PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 [182] 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 89 Prelude SI Oil Pressure Problems
  2. Electrical Problem 96 Prelude. Short?
  3. Difference between oil pressure/level
  4. Tire fitment 4th Gen
  5. Replacing window regulator in 89 driver door
  6. I'm going on the dyno...but the wideband??
  7. help with my f22a1
  8. crower cams
  9. i need a H22A1
  10. cel code 21 vtec control solenoid
  11. Anyone here running heat range 7 plugs?
  12. vafc tunning
  13. 3rd Gen Info Needed, suspension bushings
  14. Cleaning my engine bay of grease, what to use?
  15. f22b problems
  16. accord to prelude
  17. I need help with turbo 01 Prelude
  18. Any tips on going back to stock exhaust?
  19. Code 9, CYP - cylinder sensor
  20. 92 honda prelude h22a swap
  21. Chitown photoshoot inside >>
  22. Which exhaust
  23. Moly coated rings?
  24. how much oil
  25. Coil bad?
  26. Causes of backfire
  27. JDM F22B ECU
  28. 97 Prelude SH Suspension
  29. JDM H22 coils, internal or external???
  30. Intake Control Diaphram...
  31. Wire harness/wire tuck assistance needed...
  32. civic shiftboot in a 5th gen?
  33. DRL relay for a 1997 Prelude base model.
  34. which preludes had yellow foglights? 88-89 or 90-91 usdm? help!
  35. Blown Timing Belt Rebuild
  36. turbonator...
  37. Goin' to the track!!!
  38. SFP manifold
  39. Balance gear locked up
  40. Dynoed my 1992 prelude si (H23)...
  41. OBD2 Secondary o2 Sim Question
  42. Where to buy H22 breather kit?
  43. Installing monitor behind smoked plastic
  44. Bad clutch?
  45. How-to: Install JDM 4th Gen. Prelude Window Visors??
  46. B&M FPR
  47. Tubular turbo header?
  48. oil pump seal issue on h22a1
  49. Location of Factory Foglight Harnesses in 92 Prelude Si??
  50. building a head
  51. 91si 88si aws
  52. Anyone Selling An H22A?
  53. Uberdata and P13?
  54. has anyone buy rims off wheelmax?
  55. Prelude Lsd questions
  56. Idle Issue for H22a4
  57. pic of the kamikaze header b-pipe
  58. tuner shops in louisiana
  59. Where do you place your catch can lines to?
  60. Paint color question
  61. power antenna question
  62. pre obd to obd1
  63. Do you guys think this crank is toast?
  64. not getting fuel
  65. tach is 500 rpms off at redline
  66. fuel pressure regulator on stock rail?
  67. P0172 Sys. To Rich Bank1?
  68. once again no tension on h23 swap
  69. Broken Headlight Brackets
  70. Swap: Power Doors on Non Power Door car?
  71. gas tank problem
  72. Need Flange
  73. ATTS tranny out, Base Model Tranny in?
  74. What to do?
  75. tranny swap problem?
  76. Dumb question.... location of IAT sensor on H22?
  77. max hp on h22a
  78. p0113 code?
  79. 97 lude tranny question
  80. AC Problems..
  81. messed up?
  82. Prelude Mugen Hub
  83. 3rd gen ludes
  84. head swap = map sensor error??? HELP!
  85. CLutch Problem?? HELP PLEZZZ!!
  86. car won't start. electrical maybe?
  87. custom AC lines? where to buy? etc....
  88. for 5g Prelude ~AEM EMS or Hondata~ which would you prefer?
  89. h23 build up
  90. head build
  91. different vtec sound?
  92. pictures of v2 installed in prelude?
  93. does anyone own an aem v2 in LA?
  94. H22 CamGears
  95. where can i buy itb for my h22?
  96. 2000 SH Running Very Rich?
  97. A good h22 header please help
  98. differences between 97-99 and 00-01
  99. What's that noise? Not valve lash.
  100. ppl with the magnetic oil drain plug
  101. car not always starting? Help!!
  102. need help on check engine light
  103. crankpully? any one using fluidamper?
  104. Need help installing steering wheel?
  105. 4ws P13 question
  106. Please help me!! 2000 prelude in trouble. Cluster and gaguage lights OUT!!!
  107. stainless steel valves
  108. what to do with power steering cooling lines ????????
  109. no ac ,what belt on h22???????
  110. H22 valve cover bolt sequence????? did search
  111. okay..prelude crank but won't start, timing belt half ripped
  112. Code 3
  113. 5th gen Prelude Taillights, opinions welcome
  114. JDM p13 (h22) causes valve clatter and USDM p14 (h23) doesn't. WTF?
  115. h22 piston to deck???
  116. strut interchangability
  117. 5gen transmission problem
  118. Help, fan does not stop
  119. NEW AXLES HELP
  120. i got a problem
  121. lma tranferrable?
