PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. h22a4 engine block water jacket
  2. Driver's door won't lock/unlock w/ keyless
  3. External ATTS cooler
  4. H22a4 Forced Induction Build Built To Kill
  5. h22a4 turbo build?
  6. Stuttering when engine is at a steady RPM.
  7. 1980 maroon prelude
  8. The lude is jerking
  9. anyone ever run 60 sidewall tires on stock 4th gen si-v rims ?
  10. No oil after rebuild engine
  11. 1982 Honda Prelude resto
  12. s300 with innovative mtx L
  13. '92 honda prelude problems and questions
  14. Question regarding boosting h22
  15. 98 Prelude Seats
  16. 90 Prelude stalls while idling
  17. 97 prelude problems HELP!
  18. 5th gen overheat and now no heat.
  19. engine failure while driving
  20. H22a prelude misfire?
  21. Igintion lock cylinder
  22. Mid-Engine RWD V6 5th Gen Prelude
  23. 1999 prelude engine swap
  24. 97 Honda Prelude, starts but won't crank.
  25. Honda Prelude 2001 Fule Tank Pressue Sensor
  26. H22 motor build
  27. axle length
  28. IIIgen 2.0 AT - problem with gearbox
  29. HELP! Car does not start.
  30. where can i find a spoiler?? (:
  31. Rear engine mount bracket
  32. NeedHelp getting 96 lude running..
  33. rpms bounce and engine stall while driving?
  34. 3rd Gen H22a/b20b
  35. Egr code and it shuts down
  36. Egr code and it shuts down
  37. How bad is the rust on this car?
  38. Do Preludes still get stolen?
  39. Are these prelude wheels?
  40. J swap prelude
  41. i ave h23a vtec engine in my honda prelude , i have tdc code so how to clear tat code
  42. Euro R swap w/LSD into 97 SH
  43. floor board vibration at take off
  44. H22 Oil Cooler Removal
  45. 99 Prelude Radiator Mount
  46. torque value for oil cooler bolt
  47. 2001 Honda Prelude SH Head torque and sequednce
  48. I cant seem to find the right spark plug coils for my H23A
  49. Help me !
  50. head swap
  51. JDM h22 Type-SH swap. Bad gas mileage.
  52. huytuankm@gmail.com
  53. Rear Ball Joints
  54. H22 whining while accelerating and loss of power
  55. 89 prelude si aws suspension swap
  56. Blue top?
  57. Best way to loosen power steering lines from steering rack?
  58. Honda Prelude 2001 base automatic Questions
  59. 1989 Prelude cranks properly but ignition will not fire when car is hot from sun
  60. NEED A TECH HELP
  61. Overheated today.
  62. Honda Prelude 1994
  63. H22 tensioner assembly bolt broke!
  64. Compatible Rear 6x9 Speakers?
  65. 88 prelude manual transmission weight??
  66. 5th Gen Adjustable Camber Kits
  67. 98 Prelude stalls
  68. 5th gen Fuel issues
  69. flywheel bolts
  70. Richard
  71. 1990 Honda prelude si
  72. 5th Gen Front End Noise!
  73. Just bought a prelude
  74. prelude 5th Gen intercooler piping
  75. Obd2 knock sensor chip & tune???
  76. temp gauge jumping
  77. 91 Lude ignition switch and main relay delete.
  78. 5th gen subframe swap onto 4th gen
  79. Wire Harness Help
  80. 4th Gen JDM headlight conversion
  81. 96 prelude
  82. Dash Fuse Keeps Blowing
  83. torque transfer??
  84. New To Honda Car
  85. 1997 Base EGP Flip project
  86. motor swap issues
  87. h22a euro r
  88. vin number GB3-1147729
  89. 1985 Honda Prelude
  90. Prelude simulator
  91. H23 question
  92. honda accord
  93. engine swap or manual tranny conversion?
  94. Please help me identify this H22a harness plug. Where does it go?
  95. 35 shot of nitrous on a 250k motor?
