?
- Positive Camber ???
- checked the dipstick and it looks like this... is it normal?
- **help**
- anyone know if this IC will fit?
- intake manifold chamber hose not connected= over heating?
- No spark? What could it possibly be?
- Has any one tried this Canadian modification?
- looking to buy a new h22 head
- Tokico blues for 4th gen good?
- 92 lude check engine light car wont start, PLEASE HELP ME
- Boosted h22a - which spark plugs?
- Prelude 97-00 exhaust on a 93-96 prelude
- 4th gen headlight conversion on 5th gen lude?
- Just Chiming in.
- Headlight Options for 5th Gen.
- f22 tranny
- 3rd gen lude
- piston to deck on stock h22?
- P13 QUESTION ?
- MUGEN CHIP ?
- Damn check engine light
- how much damage...
- Powercore Header?
- Were can i find a distributor cap for a 99 prelude type s
- cheapo cat fit on my RSR exmag?
- H22a piston
- how long will these mods last?
- h23 tranny
- shaking car under acceleration?
- i just got a v-afc controller
- 300zxtt injectors in h22?
- 1993 Prelude S left rear suspension
- what the hell is this?!?
- Best intake manifold?????
- fresh oil...really dark?
- General question
- Removed AC, what should i do about the evaporator?
- already searched, need help Wiring my JDM headlights
- dsm eclipse pistons in a jdm dohc f22b?
- what exhaust system to go with?
- Project: Teh Frankenstien
- RED 6000K H1 XENON HEADLIGHTS
- H23A rebuild
- climate control schematics
- Gunk inside valve cover
- new brake problem....
- Prelude's AC weight?
- Buyer Header...Need opinion on which one!
- E-Brake Light Problem
- First Time Replacing Spark Plugs!
- Can someone provide pics for tranny changing
- idling lude
- is this turbo very streetable?
- 5th gear grinds..new shift fork? syncro? help please
- Smaller wheels affect ATTS?
- Code 9!! other strange problems searched!
- Bottom End laggy ?
- I'm completely dumbfounded.........
- Does adding Lucas Oil stop the traditional Honda engine "tick"?
- Reducing weight?
- LSD swapping
- Where should my 98 be on my vacum gauge?
- 4th Gen Spoilers
- Coolant system
- Door trim (Stereo install)
- Oil change what should I do
- vtec not working
- should i replace the coil if it looks like this?
- Will this turbo work?
- code 12 egr sensor help!!
- Speedometre is messed
- o2 sensor and VAFC management compatibility question
- M2f4 Transmission LSD or NOT?
- quick question.. will this catco cat fit
- Clock goes on and off.....
- Stock ride height
- HELP PLEASE CAR boggin, shaking and stall OUT . what could be the problem
- AEM CAI question
- rear wheel/suspension help...
- my keyless entry wont work (5th gen)
- Got a question about tie rods 4th gen si non4ws?
- h22's reputation...honest opinions!
- ? on running hondata
- got imagestation hooked up how do i add a picture to my dyno post
- flat tire...atts light...
- h22 u.s. and japan h22
- after market suspension bushings
- CEL code 9(nine) update
- How much fuel should i add to get to the dyno?
- Legend/VTEC caliper brackets
- sunroof sounds bad when closing
- JDM DC Header
- BARO SENSOR?!?!?!
- PirateMcFred (please read this)
- the right way to lower
- Type SH and the Skunk2 Manifold
- anyone removed their ATTS?
- Springs bad or good?
- Came to the experts for some answers...
- Just ordered a Prospeed Header for my 95 Prelude VTEC!
- I need Help on 98 Vtec Prelude
- Accord Type R / Euro R transmission
- h22a4 cams are hard to turn question
- hesitation under and between 2 and 3k
- Caliper troubles
- Ticking noise (did search)
- shifting not smooth?
- 1989 SI Starting problems
- Smoking...
- 4th gen power window switch auto doesnt work is it the switch
- where to buy aem v2 filter?
- Wheels
- annoying rear panel rattles with bass any one run into same problem ??
- Tien Coilovers and Fender-well Clearance??
- misfire
- Install prelude camber kit
- help i lied so sorry help help POS wont start
- Car Sound catalytic converter
- Wrtie-Up: JDZ Digitial Climate Control Install??
