PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. ? about older preludes
  2. JDM Prelude Type s
  3. JDM Spec Prelude Type S.
  4. spoon honda chip
  5. H22A7 PDE Euro-R Questions. Turbo? HP limits?
  6. looking for new axels....
  7. F22/H22 Engine wiring harness differences.
  8. prelude clutch problem
  9. H22A Valve Train Adjustment
  10. What cams to get (H22a)?
  11. How to tighten belt on a manual tensioner?
  12. How do you do a compression test?
  13. ABS Light
  14. usdm h22 parts into jdm h22?
  15. Question??
  16. H22 head with h23 block dyno results!!
  17. 02 sensor..
  18. Exhaust valves and head gasket woes…
  19. Stupid VAFC harness question
  20. SRS light coming on
  21. H22A Specs? auto vs. manual
  22. hooking up vtec h22a
  23. Back from the dead
  24. TYPE-S engine
  25. Help With H22 valve spring stiffness
  26. stopping rust
  27. H22A Cams.
  28. Engine smoking/horrible smell.
  29. Let's all make fun of the new guy(me) and answer a Q in the meantime :)
  30. Alt Belt and Power Steering Belt
  31. New to this whole retro deal, whats your guys opinions
  32. 5th gen slow acceleration issue
  33. 5th gen foglights in a 4th gen
  34. tranny problem help plz
  35. plz need help on h22a 95 >>>
  36. H23 parts, H22 parts, interchange
  37. H22 Turbo Need Help!!
  38. engine light
  39. cheap Ebay Fuel pump.
  40. Help. Car pulls to the right upon braking??!?!?!!?!?
  41. Code 9 Cylinder position sensor HELP!!!!!
  42. I Need Your Help Asap !!!
  43. Where to get engine sensors
  44. *Searched to no avail: JDM Climate control, Heater core sensor?
  45. stiffer valve springs causes hard turning cams?
  46. Engine problems
  47. PP.com JDM Replica Fog Lights GB
  48. JDM H22a Crank Pulley Bolt Direction?
  49. water pump leaking
  50. how do i get 200+hp out of an H23
  51. HELP tranny issues
  52. 92 Accord w/H22
  53. recaro seats in to a 4th gen prelude-which rails
  54. h23/ h22a pistons will this clear
  55. Not shifting right in high rpms
  56. Help!!! Motor swap '99 Base to '98 Base
  57. Radiator support replacement
  58. My motor finally got started yesterday!
  59. Anyone use the Apexi AFC NEO?
  60. How do I go about making my 2000 Honda Prelude from a FWD to a 4WD???????
  61. '01 SH: LSD and ATTS. Similarities and Differences?
  62. hel with radiator!
  63. Quick "What Rod is this" Searched failed!
  64. auto-manual swap wiring help
  65. Few Questions for a F22A1
  66. Looking for cam recomendations
  67. Clutch and Flywheel
  68. now for cruise control
  69. h22a sernsors/ plug wire help
  70. My wheels always get cross-threaded with the lug nut.....What's the problem
  71. Need info on JDM F22B
  72. prelude h22a1 engine harness
  73. flywheel installation
  74. Speed Sensor...
  75. Can not unlock Driver side door
  76. H22a4 balancing shaft question
  77. 99 SH prelude - Wanting to swap in a 92-95 motor
  78. Cruise Control Switch Bulbs
  79. Im Looking for an ECU FOR MY 97 PRELUDE
  80. Lightened flywheel, cons?
  81. Fuel Pressure Adaptor Nut
  82. ACT pressure plate still good?pictures inside!
  83. VAFC: will it fix running rich?
  84. '93 H23 to H22 Engine Swap Nightmare in Indiana
  85. H22/H23 Flywheel timing cover
  86. anybody who has installed tockio struts and springs
  87. Pulling codes and resetting ECU
  88. How's the AEM EMS for tuning?
  89. Oil leak problem p/m/o!!!!
  90. Oil leak, bad pan?
  91. Engine Code 36 anyone
  92. prelude axles
  93. Pretty sure it will work...just curious...Fully Built H23 Head on H22 Block
  94. power window motor
  95. Speedo and Rev counter problems on a '93 Vtech
  96. Turning on signals?
  97. lude wont start
  98. why doesn't my intermediate shaft fit???
  99. 5th gen swap questions
  100. fog lights
  101. Alternative Starter?
  102. Need help with h22 bearings
  103. Do not buy from Shutta
  104. saw this on youtube help out poor guy
  105. jdm harness with usdm motor
  106. new engine prime oil pump?
  107. H22 wiring harness
  108. Cost of shipping a complete H22 ?
  109. h22 block problem. any help is appreciated
  110. exhaust smoke issue
  111. F series block H series head?
  112. 97 auto tranny
  113. misses when warmed up
  114. HELP: Oil leak from Disturbitor or around
  115. Just got oil pressure gauge wired up, but
  116. 5th gen rear brakes suck.
  117. clock and only dash speakers dont work
  118. teflon coated sleeves????
