PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 [198] 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. SR20 into 4th Gen
  2. what to do next for more power?
  3. where can i find kyb agx struts for a good price for a 92 s prelude?
  4. parting out my 91 perlude greddied out
  5. Nology plug wires??
  6. what springs
  7. Is the skunk 2 intake manifold worth it?
  8. what is the possibility?
  9. Coolant Flush Step-by-step?
  10. ECU problem HELP !
  11. something wrong with my ground controls??
  12. Gearbox Curiosity...
  13. ECU Reset
  14. S model Calipers the same as Vtec model?
  15. question about preludes headlights?
  16. can u put?
  17. How do I change my transmission fluid?
  18. H22 dist ?
  19. Advice needed: A/C not blowing from dash vents
  20. Type R seats in prelude
  21. Have you ever seen so much torque in a h22?
  22. Jdmh22a specs plz help!!
  23. Accidently into second??
  24. no clutch pedal pressure?????
  25. a heads up for suspension installers =]
  26. OBX Cams
  27. Is doing a collector mod on a dc 4-2-1 basically the same results as the jdm 4-1?
  28. Merry Christmas to me! H23 -> H22
  29. prospeed header question about flange to connect to cat?
  30. SH or not help please
  31. ECU question (which do i have???)
  32. Hardness of clutch installation in a 97 SH?
  33. Anyone ever put dual exhaust on their Prelude?
  34. 4th gen Gauge Cluster Bulbs
  35. JDM H23 For Sale Freshly overhauled/rebuilt
  36. i need list of parts that i need to put a h22 head on a h23 do i need a different
  37. help h23block h22 head
  38. Greddy Evo2 exhausts
  39. 3rd Brake light
  40. engine question
  41. Is a collector mod worth doing on dc header?
  42. Comparing K20a to H22 Euro Accord motors
  43. rearview mirror
  44. DO AFTERMARKET SHOCKS MAKE A BIG DIFFERENCE IN 1/4 MILE TIMES
  45. Help with TDC(h22)
  46. SH Header on Accord w/ h22
  47. installing rear springs
  48. Anything look wrong with this light?
  49. dc headers 2.5" collector mod compared to top headers?
  50. JDM type-s H22a specs
  51. VTEC failure????
  52. TURBO H22
  53. P0420 - Catalyst System Efficiency Below Threshold
  54. Fog Light install (1997+)
  55. FPR's and Fuel Rails...
  56. I love my life now!!!!
  57. 91 Prelude 4ws power steering rack
  58. Crower Cams with 37261 stamp...
  59. Yay, I lost 43 lbs! (4th gen CF sunroof plug)
  60. ignition missing?
  61. Does this look wrong?
  62. FAO: satan_srv
  63. Wierd Squeeking Noise??
  64. can you reuse this filter?
  65. Gold series h22 pistons...?
  66. Misfire code after H22A4 > H22A swap? Any thoughts?
  67. Upgrade Help
  68. Is Check Value has anything to do with Turbo?
  69. 02 Sensor?
  70. http://auto.howstuffworks.com/turbo4.htm
  71. mushy clutch after some driving???????
  72. starting problem
  73. what is the best site to purchase a JDM h22 + tranny?
  74. Vibration at idle in "D" with brake applied ('88 S)
  75. Anti-sway bars for the 5th gen
  76. Mahle Goldseries pistons
  77. Loud Boom Noise
  78. Prelude Aftermarket Throttle Bodies.
  79. anyone ever move the alternator
  80. HELP! My driver side window is jacked.....
  81. h22 not running right
  82. h23a2 block stamp
  83. Rod Knock
  84. Alternator keeps breaking... (searched)
  85. H22 with b16 tranny 1/4 times!
  86. Login Help needed. Forgot my passwpord
  87. Need Help Finding A Good Replacement For The 97-01 Prelude's Upper Control Arm
  88. 98 Prelude SH running to rich and won't start
  89. Help with brake removal please!
  90. Lookin at a 92 Lude, Need help?
  91. # Help!!My car is running terribly rich!
  92. How to identify a H23 tranny
  93. lude idle problem...not like the others
  94. EGR Fooling....
  95. cooling fan
  96. ringing noise coming from exhaust...
  97. Shocks and Spring combo for my prelude?
  98. Accord Ebay Front Lips?
  99. Weight reduction: 1/4 mile time
  100. 5th gear griding problem
  101. Question about spring rates for my rubbing problem...
  102. How long should bump stops be?
  103. Wrecked my prelude.. what a terrible new years
  104. installed pics of itr shift boot and more....
  105. Procedure for oil pan gasket.
  106. Turbo burning oil? HELP!
  107. Larger wheels / tires and ATTS
  108. Do away with Power Steering?
  109. 5th gen sidemarker
  110. the difference between sh and base model motor?
  111. jdm one piece headlight trouble
  112. Need help in my prelude 96
  113. Synthetic v. Regular (dumb mistake)
  114. Right tire Pressure?
  115. Ignition switch wirings?
  116. JDM H22A OBD1 engine put in OBDII Prelude
  117. Idle and Check Engine Light ?????
  118. 1997 prelude DRL
  119. need power!!!
  120. 5th gen. prelude Wings west lip installation???
  121. Type S tranny.... How to tell?
  122. Opinions on setup
  123. Power Steering Belt Removal 1991 Prelude
  124. A bunch of noob prelude questions
  125. vtec controller tuner
  126. install problems/questions
  127. 98 prelude oem pads?
