PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 [265] 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. TB question
  2. ok...simple n00b question here...
  3. Why do honda stop making new prelude?
  4. HELP!!!
  5. attention Prelude turbo builders
  6. Low compression pistons and check engine light???
  7. pics of the RudeLude
  8. OEM Intake Manifold
  9. JDM shift boot ??
  10. brake calipers
  11. Set of tires for winter...
  12. My first Post! Need info on Prelude and Prelude SH motors
  13. tranny swap
  14. Is the anything special I must do when installing my H&R Sports and Tokico HPs? BUMP STOPS??
  15. Invader side skirts for sale,97-01 Prelude
  16. How can I find out if my tranny is the one that came on the car from the factory??
  17. Installing my Neuspeed bar. Any tips??
  18. 3rd gen b21a1 swap to b20a5 is it a direct swap?
  19. need exhaust help
  20. some pics...
  21. Do 4th gen seats fit in 5th gens?
  22. hondata
  23. Sound System Question - Anyone have rattling problems from subs?
  24. Need some help
  25. do any one know Wiked935EK or his phone number IM missing my h23a1
  26. need help fast
  27. building internals... need more info
  28. what's the redline?
  29. Help me build an H22 (JDM)
  30. anyone want some 16" Rota Grids???
  31. new n' planning to swap h23 w/ h22a.. advice needed :)
  32. Buying a prelude tomorrow or monday...
  33. Which Exhaust to get?
  34. h23 n/a build with h22 pistons...
  35. New to the Scene
  36. MY GROUPBUY HORROR STORY!
  37. help
  38. Wheel Bearing Problems Please Help
  39. Headlight relay
  40. Replaced HO2S, reset ecu, still throwing CEL 1
  41. Those of you not running balance shafts!
  42. e-brake problem
  43. Theives strike again
  44. H23 Swap for V-TEC
  45. ecu location
  46. type s vs. stock jdm
  47. Brake light on cluster comes on in mornings...
  48. Oil question for h22a1's..........
  49. i've got appearance related questions....
  50. HELP PLEASE! ECU GETS NO POWER!
  51. Help! Car won't start after 2 months of storage
  52. JDM f22b DOHC Question
  53. SH, non SH?
  54. My brake is weird..?
  55. Hey I'm New!!!
  56. 6500 rev limit on boosted 97 prelude
  57. new rims question
  58. How long does a Fidanza Flywheel last?
  59. wheel bearings are bad!.....
  60. Need Some Torque Specs or a PDF Helms & Honing Question....
  61. Paintjob in North Carolina
  62. Never trust anyone with your prelude.
  63. What are good h22a compression test numbers?
  64. selling parts for h23
  65. burning oil
  66. Question on struts
  67. New H23A SFP manifold in the mail, detailed pix0rs inside...
  68. Obd II distributor needed
  69. removing front bumper?
  70. oil passage for middle main bearing...
  71. Anybody with Real Mugen Bumper cover
  72. Conflicting posts regarding oil squirts... keep `em or leave `em?
  73. H22 oil pan torque spec?
  74. suspention
  75. I need a prelude for a few hours
  76. Please tell me what this is worth....
  77. So I to learn about Turbos..
  78. JDM h22 motor questions
  79. got an alignment yeserday..
  80. a/c power loss...
  81. Stage 2 cam shaft
  82. H22 Engine noise - MP3 inside
  83. EMERGENCY HELP!!! Honda dealer shop...
  84. Difference between SH and Base Neuspeed springs?
  85. Just got my VAFC, if I install it and leave it alone before I get it dynoed.
  86. how did you get to the back of your stock head unit??
  87. got a turbo, wanting nitrous, good idea? which system should i get?
  88. Exhaust Question
  89. hesitation when redlining
  90. car running very hot any ideas?
  91. JDM valvesprings
  92. thinkin of parting her out.
  93. To hone or not to hone, that is the question. (h22a related)
  94. My Azenis just exploded!
  95. ------//> Cruise Control Switch causing HORN BUTTONS not to work.. why??
  96. Euro Accord Type R motor into a 92 Prelude S....
  97. mph gains
  98. Post your nextel 2ways
  99. checking if CEL is working
  100. Compression
  101. h22 injectors
  102. quaife LSD
  103. Just unplugged my oxygen sensor and went for a drive
  104. For the H22A peeps out there
  105. Need Help Fast - problems after '97 prelude timing belt install
  106. New CD player in 5th gen....no rear sound.HELP
  107. Cleaning Throttle Body
  108. Mugen Fan switch for 4th gen h22 prelude. Fitment issue?
  109. will jdm h23 intake manifold fit on usdm h23 head without modification?
  110. Turbo setup finally complete (lots of pics, 56k warning)
  111. quick aem question
  112. taking out power steering
  113. Stock rims
  114. help intercooler way to low!!!!!!!!
  115. H23 headwork
  116. Tranny Question
  117. H22 H23 VTECH QUESTION
  118. 94 prelude s exhaust inlet
  119. md inspection---please help!!!
  120. labor costs for installing new shock/struts?
  121. what engine came in the aws 4th gen preludes?