  122. White smoke...after my project
  123. Newb Questions, regarding 5speed/SH prelude
  124. swapping a h22a type s motor
  125. JDM H22 Dizzy = what dizzy
  126. JDM H22 Distributor PROBLEM
  127. in the market for new intake.help(not a cai vs short ram thread)
  128. Oil levels
  129. Apexi N1 exhaust
  130. How important is it to change washers with fuel filter?
  131. IMPORTANT: incorrect PCV routing in JRSC instructions
  132. Key Code & Stereo Code same?
  133. weird exhaust smell and blue smoke
  134. For everyone here that's done a 5spd conversion...Please help...
  135. Timing Belt Broke
  136. Afraid (Timing belt)??
  137. Bridgestone Potenza RE750
  138. help analyze my timeslip
  139. help me
  140. Radiator fan turns on when engine turns off, doesn't seem to turn on when the engine is running.
  141. prelude f22 tranny on h23
  142. thought you guys would like this ....f20b+itb with vids
  143. 4th gen ball joint removal..help needed
  144. Auto window 4th Gen
  145. keep geting evap problem, CEL
  146. Headlight keeps burning out
  147. h23 manual tensioner spring tension question
  148. Problems that need fixin! NEED INPUT PLEASE! Lots of questions!
  149. Lost Motion Assembly???
  150. My first engine build picts, more picts wanted
  151. 93 prelude vtec wiring
  152. alignment question after suspension change
  153. car cutting off
  154. pics of cai in a luder?
  155. Throw out bearing??
  156. 99 accord springs
  157. CEL code 43 fuel management help
  158. what tires and wheel set up do you guys use on track?
  159. manual tranmission fluid.....
  160. S2000 seats in prelude, Someone Has To Know!!!
  161. bushings for 5th gen preludes?
  162. Auto to manual ECU/ICU/keys after auto to manual tranny swap
  163. Transmissions not my forté. --> which on H23 vtec?
  164. Which H22 has the closed deck design?
  165. is all 92-96 vtec model tranny slave cyclinder position have the same fitting exact?
  166. Header Back Exhausts
  167. Turbo T3/T04e In 60 A/R, Ex 63 A/R in H22
  168. h23 pistons in h22
  169. east caost NC engine builders...
  170. where is ECM test harness?
  171. h22 questions**crank, rods, pistons, etc**
  172. Pic Request!!!! Prelude Rims Paint
  173. H22 piston claying
  174. Where is a good spot to mount VAFC on 4th gen?
  175. how to post an image in my sig?
  176. Help me pass smog test please
  177. Replacing rotors?
  178. Sportshifter wiring diagram.
  179. Flywheel sugestions
  180. Just Makin Sure??
  181. Clutch ? Pressure Plate
  182. Fujitsubo header B-pipe dimensions ?
  183. Tranny problem
  184. Prelude throttle body sizes
  185. what to look for in a 99 sh?
  186. What was the site with the good price on jdm h22s? Rising sun something or other...
  187. Clutch/Flyweeh in H22
  188. auto to manual tensioner - why?
  189. speaker fitment
  190. 98 Prelude Fuse Box
  191. Prelude Opinions Wanted
  192. jdm h22 tranny
  193. Headers and Exhaust
  194. 4th/5th gen seats
  195. Noob to 3rd Gen Preludes
  196. timing balancer belt
  197. missing link
  198. JASMA header fit stock pipe?
  199. Best rods to use with Type S pistons? (OS)
  200. fuel pump and injectors
  201. H22 Tranny Gears???
  202. running nitrous with stock cat
  203. i have some questions about my h22 i am puting it back together
  204. OIL LEAK PROBLEM....what is it?
  205. Where are the rain gutters on a 4th gen?
  206. Clutch Tranny Problems... Help.
  207. H22A will not start; I've checked everything I can think of, NEED ADVICE DEARLY!!
  208. Need Help with a 98 h22 swapp into a 99 civic coupe
  209. Automatic prelude shift knob replacement...Help!
  210. Problems installing a rear strut bar on a 92 prelude 4ws
  211. B21 oil consumption problem (1990 Si)
  212. will ABS light on fail smog test in Ca
  213. Where do you turn when you can't find lude pieces on ebay, here, hpoa or PO?
  214. Random Ohio Prelude sighting....HELP ME!!!
  215. Distributor Cap Question...
  216. SMSP header with JRSC?
  217. 4th gen jdm one piece headlights
  218. raced the H22 for the first time
  219. oh crap ...cam gear slipped
  220. Digital manual - for upload
  221. wont rev pass 3k
  222. 92 - 96 prelude passenger airbag all years interchangable???......??
  223. Cam Gears... What shoudl I set them to? (No Dyno available)
  224. Shift Cables Stretched or Broken - Fixed and Review of JDM Cables
  225. everytime i take a corner my clutch pedal goes soft
  226. Help Me!!!
  227. tire rub problem... one side only
  228. Prelude Diagnostic Steps
  229. Tanabe USA still looking for socal Prelude
  230. Rebuilding engine cost from kings motorsports
  231. Swapping a H22A into a 96 EK Hatch..NEED HELP ON WIRING ...
  232. Need help with idle Problem!!!
  233. new prelude bb4 owner
  234. Need Help Fast!
  235. .:OFFICIAL TREAD:. Idle problems surging RPM dropping (search friendly)
  236. pistons????
  237. Prelude Internal Coil to External Coil???
  238. trying to diagnose a weird sound
  239. Doing an alignment on a lowered prelude?
  240. Just rebuilt engine
  241. h22 swap into f22 lude
  242. gauge install
  243. Cracked lens replacement
  244. Starting Troubles
  245. 5th Gen H22A4 Tranny swap
  246. Which car? Need your help!
  247. Suspension HELP!!!!
  248. Calling All JDM H22a Experts!! Opinions
  249. Frozen (stuck) Gas Pedal
  250. 4th gens w/ oil sandwich adapters
