PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 [172] 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. neuspeed springs on a 97 prelude
  2. what do i need for a 5 lug conversion on a 93 Prelude
  3. My compression Test on a JDM H22A
  4. Dif. between reg. H22 and Long Block H22
  5. manual conversion/engine upgrades, WHICH FIRST?!
  6. drag ic piping question
  7. is a KAAZ lsd a good lds i want to turbo my h22 and put the power to the wheels
  8. removing OEM headbolts....
  9. bringing the 5th gen back to life after 2 YEARS - advice?
  10. removing tps
  11. Electromotive tec2 For Sale for H22
  12. K24 swap in a prelude?
  13. h 22 a problems
  14. 1995 Prelude Vtec Dyno results (pics+vid)
  15. H23a vs. H23a1?? searched!
  16. Piston Geometry/CR
  17. Endyn H22 Bump Stix Cams
  18. JDM Engines
  19. how to pry out driver's side axle from intermediate shaft? (92 prelude)
  20. Battery is all drained by LED alarm light??
  21. ABS code 12 help please
  22. Thrust Washers?
  23. Need some help
  24. Check engine code question.
  25. Rare Problem for 5th gen?
  26. Steering Seems to give out SEARCHED EVERYTHING
  27. How would tdo4 turbo perform on h22?
  28. 4th gen prelude sunroof
  29. Video of seafoam on a 1994 prelude with 79k miles
  30. autocross wheel size
  31. need info on AIRMASS header!
  32. So sorry to beat this to death, but balance shaft belt removal alone?
  33. New Setup: N/A - 97 Civic - G23 VTEC
  34. J's Intake(will it fit?)
  35. Osaka JDM Motors
  36. second gen. prelude
  37. vtec and redline
  38. Symptoms of Running Rich & Yes I searched
  39. exhaust size vs power
  40. custom exhaust piping
  41. does 5th gen fuel pump work on a 4th gen???
  42. Oem Lip Kit
  43. Random Misfires: Is it because of my injectors?!
  44. So the lude is gone!
  45. Idle problem need help asap
  46. Blowers?
  47. Ebay cold air intake
  48. Exhaust Gaskets
  49. VAFC
  50. Damn wheel stud
  51. Catalytic Converter Question
  52. $1000 ON THE LINE
  53. where to mount MSD box??
  54. Removing front license plate holder from 4th Gen??
  55. a/c idling problem
  56. JDM Leather Seats - How to install the power options
  57. jdm h22 overheat
  58. H22B? Does it really exist
  59. maybe tps?
  60. missing after engine warm up. Help!!!!!!!!!!
  61. any idea what brand this is?
  62. Coming to Miami FL
  63. ignitior test??
  64. Can I drive without the 4WS ECU?
  65. Head Port & Polish
  66. h 22 a ?
  67. Check engine light!
  68. Dallas/Ft.Worth junkyards
  69. how do I keep my antenna on my 4th gen from lowering every time I stop?
  70. 4th gen side markers (SEARCHED)
  71. Need the part number for the front brake sliding pin boots, pic inside
  72. Can't find offset calculation site again
  73. price for an engine swap....
  74. JSRC Question
  75. HELP!! NEED MANUAL!! 1995 Honda Prelude VTEC
  76. How to get contact info for member?
  77. Which engine is best?
  78. Just wanted to share some info about European 5gen Prelude
  79. cluth problem... i wont grab..help!!!
  80. 5th gen tail light (driver's side)
  81. wierd problem with car
  82. Pspec & Lean Racing
  83. Mahle Gold series piston
  84. Twin Turbo Applications - quick question
  85. molded front bumper..
  86. Power for my lude
  87. 1992 Prelude hose question/help?
  88. 91 'LUDE SWAPS, ARE THER ANY
  89. Dope Kits for 4th gen prelude....
  90. MAP sensor help/experience??
  91. Anyone acutally using H22 Pistons with an H23 Head ???
  92. Exhaust uninstall help needed
  93. TESTING-H2O: My 92 prelude for sale
  94. Killed my SECOND prelude in less then 6 monthes! Whaaaaaaa.....
  95. my alignment's Annoying! camber kit time perhaps, suggestions?
  96. white gauges...pain in the butt to install?
  97. whats the best headers for my h22 its in a 96 coupe
  98. JRSC Belt slip at high rpms.
  99. What do you think my Prelude is worth - owner to owner
  100. wierd temp. switch issues
  101. timing problem
  102. 4th Gem H22 Swap
  103. help wanted
  104. Transmission issue HELP
  105. header, exhaust & cat converter question
  106. High mile prelude, worth the buy?
  107. did i break it?
  108. activated car alarm
  109. Sticky Icky Tires
  110. 1997 PRELUDE OVERHEATING after 10 minutes of driving/idling?? Changed Thermostat. Could it be a blow
  111. H23 Rod measurements/sizes
  112. turbocharged h23 Vtec - worth the effort?
  113. 5spd auto trannys generic swap
  114. h23 tubro or h23 vtec or h22 ??
  115. questions about a aem ems ECU # 30-1010
  116. AT Control Unit
  117. i hate the gauges in my prelude its a 92 can you take the ones from a new prelude like 97 and up
  118. '90 Si, battery draining...
