View Full Version : Honda Prelude
- installing s2k seats on a 5th gen lude!!!
- Tried to tint my gauges
- Hondata s300 on 98SH
- Parking Brake Adjustement - How To EASY way 94 - 96
- tune up
- Will these rims fit on a prelude
- wierd car dieing problem
- lost my car key
- maintenance
- euro style tail lights
- i need a glove box lid
- questions prelude
- JDM H22A gurus look inside different years different rods??? Picture!
- instantly code 22
- how many lb are a stock prelude flywheel 92-96
- crankshaft pulley
- 5th gen yellow foglight question...it has been searched
- new brake pads >>--> is that normal?
- Vtec help
- 4gen speaker help
- low rpm?
- Need Picture of PIN Layout for H22 ECU
- driveshaft shop axles
- E-Ram Electric supercharger????
- 92-96 prelude need help with high beam bulbs
- 96 vtir ecu reset
- "check this out" 96' honda prelude distributor..."NEED HELP"
- Top Speed?
- axle broke off in intermediate shaft(pics) Cant get it out! Need Ideas!
- fluidyne radiator and hondata s300 on SH
- how do i figure out whats wrong with my foglights?
- help getting axle out of intermediate shaft, 5th gen
- TB gasket ?
- Smoke from vtec ?
- Main Relay? bb6
- Car will not start
- Stock Door speakers
- Misshap with resistor box wiring (97 boosted prelude)
- Underground Racing Camshaft h22
- hub bearing bad again, ideas why?
- 4th gen floor mats?
- tranny leak - doesn't stop!
- forced induction on a h22a7
- JDM H22 Radiator fan timer
- Bad TPS on my JDM H22A
- Motor swap for my Prelude?
- drag racing breaks a distributor?
- Stupid question...
- Possible new purchase (89 Prelude Si) Stalling, hard starts
- deleting the knock sensor from my p13??
- Prelude Check engine, ATTS light no, Spedo doesn't work
- Jdm Headlights (92 lude)
- bumper damage
- driving with a slightly warped/bubbled tire. Can it make my brake pads uneven, ruin my suspension?
- EL Gauge Cluster: Blinker Problem
- jdm h22a distributor
- big problem with rpm's help!!
- tuning in nj?
- Greddy timing belt or OEM
- JRSC fitment question....
- Prelude Gauges Burned Out
- 3rd gen steering wheel on 4th gen?
- timing belt walking off after manual tensioner swap
- 8-4-06: The day I have seen it ALL!!! LS1/RWD Prelude!
- Under drive pulley
- Will ATTS work without electronic control?
- Oil Leak!
- Part Number & Picture
- Distributor wiring?
- H22 distributor going bad?
- 2000 h22a4 w/ 96 ecu - different fuel injector types, is this why I'm running rich?
- Where to buy 93 Repair Manual, real book, not pdf/cd.
- got some problem with jdm h23a vtec swap
- koni/neuspeed race
- blown up h23
- overheating... new rad and theromo.
- My transmission won't go in reverse
- transmission teardown..
- i just install a blockguard in my h22 do i still use the same headgasket
- are the h22 and the h23 distributor the same
- are h23 and h22 flywheel the same
- 1st and 2nd gear locked up in transmission overnight?
- Anyone squeezed 225/35/18 or 225/40/18 on their 5th gen?
- Changed the Timing Belt...Now a Squeal
- Fluidyne Radiator Install
- vtec doesn't engage in first gear, other weird things...
- noob question
- 91 swaps
- GSR ecu in a Prelude?
- Big Electrical issues once again.. cigarette lighter ground
- Prelude with Jun p73 ecu?
- rs-r ex-mag
- engine light & ATTS
- removing power stearing
- Stripped bolts!!
- Rear Wheel bearing 98lude 130KM
- HP4 H22A engine overheating
- b16/b18 higt comp pistons in b20a ?
- SH front coilover install ?
- noob question. 89 lude
- changing oil pump 5gen
- What are the stock sway bar sizes on 97-01 SH prelude?
- clutch install tips
- just got another h23 from hmotors
- ***turbos***
- 215/45/16 on stock 5th gen rims?
- how i know the # of sensor for my apexi
- Transmission Oil Change
- external coil to internal coil
- H23/H22 Swap or Not?
- Should I replace throttle body?
- Cat
- Samco Hoses
- Walbro Fuel Pump From b16 95 civic si Fit 95 VTEC Lude?
- Fuel Pump
- H22/H23 Gear Ratios
- NEW TEIN EDFC will it fit lude now?
- Just got another prelude
- velocity stack with aem or injen sri?
- After installed Ground Wire, motor oil light came on...Anyone help plz.
- A/C questions
- reccomends on a fitler
- possible to hook up horn w aftermarket hub and stuff
- what are these ment to be used for ??