  122. H22 guys with H23 tensioners! Where did you get one?
  123. wheels/tires
  124. check engine light and atts light
  125. Selling the lude and turbo kit
  126. flywheel/clutch install problem
  127. h22a is acting up
  128. What size are JDM injectors?
  129. Noticing redline grind 2->3rd gear with this 10w-30 oil in my tranny....
  130. Bought a set of rims and tires
  131. I was shipped an extra F22/H23 crank scrapper by mistake... anyone?
  132. secondary fuel pump...electrical connection question
  133. can somone do me a favor?
  134. exhaust help
  135. Please tell me what you think!!!
  136. injector size for boosted 96 lude
  137. VAFC qusetion
  138. The best way to rebuild a stock h22a back to oem specifications?
  139. hey everyone tyranny problems
  140. planning to sleeve, bore ect.. need advice please help me out!!
  141. fiber tech cf hoods
  142. Prelude 5th Generation!?!
  143. Pistons..Sleeves..Boost...
  144. "special" 1993 v-tecs?
  145. bad compression
  146. Bad H22 autotensioners - WHY is this a problem?
  147. Exhaust scrape...
  148. need help...idk anything bout preludes
  149. Rotors
  150. Engine and Rims
  151. Anyone here have 5th Gear Synchro Problems???
  152. NEED tranny BAD.. HELP??!!!
  153. Wheels question 91CRX~90Lude
  154. Keyless Entry Question
  155. EFI PMS harness for 5th gen SH
  156. prelude stats needed
  157. HS, non HS?
  158. great... code 16-- fuel injector..
  159. what header...5th gen
  160. cat...??
  161. I NEED HELP GUYS!!! DOOR SCHEMATICS??? 4th gen
  162. prelude vtec brake swap
  163. CEL code
  164. Cd Player from 5th Gen Prelude..Work in my 4th Gen Prelude?
  165. What is this little gray box?
  166. prelude radiator
  167. what kind of problems do you notice when plugs go bad? I have a check engine on and it says im misf
  168. wtb: prelude front vents
  169. JDM vs USDM h22
  170. Another Header and V-AFC question (Kinda Long)
  171. Looking for a OBD 1 H22a ECU need asap like need it tomorrowSN
  172. Idle Learn Procedure...?
  173. Good Brand Transmission cooler?
  174. fitting a Distributor
  175. tire size
  176. Need pic: Top deck of H23a1
  177. Anyone have an Apex VTEC AFC?
  178. Clutch Problem
  179. n2o
  180. ferrea for H23
  181. My h22a Motor (Pics included soon)
  182. boring out cylinders for boost
  183. Which LSD is better?
  184. Help me find this oil leak before I go to the dealer :(
  185. what should compression be on an h23?
  186. Wheel question...
  187. engine cut off....
  188. I Have A Question!!!!!!!!!!!
  189. Need Prelude interior
  190. anyone know how to seperate the lense from the corner light?
  191. Anyone want a cheap prelude h23
  192. F/S: 2001 Electron Blue Prelude OEM Front Lip
  193. f22 shifting...
  194. Stoichmeter readings
  195. h22 str or venom intake mani where to find ASAP
  196. WTB: Honda Prelude 97+ in Orange County
  197. DC headers don't come with header gasket???
  198. Any interest in a cheap 93 Vtec?
  199. GS
  200. Best thing to do w/ $1400 on a 4th gen?
  201. Intake and Exhaust Questions
  202. Best Turbo app.
  203. Finding Exhaust leaks
  204. cleaning greddy SP?
  205. can u swap backseats from a 95 lude to a 92 lude?
  206. Prelude????
  207. Evap system question
  208. ECU fuse location?
  209. Aftermarket Clutch
  210. Best thing to get for $500 on a 5th gen
  211. Bad auto-tensioners also in 4G H22?
  212. PRICE DROPPED!!!! somone buy this damn turbo kit
  213. Can I reuse my aem pulley kit in my h22 swap?
  214. How to run headlights without fog lights on 5th gen
  215. Skunk2 Valve Springs and Retainers
  216. Potential fuel problem?
  217. VTEC wiring
  218. Basic modifications for 85 Prelude
  219. Quick trans ?
  220. need help with large buying list
  221. i need help w/ picking the best engine
  222. Nozzle lights?
  223. Spoon N1 with a DC b pipe...
  224. The ONLY thing KEEPING me from my getting my EXHAUST SYSTEM.....Experts NEEDED
  225. h22 engine swap, help.....
  226. Rotary
  227. help --> how to align rear balance shaft on h22a??
  228. 92 prelude h22a1 overheating!
  229. I HATE MY CAR.... AGAIN
  230. Fog light help!
  231. compression check #'s... soon to spray n2o Help PLEASE!
  232. HP question?
  233. Mechanical issues ... NEED HELP !!!!!!
  234. Disconnected my negative side of my battery....
  235. 87 Prelude
  236. Does the front licence plate have to be attached to the front bumber in Canada?
  237. Anyone running an t3/t4e w/SFP manifold?
  238. H22a Wiring
  239. god prelude helms manual in PDF?
  240. 5th gear vtec?
  241. Rebuilding My Transmission
  242. Color Code for 1998 Pearl White Prelude
  243. Message Board Website for Unreliable Sportshifts?
  244. New Clutch or just a leak
  245. H22 Timing belt replacement
  246. car wont start! Distributor help needed
  247. For those with mugen exhaust
  248. JDM H22A Redline?
  249. HID sidemarker or turn signal bulbs?!?!
  250. Idle bogs down after revving it a bit when the A/C is on?