  128. 93 honda prelude motor vibration when under load
  129. Quick question bout f22
  130. 3.0L H22A
  131. Sway Bar: Will Lightspeed 28mm sway bark snap off the brackets?
  132. Winshield Wipers Driving me insaine
  133. i spun a main bearing and rod bearing ....is it possible to fix the block h23a2
  134. How long has everyone owned their prelude?
  135. rear seat swaps
  136. Venom Intake Manifold
  137. Just Dyno'd My H22
  138. What the hell??? Jdm 2 piece headlights??
  139. Light weight wheels VS Stock wheels.
  140. Distributor Rotor
  141. Redline of euro h22 motor?
  142. Went to the dyno today
  143. engine id numbers
  144. wut should i get???
  145. AFC VS VENOM CONTROL MODULE
  146. Alphawerks headers
  147. Does this part actually clean oil, increase engine life?
  148. Identify what this is(cracked my oil pump)
  149. steps to installing a turbo on a lude
  150. old prelude SI motor question
  151. Something wrong with gas pedal...
  152. Need Codes sheet for 90 Lude Si
  153. 92 trany swap
  154. Which Setup Do You Think is Better?
  155. Radiator cap
  156. O2 sensor
  157. Engine swap can all work
  158. steps to install a trubo kit on a lude
  159. JDM cluster wiring?
  160. Bumper signals for 92 prelude
  161. Running nitrous on H22 Euro Accord TypeR?
  162. it can be repaired ***picture***
  163. Leaking Power Steering Reservoir Problems
  164. lower control arm '87
  165. New problem (auto tensioner?)
  166. Relocating plates???
  167. What is the ratio of weightloss to 1/4 mile improvement?
  168. Factory 2.3 H-series VTEC ?
  169. 92-95 prelude vtec rotors
  170. if i use a f22b dohc ecu on my h23, would it make more power?
  171. Anywhere in particular good to get my hands on an h23?
  172. IAB's open or closed?? w/pic
  173. I think I've got fried piston rings, what do I do? (5th gen)
  174. 4th Gen Prelude Alternator Assembly need diagram or how to...
  175. H22 shift box.. HELP
  176. any known 5th gen prelude problems?
  177. how do you bleed the radiator
  178. Porter Electric Replacement Distributors?
  179. Anybody have a h22 IACV, MAP, TPS
  180. Bolt size for brake rotor (tried search already)
  181. Got a temperature problem, need a solution.
  182. what should i do to make my lude quicker/look nice for cheap?
  183. Anyone familiar with these sleeves?
  184. stroker?
  185. ws exhaust.
  186. turboing a lude
  187. EuroLite Xenon Fusion Bulbs: Review
  188. virgin p13 ecu
  189. 5zigen Fireball...any good?
  190. which header is the best?
  191. air fuel gauge question
  192. tuneup question
  193. STILL OVERHEATING!!!
  194. Brakes/Suspension/Bushings redo -- problems with Axle/Hub nuts!
  195. 97up Bulb questions??
  196. Removing Sunroof from Dead Car..
  197. how to wire up a resister box and obd1 inecjtor/clips
  198. how much a h22 vtec head cost
  199. clutch pedal is DEAD
  200. 5G Distributor Ignitor Questions - Replace Options?
  201. Did i bend a valve?
  202. E-Brake light always on.....
  203. alternator pulleys = idle problems
  204. rev limiter
  205. Error Code 4 on 97 Prelude
  206. H22 Euro Accord TypeR motor worth the $$???
  207. taking off streeting wheel and putting on momo.
  208. electric problem?
  209. need help, for h22a4 head torque spec
  210. flex pipe keeps breaking...(new ones... not re-using old one) lol
  211. I need your guys' help again - California Smog
  212. how to install my new injectors on my 5th gen
  213. Stuck oil filter, no good tools ('88)
  214. real Spoon p13 ecu
  215. h22a header heatshield??????
  216. 97-01 triple pillar?
  217. what is the "push button" for on the radiator cap?? what does it do?
  218. i need help with my bumper light
  219. help!!!!!!!
  220. I just thought id share this ECU Info
  221. compression test numbers on h22a4?
  222. engine hydrolocked?
  223. 93 Prelude blower motor?
  224. iat sensor help me locate it
  225. High idling problem! What is this hole?
  226. vin number question
  227. Where do I check the automatic transmission fluid ('88 S model)?
  228. Coolant disapearing
  229. "Check Engine" light comes on after exhaust work--Any ideas before I go to dealer?
  230. newbie
  231. To the turbo expert!!!
  232. What is the exact difference between h22a4 and h22a1 rods ???
  233. KYB AGX + Eibach Prokit Impressions (along with brembo oem rotors and aem pads)
  234. how to install walbro f.p
  235. Koni Shock (driver side) squeaking noises?
  236. Door lock problem...kind of odd
  237. lowest 5th gen weight on street
  238. Tell me about your HID's
  239. civic with h22 jerking me
  240. Golden Eagle 440 Cam gears
  241. michaels intake manifold h22
  242. H22 Turbo
  243. 5th gen Greddy Header still in development?
  244. code 22
  245. got a problem with my prelude!!!
  246. Xmas was almost ruined.......oil leak
  247. 4th gen and 5th gen
  248. Odd Technical ghetto question...............
  249. Problems with engine shutting off
  250. H22 shifter... HELP
