- Rear Crossmember 4th gen
- urgent
- Cam gear question
- idle issue help
- 5th gen wiring with a hondata s300?? putting back to stock setup
- My 98 Prelude Jerks forward when I come to a stop [Help]
- a couple problems with my 2000 base prelude
- JDM clusters help!
- Anyone that has EVER had the "random misfire" CEL code, POST UP!
- from what year to what year is the 5th gen. prelude??
- H23 Timing Issues...
- p14 aws
- Recaro Rails
- Wastegate Size
- 4th gen shift knob stuck?
- Clutch/Tranny question.
- Auto Tranny question
- Location of fuel pump wires?
- JDM H22a Nitrous Parts List Plus Questions
- sounds like engine knocking please HELP!!!
- stock steering wheel
- Hood Dampers for 4th gen prelude
- removing crank pulley
- turbo prelude questions
- what brake pads do you use?
- engine getting hot real quick?
- skunk2 cam gears....(searched)
- Skunk2 New designed manifold
- OBD 2 to OBD 1
- help with my o2 sensor cel code 41
- jdm type s pistons
- removing pulley
- Will these wheels...
- Exahast Help
- Dyno Results and Questions On A H23
- H22A Mid Shaft Bearing
- front bumper protection?
- Need help with the nitrous
- Nitrous HELPP!
- Prelude sh....swaped jdm h22??? HELP
- 235/40/17 or 225/45/17 or 215/4017
- Crank sensor vs no crank sensor
- Help out with Ground Control coilovers needing new struts
- Questions Vs 1992 Lude si H2.3
- Honing H22A cylinders - How different than anything else?
- jdm H22a type s cams vs crower cams
- "yellow" maintence soon box...
- OBD for 92 lude???
- h22 swap into ek help
- Good Place for a C/F hood
- Question about Vehicle speed sensors
- Hot to set the cruise control on a 91 2.2vtech it's set for 60 and i waht to put it to 70 ??
- Leaving The Lude Soon
- What should I get to build up my H22 for more power?
- who's got a greddy kit on a 5th gen on here?
- Going from 16" to 17" tires . . .
- motor blew? help...
- transmission sway ????? ASAP
- K Sport big brake kit
- 95 prelude problems
- Lets talk SLICKS!
- H22 Turbo setup
- Something other than an h22 in the 97+ lude?
- CR how high should i bet
- awkward idle
- Alignment or what
- HOW 2 reset timing on H22
- turbo prelude, advice needed
- anyone use the mahle gold pistons yet?
- smokin h22 in v-tech
- PS bracket and pump for F20B
- Is it possible to fit RSX guages in a Prelude cluster?
- 5th gen tranny noise through shifting
- K swap in 92 prelude
- MSD Distributor Cap for h22
- Prelude on 15's?
- Transmission problems
- Cat-back
- Prelude SH vs ITR
- Oil Leak Pleases Help.
- Will a 94 prelude H23a safely go into a 92 prelude.
- Do i have a blown headgasket?
- Valve Cover Torque
- k-series
- H23 Headgasaket change Qs
- crank pulley is still wobbling!
- I'm a noob to fixing cars... need some minor help
- Running on 3 cylinders on H22A4 Swap. Help!!
- Timing Belt Tension...slack
- NO IDEA!!!!!
- h to b series tranny swap.....
- how to find bearing sizes on h22?
- =Possible clutch problem....need suggestions=
- Car idol low when i turn on A/C, sometime engine die out
- new idle problem....
- B20A/21a1 Engine Mounts
- Satin Black BB6?
- bb4 prelude question
- Front Motor Mount Bolts!
- Reading Intake Air Temperatures
- FUNeasyMODIFICATION
- ESP mounts 5th gen
- one fab top mount: how the **** can i run the dp? pics included
- 93 with a h22a4 i need ideas
- EDM-JDM Rear Wiper setup Pic Request
- 250 WHP With No Turbo and no NOS
- Rear suspension parts
- pocketrockets scamming me?
- Is a Prelude a Grown up Car?
- Check Engine Light, Codes P0700 and P0730
- 87 2.o si performance?
- My BB4 Project
- H22A connecting rod/Inline pro 2mm headgasket torque specs??
- Yet another, noob question (PLEASE HELP!)
- quick type s piston question
- adjust your car's idle?
- exhaust ??
- all kinda problems
- how to check distributor?