  96. H22 4-1 header. Custom spec'd
  97. Can I drop the header and downpipe as one unit?
  98. Rare jdm climate
  99. 99 lude swap
  100. watts of head lights
  101. 1993 Prelude Si H23A Radiator Fan Issue
  102. Revs hanging on 5th gen.
  103. 94 prelude si h23a1 To F22b1 to h22A Swap
  104. Stolen car. :(
  105. 97 Prelude intermittent D4 light
  106. 95 prelude soft grinding even in neutral
  107. Driver door window working sporadically
  108. prelude transmission
  109. Car turns off while driving
  110. Just got a 2000 prelude, has jdm h22a, needs throttle body...
  111. H22 header on f20b?
  112. seat belt warranty
  113. 1997 Prelude 2.2 liter V-Tech H22A4 eng
  114. 98 Honda prelude
  115. Prelude BB8 digital touch screen AC control
  116. f22b1 to h23a vtec swap
  117. H22a manual
  118. 5th Gen Steering Rack Problem
  119. Need help getting a prelude moving
  120. Heater blows no air and almost sounds like fan hits something when I turn the fan all
  121. Manual swapping a 98 prelude
  122. Speedo Reading Around 2mph Fast. 5th gen.
  123. Will The Value of 5th Gen Ludes Increase in years to come?
  124. Help? Euro r H22a
  125. Burning oil, other issues. 2000 Base
  126. can i swap a e22b
  127. F20b piston and rod compatibility
  128. Euro r with pcd 5th gen prelude swap
  129. i need a ECU for my h22a Auto swap
  130. '01 SH to Euro R or Type S Checklist
  131. Advice - to repair, sell, ditch, set on fire, etc. etc.
  132. 01 Prelude H22A4 Timing Belt Noise
  133. 99 prelude obd1 7 flashes
  134. 1999 honda prelude h23a problems
  135. Obd1 to 2 conversion
  136. Detonation and pinging h22a
  137. F23A 4th Gen Prelude Turbo Build
  138. Misfire at idle when cold
  139. 97 Prelude SH Engine Swap
  140. CPS plate.
  141. Bad ignition switch?
  142. Honda prelude 98 h22
  143. Cranks but won't start unless push started
  144. Honda Prelude Lsd question
  145. 98 h22 issue
  146. 94 Prelude Map Sensor Test
  147. spark plug tubes with oil
  148. Bearing Brand recommendations for an H22A4
  149. Honda Prelude BA41 and BA42 for sale in Switzerland
  150. 94 H22 totaled
  151. 92 Prelude Euro R F20B(SiR) Running Rich
  152. Boost intake manifold without changing hoses?
  153. Honda prelude 5 gen, AWD(RWD)
  154. 5th gen prelude automatic to automatic swap
  155. Where can i shop for JDM swapped parts
  156. 98 Prelude - no vtec, redline 6500rpm
  157. Is there a updated?
  158. Car was damaged, salvage or sell?
  159. Prelude 5th gen f20c rwd
  160. Which trunk spoiler is this? 97 Prelude
  161. 5th gen Prelude Power Door Lock!
  162. Strange noise from timing belt side
  163. AC & Fans + Hondata S300
  164. only starts when push started (may not be starter or battery)
  165. H23 Blue Top timing issue
  166. IMMO help
  167. F20b swap into 01 SH won't start!
  168. '98 JDM Swap Misfire Help
  169. JDM H22A Swap Help
  170. H22a4 has fuel, no spark!!!
  171. Will the Atts light affect smog?
  172. 3g drag record without motor swap :)
  173. Idle problem obd2 to obd1
  174. Anyone with coilover install experience on preludes?
  175. Need EGR Solenoid Valve '89 2.0 Si 4WS
  176. CEL 12 1989 4WS
  177. injector's dawg
  178. 4th gen transmission on 5th gen
  179. Iab circuit in ecu keeps burning up.
  180. 5th Gen Turn Signal Flasher Fix
  181. 97 PRELUDE LOW OIL PRESSURE LIGHT "BLINKS"
  182. 98 Prelude with P5M and immobilizer question
  183. Need Advice on a 91 si
  184. Broken drive belt while driving.
  185. Prelude SH F20b swap.
  186. 95 prelude engine swap
  187. need help with starting 98 Prelude
  188. Need help with parts for '85 prelude!!
  189. 91Euro R (CL1) into94 BA8 (F22b).
  190. urgent help needed 89 prelude rear control arm
  191. 1995 prelude sun roof removal
  192. REBUILDING THE LUDE FOR BOOST
  193. Cannot find Jun cam gears torque specs. ANYWHERE!
  194. 98 Prelude OBD2 to OBD1 Question!
  195. H22a Help.
  196. Fuel and temp gauge erratic
  197. fastest stock block f20b prelude?
  198. Idle issue someone please help im lost
  199. Prelude Fuel Pump Relay
  200. H22a4 block prep
  201. F20B starting issue
  202. 2001 BB6 Battery & Brake light problem.?!help
  203. Starter and flywheel issue!! Broken flywheel?
  204. Milled head please help
  205. h22 euro r questions
  206. turbo prelude re build
  207. CAN I POST A QUESTION I HAVE HERE
  208. First time Honda motor owner , trying to replace oil pan please help
  209. TURBO PRELUDE NEED HELP
  210. 2001 Prelude - SRS Troubleshoot (Reset/fix)
  211. " CEL 6 " H23a1 prelude 95
  212. Prelude F20B Help
  213. euro r cam suggestions
  214. Please HELP me with my 1992 Prelude Si
  215. h23a dohc vtec head on h23a1 block
  216. 1998 Prelude h22 Auto to 5 Speed question!
  217. 99 Prelude SRS clutch replacement - parts & tools req'd? (which kit?)
  218. Aftermarket cheap header/downpipe
  219. h22 motor in. My 92 prelude
  220. Need help with flashing CEL in 5th gen
  221. JDM H22A engine balance belt seized and stripped causing engine failure
  222. Replaced front upper ball joints in 5th gen
  223. h22 sh atts
  224. what are these...?
  225. Help!!!
  226. 97-01 Prelude top hats issue
  227. Which years does this Sebring cat back fit?
  228. Excessive Vibration and Steering Wheel Wobble at High RPM (93 VTEC 5spd)
  229. 97 Prelude exhaust
  230. HELP! Supercharger whine in 4th gear only!
  231. Won't crank, click or anything when trying to start
  232. Tubular A-arm available for prelude
  233. H22A4 Specifications and Calculations
  234. Stumped! 4th Gen No Start!
  235. How to know if 2001 Prelude has keyless entry
  236. 90 honda prelude help
  237. Car wont start issues 97 SH
  238. Check engine light flashing
  239. Can you identify this H series motor?
  240. Burning through ignition control modules
  241. 99 Civic with H22A A/C idle issues
  242. H23a vtec swap
  243. 3rd gen prelude ecu fuse38 keeps popping
  244. Got a oil leak.
  245. Parts compatibility between 84 and 89 Prelude
  246. h23a non vtec swap
  247. Stereo and Alarm Issue
  248. ATTS light
  249. What parts should i replace befor installing motor?
  250. Newbe looking 4 h23a motor pull write up.
