View Full Version : Honda Prelude
- Confused
- 225 R888's on Kosei k1's?
- A couple of issues... (Overheating plus)
- How to tell if your car is JDM Or USDM
- O2 sensor bad only at high RPM?
- alternator belt length
- Time for Timing belt change?
- P13 H22A Help!
- 1999 Prelude SH Radiator
- 900 original mile, 99 SH on ebay
- Lighter flywheel
- H22 guru's test your knowledge!
- 95 prelude cluster diagram
- Head gasket issues
- Crank Pulley - Need Help
- Exterior Window Seal Part Number
- where is the vss
- Vtec very loud but weak power??
- Dash Lights Dim
- JDM Type S camshaft on stock H22A1....?
- Help! P0172, P0302, P0170
- Tranny fluid leak
- h22a built loosely for nitrous
- F22B
- Failed smog check, need help
- H22: Build
- Change ECU
- clutch pedal all the way down 93 prelude..
- F22 Trans
- JDM H22a installed!! 1 problem though....
- my planned h22a build
- Skunk 2 Pro camshaft users
- Recommended oil for h22 w/ 225,xxx miles
- SUSPENSION QUESTION: Bump stops
- Bad electronic air control if car turns off when uplugged??
- tech question. h22 crank diffrence?
- H22A Automatic Timing Belt Tensioner
- oil pump???
- h22a various questions
- my clutch
- Should I be concerned?
- 97 prelude problems need help!!!!!!!
- Can a 5g oil pump work on a 4g?
- 1991 Prelude Project tips and help needed (im new)
- what size bulb do fog light use??
- Power steering belt issue
- H22A4 pistons fit f22a1
- Help Please evap code
- EGR control Solenoid H22A specific?
- Interesting Starter Question/Problem (Type SH w/M2A4)
- Ok, so what broke?
- just wondering
- Prelude Si, vtec is not engaging. need help!
- JDM H22 Swap:Is it worth it?
- 88 prelude wont start*please help**anyone!
- h23a's external ignition coil for JDM H22 swap
- s2p3 camshafts
- ..:: WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - October 2009
- ..::: FOR SALE ONLY :::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - October 2009
- rear wheel drive prelude
- 225/45R16 on Stock SH Wheels?
- Weirdest start up issue ever....help
- Tie Rod Bolt Spins!
- Oil Leak from My vtec solenoid....Help....
- Honda Prelude BB4 Japanese, noise from the back..
- Has anyone used KMS parts?
- what heads are these????
- Coolant Leak into Spark Plug Cylinder
- 2.5 Collector mod effects on Torque H23
- turbo for my preldue ??
- TURBO ON MY 2.0 ???????
- Help- drag racing set up on slicks?
- Erratic speedometer and apparent road trip
- 5th gen Honda Prelude Headlight adjustment
- JUN H22a parts
- JDM H22a tach not working!
- problem with h22 after timing belt install
- would 245/40/17 tires fit a 1999 prelude?
- Is there a difference between vtec soleniods.
- help prelude 92 !!!!
- lights are on the frittz!!
- Mud flap on preludes.
- Removing power steering question
- (Searched) Simple H23 to JDM H22 questions
- Clunking noise on right side of engine bay.
- RACK and pinion instal-can't seem to find DIY thread with diagram or anything
- need help bad, wat part is this??? plzzzz
- 4th gens without stock steering wheel?
- Quesation: My clutch wont disengauge
- torque converter???
- lights in dash out
- WIRE FIRE!!!!!! good trade or bad?
- Intake Manifold the same for years 94-01?
- +15 offset?
- Headlight problem related to igntion switch
- cold air intake install help
- Does it Work?
- Reading my CEL code - Misreading it
- ? About Crank pulley problem on a H22
- 91 prelude help!
- h23 head on h22a4 block or matching?
- Got a ? for you prelude guys......
- Airbag compatibility (searched)
- (#2)How much Boost can a stock H22 handle??
- A/ET Series Adjustible Cam Gear
- Seats?
- Suspension choice??? Which to use, help HT :)
- K series Preludes?
- suspension upgrade
- Starter/Electrical Issues
- eletrical problem??
- How much Boost can a stock H22 handle??
- Wiring Diagram
- 99 h22a4 swap into my 92 prelude
- How much would you pay for this 1998 Prelude 5spd, w/61k miles?
- honda prelude bb1 problems
- A/F ratio (autometer)
- anybody ever gutted a 5thgen? post up
- My Project Prelude
- Is this a Euro R Intake Manifold?