- Swapping Honda Badge/Emblem on 5th Gen
- tranny fluid 5spd
- need to find a belt
- Knock sensor socket size?
- Has anyone of you had this problem?
- taillight problem
- Vtec
- Will it fit? Quaife LSD & Mfactory Final Gear
- The Random Misfire CEL on obd2 cars converted to obd1
- Prelude 6 speed Tranny
- Prelude custom bodykit front bar only
- antenna problem
- Vtec Controller
- Header bolts
- hig rpm's
- Swap or rebuild?
- should i buy a prelude or a nissan maxima?
- shitty sounding exhaust
- Quick Question...Please Help
- Not the same plugs.
- Need help identifying cams
- Brake lights staying on. 85 prelude
- brake hose replacement please help
- No crank no start
- h22 turbo project- need some input
- dead h22 diagnosis?
- prelude motor
- Preludes with high mileage - check in
- someone with darton sleeve knowledge
- prelude spoiler holes cover up
- clutch isnt catching
- true h23 vtec
- '96 Prelude trunk question
- Battery relocation ... where to put overflow tank now ???
- Catching trans mount
- 2001 Prelude Battery Not Charging At Idle
- white smoke from exhaust
- Motor Sputtering when driving
- Manual Transmission Grinding When Changing Gears
- Gas Smell Plus more
- How much lateral G does SH pull?
- cruise control
- pedal to the floor!!!!
- write up for installing a turbo kit
- Help! locks and cd player not working...
- Clutch adjustment????
- How much is an M2F4 tranny worth?
- brake light
- quest for 2500 pound lude?
- Skunk2 Throttle Body - How'd You get it to work?
- Benen Tow Hook.
- Oxygen Sensor Replacement
- pics of CF lip
- powder coating
- well i need help. wont idle
- i have a ?
- Steering Wheel
- digital climate control question
- Engine operating temp
- HASPORT mount kit for H22A
- Type S Steering Wheel
- So I'm changing my clutch!
- Tips on removing IACV
- 88-91 Prelude Ksport Coilovers
- Main Relay or needs Tune up???
- blown motor, can this be resleeved??PICS
- H22 Not going in Gear
- Dash lights not working 5g
- 1992 honda prelude H2.3 SI -Automatic
- need some help on a 5th gen. prelude!!
- h22 skunk2 pro series intake manifold
- oh boy, wiring problems!
- Sloppy Shifting or No Shifting
- Need help with ignition problem
- new to fourm have a question about a car i might buy
- Coolant leak prelude '88
- O2 sensor simulator
- best way to stick back prelude emblem?
- H22 crank
- apexi ws2 exhaust
- Is there a way to take off a door panel w/ the door closed?
- ECU ground ??
- dohc f22b performance parts
- mis-shifted and revved to 9k... and i don't have balance shafts...
- Official OBDI H22a into OBDII 5th gen Thread
- ECU Removal
- 4g JDM H22 longblock into '98 BB6
- H23 with H22 head
- Engine Swap troubles
- Type-S motor issues
- 3rd gen TEIN coilover GB!!!
- whut wheels should i get for my bb4
- Temperature Gauge
- 93 Prelude H23a1 help....
- How Do I Replace Crankshaft Pulley on H22
- H22 noise level- is this normal?
- OBD1/OBD2 Differences
- jdm side marker install
- Too high engine oil temp?
- how do i take off 92 headlights
- i have a 93 prelude h23 auto and have ?'s
- check engine light
- good suspension?
- 5th gen exhausts that dont hang low? Also more quiet than greddy?
- ACT streetlite flywheel ?
- intake manifold for a 93
- Stainless steel fuel lines
- Helical Torque sensing LSD would yall say this is one of the best???
- Best exhaust piping size
- Need pix of 4th gen preludes on Type-r wheelies. Anyone?
- littlehelpplZ
- Already tried the "where can i get this thread"
- AEMtruPower
- lightest CF hood available for 5Gen?
- 5th gen prelude
- flat faced valves
- is their any sites that sell this
- help me pass my smog check!
- Help Check Engine Light is on !!
- Which suspension mod affects handling the most?
- 92 Prelude Si Transmission swap?
- is this hondata the real thing?
- 97 prelude automatic transmission problem
- fog lights question
- Anybodys 5th gen starting to rust?
- shifter knob 95- prelude
- Installing struts ??
- Idle problem
- balance shaft removal
- Fuel Pressure Guage
- oil light on in my honda prelude 98
