obd1 h23a non-vtec
Old Oct 19, 2003 | 06:15 PM
B18CUL8R's Avatar
Default obd1 h23a non-vtec
would an h22a vtec ecu make a non-vtec h23a run faster?? im just curious..thanks
Old Oct 19, 2003 | 06:18 PM
PetroGuyX's Avatar
no
Old Oct 19, 2003 | 06:26 PM
satan_srv's Avatar
Default Re: (PetroGuyX)
probably due to less fuel, ut as soon as you hit 4900 rpms, VTEC tries to engage and the ecu realizes you have no VTEC solenoid VTM or anything you'll blow engine codes and be in safe mode, which will make you really slow.
Old Oct 19, 2003 | 10:22 PM
B18CUL8R's Avatar
Default Re: obd1 h23a non-vtec (B18CUL8R)
some stupid kid was lipping about his LS integra saying a gsr ecu made it faster. then he was saying i should get a h22a ecu for my h23..i wasnt about to beleive him so i had to ask....lol now i can go shut him up
Old Oct 20, 2003 | 04:48 AM
19924ws's Avatar
It's been debated that a 94-95 LS ECU will make the H23 faster because it has more agressive ignition maps.
Old Oct 21, 2003 | 03:00 AM
B18CUL8R's Avatar
really?? is should try it
Old Oct 21, 2003 | 03:03 AM
satan_srv's Avatar
Default Re: (B18CUL8R)
agressive ignition maps? Well it has way less fuel that's for sure...both vehicles run 240cc injectors...an LS ecu would be really lean on an H23 I would think...like really bad.
Old Oct 21, 2003 | 03:29 AM
Jesus_FR's Avatar
Default Re: (satan_srv)
Indeed. It would get some power though. For 1 to 5 km. Then BANG...
Old Oct 21, 2003 | 04:54 AM
19924ws's Avatar
It's not injecting a certain amount of fuel, just opening the injectors for a certain amount of time. The bigger H23 injectors open for the same amount of time as the LS ones provides more fuel. Then consider an increase in fuel press with an aftermarket press regulator. You're not swapping injectors and the computer can't tell what size the injectors are.
Dave Brabant
Jun 28, 2018 01:17 PM
crazihobo
Dec 5, 2008 06:04 AM
rmiller
Feb 1, 2008 10:10 PM
junlude19
Nov 2, 2004 03:45 PM
gsrhatch530
Feb 6, 2003 12:03 PM
