Prelude Gen. 4 Foglights
Old Oct 20, 2003 | 09:54 AM
chau003's Avatar
Default Prelude Gen. 4 Foglights
I think i've seen threads here about the wiring of the factory fogs but i cant seem to find the thread in "search." If its in the archives or something.. could someone find it for me? I juss have a couple questions before I pick up a set of foggies juss general wiring and how-to's. When i took off my bumper to put in my jdm headlights, i saw that there were extra harnesses where the turning signals were, i'm assuming those are for the fogs?
Old Oct 20, 2003 | 10:02 AM
PhatboyNYC's Avatar
Default Re: Prelude Gen. 4 Foglights (chau003)
The 92-96 Preludes all came pre-wired for the OEM fogs if I'm not mistaken. The two plugs you see behind the bumper lights simply plug into the OEM fogs. Depending on what year your prelude is, you'll find the plug for the foglight switch either behind the drivers side tweeter cover (92-93) or underneath the centerconsole (94-96). Hope this helps.
Old Oct 20, 2003 | 10:18 AM
chau003's Avatar
Default Re: Prelude Gen. 4 Foglights (PhAtBoY Si)
great, thanks phatboy. So basically, its all plug and play for us. And bulb size is h3 ?
Old Oct 20, 2003 | 10:42 AM
Prelude Styl's Avatar
yes and yes, and.. you'll need a relay as well. it plugs into an open harness under the dash by the steering column. Any honda relay that's the same size will work.
efcivic92
Nov 19, 2008 11:00 PM
popRAWvtec
Nov 20, 2006 03:32 AM
b16_madman
May 27, 2004 07:13 PM
PhatboyNYC
Aug 15, 2003 12:20 PM
preluda92
Aug 7, 2003 07:51 PM