- Power door locks
- wireing turn signals up top into running lights
- intake mani port matching
- removing secondaries
- well blew the rings....
- is this a good fully built h22 set up?
- compression test ?
- Nology wires ok 2 use???
- my stock radio wont work!! (5th gen)
- Please help me, how much is this worth? RHD 95
- spark plugs ?? are stock platinum just fine for NA or definitely upgrade ??
- valves
- Atlanta Prelude Club?
- Anyone have stock injector size for a JDM 1994 H22????
- whats the best ground wire out there?
- Got the car dynoed finally disappointed with results . are these #'s to be expected how do i get mo
- vtec code
- skunk2 intake manifold?
- bad o2?
- need link to 86 prelude ecu chat help any one
- 5th gen shocks!
- Matrix 4 point harnesses worth the money?
- Help! no brake lights
- help
- Tranny Woes (m2b4)
- Adjusting TPS on h22a1
- Silly question: Cup Holders
- non synthetic or synthetic
- coilovers on 5th gen non SH
- H22A and H23 wiring harness difference?
- How's a 5th gen prelude SH VS 98GSR, 99Civic SI ?
- Get more power to the ground...
- Polishing my SE rims? "chrome" look....tips?
- where to find urethane bumpers for lude?
- F/S H22A1 Motor only!!!
- VSS Speed Gear on Differential - HELP!
- Does anyone know how to remove the rear inside panel?
- Anybody selling owners manual ?
- Location of Spark plugs?
- mobile 1 synthetic or castrol syntec?
- 91 Prelude Si ecu code ?
- HELP ME PLEASE!!
- buddy just bought a 98 SH.. wtf is this..
- Need shop in SoCal to do tensioner
- The 'I'm new what can I do for more power' thread
- what kind of greas do you guys use in your axle boots?
- Steering Knuckle Question
- Finding Rev of h22
- Autotranny Cooler on 5spd=oil cooler?
- what is the cheapest way to gain BHP
- Question about Governer
- tranny fluid for boosted prelude
- Kakimoto exhaust
- Valvetrain for turbo setup
- Help me with my prelude pleeze..
- Irratic idle problem
- Power Window Switch
- hondata stage 2
- Crank Sensor
- Driving event at Summit Point this past weekend. PICS
- What is the Sub Frame?
- Won't flash start anymore..
- Can change my manual gears when car is moving without clutch? !!
- what is a shorter way to call a prelude? ex/ dc, ek, eg, ebp, ep, ef, da...etc
- Loose piston pin- causes? dangers?
- is anyone running uberdata on their 5th gen lude?
- neuspeed koni yellow question
- Problem at 3000 rpm when COLD - please help.
- detonation?
- 4th gen spoiler mounting
- clutch noise
- starting engine
- Digital Climate control
- Wires problem? Enegine check light on when I turn on the light!?!
- Quaife Limited Slip Differential for H22 tranny?
- Tranny oil replacement
- Proper way to store car?
- What are good SPARK PLUGS?
- what kind of tranny fluid i need?
- completed jun ecu upgrade..........now spun bearing........
- BIG compression problem. Please help!
- high flow cat
- trany fluid
- h23 vtec redline?
- 88 prelude (possilbe fixer upper) 2.0 Si 4WS
- should i wait till spring
- Once Again, Weird Tranny problems
- turbo setup for 92 h23
- 4th Gen Gone
- 9005/9006 (USDM) vs. H1/H4 (JDM) question
- Help
- SO MUCH SMOKE out of my 94 Si. Should I bother taking the head off?
- knock sensor being bad cause car to be slugish?
- leaking oil from somewhere...
- Any ideal what would happen if...
- Did 5spd SWAP, now I have no RUNNING LIGHTS!! HELP!
- tsudo cat back exhaust?? what you think?
- H22 Belt size
- wut does water in gas feel like??
- 2004 s2000 Rims, brake rotors, & calipers work on 5th gen?
- VTEC PRELUDE VS. GOLF GTI?
- knock sensor & ATTS problem
- removing factory deck
- Uncontrollable Rev?????
- 3k Hesitation?
- STOCK H22A FUEL&IGNITION TABLES ?