- Anybody converted a 5th gen lude from
- I need help with installing O-NEX hidkit BB6
- Neuspeed Springs BB1-BB6
- how do i use the memory button on my seat
- How to get engine rpm higher
- Wiper & Headlight issue
- Need Insight On This Turbo Kit
- Need Help 1990 Prelude
- Rear Motor Mount
- need to know wats wrong wit my h22?
- balance shaft...
- New to Honda and site
- Turbo-ing my b20a5 with e85, Have a few ???s
- 97 Prelude Crank Pulley
- fiberglass fenders
- 97 prelude back seat dimensions? length and width
- Questions: Clutch issue & power issue.
- EDM rear fog for a '98
- Lip help.
- Vin numbers
- Project rebuild Vtec prelude
- cel 8 and 22
- Lowering Racing Spring or Coilover Kit.....???
- 99 H22 SWAP INTO 92 PRELUDE HELP..............
- h23vtec + ??? tranny
- any aftermarket strut bars for 89 prelude??
- JDM engine
- 1990 S Sunroof leaking
- 5 lug conversion on 4th gen lude....????
- f22b1 in 94 prelude S
- overheating problems!
- DC header with stock collector?
- Control Arms?
- Accord shocks on my Lude
- Transmission talk
- Exhaust form Civic Si 06-09
- h23 to h22 problems
- 90 4ws aftermarket
- Chassis Codes Query....
- hondata s300
- what would cause oil inside intake manifold
- 4 inch exhaust
- h22 manual tensioner adjustment.. HOW?
- help needed asap
- je pistons got melted
- H22 swap into my accord ISSUES
- 1993 Prelude S, Hesitation Problems
- toughts on Aerospeed muffler on a 5th gen
- rings and bearings
- New tranny or old? Need your opinion
- Prelude turbo adding, any ideas, need info
- 92 prelude misfire....
- ABS Removal
- another car won't start thread...lol...
- Problems after intake EURO R manifold install
- Strange oil light problem...
- What do you think of this boosted Prelude?
- 4th Gen Tach not working (JDM H22a)
- Battery light and E-brake light on.
- I WANT 2 BOOST MY LUDE- SC or Turbo??
- HELP 97 PRELUDE INJECTORS NOT FIRING/no start
- Prelude Gearbox options
- clutch line/ joint clutch hose
- Dry Sleeves In h22a1?
- auto tensioner quick question hel
- Password JDM Intake for BB4
- ITB thoughts?
- is anyone running the BF Goodrich G-forces
- vtec problems
- Rear upper ball joints?
- JDM H22a Thermoswitch question...
- Honda Prelude Crank Pulley....
- need help
- Rpm adjusting
- irratic idle on h22
- Strut topmounts interchangable?
- help with spark plug
- Prelude engine swap
- SH/Base wiring harness??
- shifting problems
- need help with my h22
- Throttle Body
- prelude project
- strange problem...at least to me
- Can anyone identify this?
- how to remove the turn signal switch
- H22 oil pan baffling design
- New to Jap cars
- 89 Lude wit a bad fan i think???
- Guess the issue game!
- JDM H22a - need advice on how to get more rev and hp
- Need help diagnosing engine noise....
- KYB AGX vs Skunk 2
- Back from the Dead Build
- Help Needed.
- Car wont start strange things are a foot
- Steering wheel...
- Idle/start issues hunting rpm
- Auto tranny going out?
- VSS problem, seized gear?
- Need Catback Exhaust Any Ideas
- H22 block work questions...uhg.
- How much for my h22a4?
- throttle and idle issue help plz
- 99 prelude won't rev past 6500 after spark plug change
- Left front wheel is humminng at 50-65mph.
- F20B Cams n H22 head
- Competition Clutch- Series 2300...over all experience
- H22 Engine, H23 Trans, not moving??
- 95 srv has no power electrically
- i want to swap in an H22a1 in my 00 civic, would like you guys opinion on this.
- Air/fuel ratio guageinstall
- Preludes and theft
- Oil Light In Turns (ATTS?)
- F22 from 94 prelude
- Forbidden SS
- bb1 vtec issue
- Top to bottom rebuild results in a troubling noise...
- 5th Gen Plate Relocation
- Componet test, HELP HT gurus
- H22a SWAP ** SHORT THROW SHIFTER, HELP!!!!!!
- H22/F23- which holes in the head shoul be blocked?
- speed sensor help
- N/A plans for h22a1 advices
- H series oil pumps....
- need prelude pics
- H22/H23 hybrid problems, died and won't start up anymore.
- "phantom car" Prelude Type R
- Manual Transmission Service Question
- Fuel pump/filter are ok, but FI is intermittent!!!