  119. Help on identifying H22 itermediate shaft from Accord intermed. shaft
  120. Anyone running Mugen header on their cars? Help me out plz!
  121. how much clearance do you need to turbo a h22 and aslo a ecu questions
  122. 1994 VTEC Prelude ECU Upgrades
  123. koni yellows and h&r springs
  124. ATTS SH Clutch??????
  125. Common long term problems on 97-01 lude
  126. Please Help
  127. prelude header question
  128. Rust... fixing
  129. <<power steering diagram
  130. obd 2 to obd 1 conversion
  131. ECU...What to do
  132. New header for H23 engines?
  133. Decided on an e-manage, have a few more questions
  134. Quick Question: Fuel Rails
  135. JDM Climate Control install
  136. To tune or not to???
  137. what should i do??
  138. h22 manual tensioner question.. Please help!!
  139. NEED 92-96 Lower Header Exhaust to Cat Pipe - VTEC
  140. cleaning the pistons
  141. head gasket question
  142. Suspension Q's(need pics)
  143. H-23 boosting question???
  144. Somebody Please Help Me!!
  145. i need opinions on exhausts please
  146. shocks/struts prelude BASE vs. type SH...
  147. Cat. Converter Help
  148. h22 ceramic header repair
  149. Can I convert an 88 2.0S to fuel injection at a reasonable cost?
  150. parts replacement....
  151. Prelude fog lamps, 4th. gen
  152. Windshield/rear window questions...need directions
  153. Lowering that feels close to stock when you drive?
  154. Anything else I need to do a 5 lug conversion???
  155. Belt size for AEM Alternator Power Pulley?
  156. just wondering prices for some parts.
  157. balancing the weight
  158. upgrading injectors
  159. 5 spd auto conversion
  160. Boosting With Mahle
  161. what kind of transmission fluid do people use?
  162. p13-a10 what year??
  163. supercharged prelude
  164. h23 crank in h22 block, possible?
  165. skunk2 coilovers questions
  166. help with honda stereo
  167. Balance Shaft Delete Kit?
  168. 99 Prelude Type SH
  169. Special Tool rod bolt adjustment gauge!
  170. Cosmetics
  171. has anybody had this happen to them
  172. Extra holes for buttons?
  173. 89 Prelude coversion to a 96-00 civic hatch?? help plz!!!
  174. 1993 prelude crank bearing help
  175. horn problem
  176. Prelude Slave Cylinder ....
  177. Type S piston???
  178. smoke coming out my a$$
  179. Loose timing belt?
  180. exedy stage 3 or 4 clutch on 5th gen lude
  181. Prelude leaking oil need help
  182. cost of cooling fan fuse in fuse box
  183. >> Coilovers - need your advice please ....
  184. Hondata s200 Base Map for Turbo???
  185. JDM H23A VTEC Blue Top with Type-S SiR S-spec Pistons Compression Ratio
  186. Broken water pump = possible head damage
  187. HELP! H22/H23 manual tensioner swap not available
  188. ***how hot does your h22 get?***
  189. 5th Gen Electrical Sound.....
  190. Removing stock headunit
  191. Fuel Supply System
  192. where is the water temp sensor?
  193. How the hell can you get this FAT lip on a lude????
  194. Whats the name of the small socket in the 5th gen headlights?
  195. F22 Turbo Questions > NEED ADVICE@!!!!
  196. hit rock, common bending/breaking parts?
  197. jdm ecu's usdm ecu's how can you tell the difference?
  198. F22 throttle body. H22?
  199. People have been telling me that you can't really mod the VTEC engine on the prelude
  200. Can I please get sum specs???!!
  201. h22a overheating?
  202. Stripped bolt options
  203. searched - tranny code and specs...
  204. Need simple question answered about JDM sidemarkers.
  205. suspension
  206. H22A Cly. Head Torque Specs?
  207. Compression : Problems Ratio
  208. CEL update
  209. intermediate shaft
  210. Rear suspension bolt help
  211. Trouble Starting '94 Prelude...
  212. Help IDing my H22A
  213. e brake handle
  214. water temperature sensor
  215. gaining that extra HP
  216. h22 cylinder head to f22 block
  217. 93 prelude
  218. Pic Request jdm prelude spoiler
  219. All motor H22A BB6, pros and cons
  220. Lug pattern on Prelude
  221. sorry bout this? i think u guyz coverd this but jus wanted to make sure...
  222. light flywheel on boosted h22
  223. i have some questions about my h22 swap
  224. Prelude Circle Track Racing Tips?
  225. JDM H22 Header Choice? Need Help Please!
  226. will the h23 motor mounts fit my h22a4 help
  227. Kamikaze Headers Or Dc Headers
  228. Quick Question
  229. 4th gen speakers question (searched)
  230. Parts Help??
  231. lets see that suspension
  232. Pic Request- H22 Bleeder Vavle. Please help!!
  233. Another no start thread...
  234. What the hell does this harness plug into?
  235. Still noise coming from front passanger side wheel after new bearings!!!
  236. Carter Problem or something
  237. Error with JDM Gathers CD Player ("E-02")
  238. Tein S Tech Springs
  239. '86 Auto.Trans. Lifetime Question
  240. NUMBERS UNDER THE ENGINE CODE?????????
  241. Possible leak?
  242. Just bought an '89 Prelude Si, have questions
  243. h22 rod bolts?
  244. what plug is this?
  245. which one is better? 01 base model lude or a 01 type sh?
  246. No Spark
  247. How to change rear brake shoes on Civic DX 2001?
  248. Jumper plug in H23A Prelude 93
  249. Fix head gasket problem
  250. BIG Problems.....Tranny