  119. Type r rim question
  120. Need advice on how to get 250+ from an all motor h22a4
  121. jr supercharger bottom maini
  122. 5th Gen: Custom rate springs on DD
  123. Thermostat: H22 vs F22/H23
  124. Megan header w/2.5 collector or Prospeed header?
  125. Complete car wiring question
  126. DIY: Diagnose Check Engine Lights 4th gen Prelude
  127. wastegate
  128. H22 pistons question
  129. Problems with H22 race header into 4th gen
  130. What would you do!?
  131. is there any A/C Write ups out there?
  132. Brakes. Helpp
  133. climate control issue
  134. F20b
  135. 4th gen Prelude.
  136. motor
  137. 4th Gen 1 Piece Headlight Ajustments.
  138. F22 B2 SOHC into a 1993 prelude what do i need?
  139. Exhaust Compatible
  140. 4ws?
  141. ***New lude...Is it worth it?****
  142. what broke. 4th gen
  143. Power Steering Pump
  144. B20A5 Boosted
  145. Pic request/help: ignition coil harness connector
  146. Straight Pipes
  147. f22 head on a h23 block
  148. Prelude2Perfect's 500+fwhp BB6
  149. A few questions.
  150. obd1 h22A into obd2 lude
  151. getting cams
  152. Best type of fuel for your Prelude
  153. Flexpipe & Bushings
  154. New Atl. Region SCCA Schedule
  155. Help!crazy engine issue after motor replacement
  156. 4th gen Coolant Temperature sensor
  157. power from exhaust?
  158. slight missfire?
  159. What is a fair price for my 2001 SH?
  160. 1998 supercharged prelude how much
  161. Motor mounts
  162. starting problem on prelude
  163. What Have you done to your Prelude today?
  164. Balance Shafts
  165. Motorweek 1993 Prelude Vtec tested video!!!
  166. Possible to short out the under dash relay box?
  167. Customizing inside of trunk
  168. Oil cooler oil leak
  169. Mix and match Prelude?
  170. 5th Gen Rear Lower Ball Joint
  171. irratic surge idle
  172. quick question
  173. I need help !!!!!!!!!!!!!!!
  174. any trick to get h22 tranny case back on ?
  175. need some help
  176. oil light problems
  177. problem with starting the car help
  178. H22A and H22a1 heads the same?
  179. Spark plug explode
  180. weather striping??????
  181. Will a 28100 P15 A22 TCM work in my 1994 Lude S A/T
  182. no spark
  183. motor swap
  184. overheating
  185. Need motor mounts!
  186. H22 question
  187. va weather
  188. Idle problem with new motor?
  189. pls help!!
  190. Performance Radiator and Thermostat
  191. Speedometer not working
  192. S2 Blinking...?
  193. fuel filter?
  194. Need blueprints for a cake
  195. Oil fill on h23 manual transmission?
  196. Difference: Header:SH vs Non SH
  197. slave cylinder hose leaks when slave is compressed
  198. 5th gen 2001 Prelude abs code check?
  199. oil light issues
  200. i have a antifreeze leaking problem and need help
  201. 4th gen eyelids
  202. no speedo
  203. anyone going?
  204. got rust on the quarter panels
  205. Junta culata a colector escape
  206. H22 high idle sometime?!?!?
  207. Check Engine Light help?
  208. Need help! Driver door wont unlock properly
  209. Prelude will not start 82'
  210. Shifter and cable assembly
  211. need help with 97 prelude sh asap please
  212. safc and obd2
  213. Pic Request + question: Alternator relocation.
  214. EGR Valve Lift Insufficient Detected?
  215. How do i scan my 97 prelude?
  216. Distributor question!!
  217. White clear smoke?
  218. idle at REDLINE LS into ek
  219. need help, broke my egr valve
  220. H22 SH LSD trans on F22B
  221. bad fuel pump?
  222. short shifter
  223. Projector Retro Fit
  224. valve seals
  225. H22 Ignition problems..
  226. Trick out trunk
  227. i need help with my 96 Honda Prelude...
  228. 97 Prelude primary heated o2 plug location?
  229. 1994 Lude where is the TCU?????
  230. ECT sensor on hondaautomotiveparts.com
  231. Throttle Body spacer?
  232. auto tensioner bracket
  233. Only one Driveshaft Spinning
  234. ticking noise
  235. 1990 Prelude Question
  236. spark plugs
  237. Looking to buy a 2000 Honda Prelude
  238. jdm h22 wont start
  239. H22 parts for sale
  240. Car Will Crank and Turn On, but When Key is let go Dead.
  241. 4" exhaust anyone?
  242. park, tail, and dash lights are not working on Fifth gen prelude
  243. quick tranny question
  244. h23 vtec vs h22
  245. why does my car sit so high after putting on brand new shocks
  246. wtf is up with this crank?
  247. timing belt cover
  248. jdm h22
  249. F20b swap in 93 pelude???
  250. my 92