- wideband o2
- will the 97-01 honda prelude manual ecu work on the 96 obd2 prelude?
- Need help guys 235/40R17 on 17 x 8 48mm offset 5th gen lude
- 92-96 jdm Honda prelude/TyPe R Integra....
- Unknown Suspension Noise (searched)
- timing belt question?
- New BB6 Owner, got a couple quick questions
- apexi N1- a few questions...
- testingwaters, What you think I should ask for my automobile?
- ??? DSM Injector install on h22 ???
- F22B parts?
- 4th gen prelude fuel circuit
- cracked bearing cap bridge? (block girdle?)
- spark plug replacement
- Need Some help with my 92 Lude
- Dyno plot of h22 vs type-S / f20b cams - turbo vehicle
- stock exhaust diam for 4th gen
- Sunroof stuck and doesn't work
- will a SH tranny with a base model?
- mounting external coil on H22 swap
- Front End Clicking! please help
- Wanna Drop your Lude?
- sterring wheel shakes at high speed
- jdm h22a cam issue ???????
- silly question I know but!
- How can i make this steering wheel work right?
- Losing HP, Injector resistor box or ECU??? help plzzz H22 Teg
- 5th Gear grind
- i need help prelude
- installing engine!
- coolant temp switch question
- are LSD axels different?
- Crazy blinking problem Need help
- Upping compression... *searched*
- Weird idle problem...help needed
- EGR block with jdm p72 obd1 and hondata s300
- Question about oil pan . . .
- Ksport Coilovers ?
- Coolant ?
- will 4th gen h22 prelude rear engine mount fit on 5th gen prelude?
- need help on changing my coolant
- a/c compressor
- H23 header on F22?
- gas consumption????
- h22a throwing code
- kb58's Mini feature in C16 - good read!!
- My 1/4 mile time
- sx fuel pressure regulator install/buy
- cruise control
- how to post pictures?
- f22/ h23
- MD driving laws - I think I've been harassed
- 92. BB3 H20A4 Prelude 2.0i Brakelight problem!
- stalling out while moving?
- 88mm h22 pistons??
- Need Help In Vegas
- cant find that topic, i searched too
- hey the OBX headers are good?
- pulley system
- Putting my KYB AGX shock and Tein S-Tech together, did i miss anything???
- how much should i sell my car for??
- Problem putting timing belt on, with an H22 cams won't align
- 89 si tranny problems
- h22 swap stuff
- 01 prelude misfire codes all 4 cyclinders
- Picture of IAB and wiring up vtec press and solenoid and vac house (h22a swap)
- what part is this?
- Close Ratio Gears for H22
- idle problems? car revs then drops? coil boot caught on fire last week!
- gears going in rough
- H22A4 long block for my 93 vtec chassic question
- i think i'm missing out..
- 95 Ignition... electronic problems...
- Which coilovers setup ?
- how much would you pay for a used Greddy SP2
- Chipped P28 H22a... no knock sensor?
- need help on ABS
- fuel pump question
- need help on 4th genparking brakes
- Gearbox mount problem (searched)
- help: car broke down
- msd install on 93 lude
- h22 engine using h23 tentioner stuff question
- can I use stock fpr with 11:1 cr?
- Rear tie bars worth anything?
- the parahana interior
- can I put regular drinking water in a battery or is distilled a must?
- Tranny Leak Help!
- clutch for H23
- General shop in Salt Lake City?
- Code 43, please help
- JDM H23A blue top transplant coming soon......
- help, need help with diagnosis
- tire size for my 4th gen
- does any one own short shift adapters
- stock h22 sleeves?
- How do u set timing on 95 lude?
- H23 Complete Rebuild(Turbo Ready)?
- h22a cutting out before limiter???
- nitrous VS an h22 with an 11:1 compression ratio
- DC sport headers.... did I get a good deal
- code 5; MAP sensor??
- miles on a full tank 5th gen?
- Is it possible to throw a dc2 or dc5 momo steering wheel in 4th gen prelude ?
- Thread Pitch for Rear calipers
- Flarenuts
- stck h22 injectors
- Greddy SP2 Exhaust, is it raspy?
- i have a OEM 6 cd changer in the back
- Crank Pulley came loose, now car won't start!!! Please HELP!!
- Engine whine after H22A swap and H23 manual tensioner conversion...
- crank pulley
- honing the duece duece
- neuspeed race for 4th and 5th spring rate different.
- Free White Diamond Pearl touch up paint
- 4WS Problems With yellow top?
- Prelude's iacv question???????
- my prelude is surging
- 94 Prelude H22A, what should be my stock fuel pressure?
- Need Help/link for Type s head swap
- Getting SKunk2 cam gears installed
- 1989 Prelude SI Power steering help
- 3 step hookup for hondata s300
- Brake Squeel
- want to buy 93 si climate control
- megan racing catback
