PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. [freak]!
  2. a.f ratio and oil pressure gauge
  3. Speaker problems
  4. tiger japanese?
  5. F22 Build
  6. Help, Changing spark plug wires. 1998 honda prelude.
  7. h22a4 vacuum hoses loacation
  8. JDM or USDM Lighting?
  9. lacking power
  10. I need help again.......
  11. going turbo and have a couple questions
  12. Where is the Srs comp. in a 5th gen?
  13. h22/h23head gasket
  14. Eibach Pro Kit
  15. '91 Prelude B21A1 Transmission/shifting issues.
  16. Vibrant H22 Header
  17. Jdm H22A bolt on's? --- meh some ideas atleast from some h22a fans.
  18. header/exhaust question
  19. h22a swap tips/concerns?
  20. 5th gen JDM spoiler w/ sidemarker lights?
  21. shock/spring question
  22. To anyone running Techna-fit Stainless steel brake lines
  23. RS-R Ex-Mag for H23
  24. b20a5 manifold on b18c1
  25. Anyone know how to hook up a horn for 5th gen aftermarket steering wheel?
  26. Is there a silencer that will fit an Apexi WS
  27. 4th generation oxygen sensor?
  28. Cold start + short drive bad for motor?
  29. Strange grindish whalish sounding noise and rubbing on front passenger side
  30. H22A1 Head VS H22A Head Any Diffrences?
  31. thinking of getting a megan header for h23 but what gasket?
  32. Manual swap, or entire JDM swap
  33. 5th gen making whistling noise
  34. koyo manual tensioner
  35. ECU/Turbocharger help?!?!?
  36. How to make an 2000 prelude stock exhaust louder
  37. Valve Cover
  38. 5th Gen Weight
  39. Do I need a camber kit for 1.2 - 1.3 inch drop on base 97?
  40. Dyno Results
  41. f22b1 SOHC VTEC into 92-95 prelude??
  42. Valve cover gasket
  43. making ecu go into limp mode
  44. 3rd gen prelude w/ low offsets?s not much 3rd gen preluders out here, but
  45. heater question
  46. 92 h22 lude wont start
  47. Mild overheating problem! Please help
  48. weird noise from engine after timing adjusted
  49. How to wire power locks into my 4th gen?
  50. header problem H2B
  51. smoked tail light thoughts/opinions??
  52. 00 idling issue
  53. What can I pull off my old motor before I go to the shop for a swap?
  54. How to set the TPS
  55. Occasional Power Loss
  56. Weird TPS screws, How To Remove these
  57. IAB WIRING
  58. Bolt Sizes On Oil Pan for 99 Prelude
  59. Recommended throttle body size for H22A
  60. exhaust smoke between shifts high rpm only
  61. Sensor in back of head
  62. turbo
  63. h22 oil sensor
  64. Car shuts off when I hit patch of ice?
  65. EGR Problems!
  66. H23a Vtec question
  67. type-s vs. type-sh wheels
  68. differance in sensor please help
  69. 5th gen vs 4th gen Brake Master Cylinder Size
  70. H23 Vtec Alternator Question
  71. prelude vti-R
  72. Excessive Head Pressure. Checked PCV, etc
  73. need some opinion on the Innovative solid mounts
  74. Where can oil and coolant mix?
  75. jdm type-sh swap
  76. EVAP sensors after removal?
  77. H22A header
  78. Camber kits!
  79. Someone please help!!
  80. ITR recaros
  81. alternator
  82. Quick Q, Fuel Rail and FPR
  83. sh or not
  84. Lower Intake Mani Bolts
  85. Nuts on ECM Cover
  86. Quick Question...
  87. adding turbo to stock engine 99 prelude
  88. legend discs
  89. 5th gen just hit 90k
  90. Non ABS lude prop. valve
  91. Rod Bolts? OEM or ______?
  92. My h22a - Something's missing?
  93. 2001 prelude sh tranny/clutch issues - stuck in gear
  94. hood cushion question
  95. 02 Sensor Check Engine Light
  96. need help wont start
  97. 5th gen trunk leak
  98. Low Compression
  99. Tail Light fitting
  100. Help! With 93 V-tec Fuel Issues plz!
  101. I need help on an aftermarket steering wheel
  102. crower valve springs and retainers
  103. Progress swar bar END LINKS KIT?
  104. Battery light flickering
  105. 3rd gen electronic oil pressure Q
  106. Brake lamp light?
  107. Please read...
  108. will a f22 fuel rail fit a h22
  109. prelude clear distributor cap where can i find it
  110. 92 lude won't start when cold HELP
  111. JDM Red leather BB6 front and rear seats!
  112. 5th gen sunroof in 4th gen
  113. i become a tuner prelude help!
  114. 5th gen prelude w/ 154k miles, what to do next for a build?
  115. Bouncing idle after using throttle cleaner
  116. still confused ?????!!!!!!!
  117. h22 or h23???
  118. Rocket motorsports valve springs?
  119. struts and springs
  120. apexi v-afc controller
  121. TRansmission swap H22
  122. shifting problem
  123. CD player error
  124. h22 engine build
  125. Idle problems
  126. H23A to F20B
  127. 97 prelude throttle body; is auto throttle body different from manual?
  128. Has Oil pressure. then looses it and blows seal out of oil filter
  129. Whats the purpose for an aftermarket Tachometer???
  130. Best H22a Pistons?
  131. Help - Timing balancers rebalancing?
  132. Auto Below 2000rpm lurch
  133. s2000 steering wheel in a 4th gen?
  134. NEED HELP ON GETTING MODS
  135. Prelude EL Cluster
  136. Fuel pump / relay issue. Help please!
  137. Small Light Fuse - Lights Not Working FIX...
  138. vtec controller questions....
  139. bolt remover?
  140. h22a Low idle with code 14 (bad ecm/bad iacv)
  141. h23vtec obd2 a/t ecu on 96 obd2 jdm h22/obd1 conversion? possible?
  142. Car stumbles and bog and rpm die
  143. H22a4, keeps blowing out the seals in my oil filter
  144. Code 41 appears after Primary Oxygen Sensor Heater replacement
  145. What type of distributer?
  146. Winding noise coming from engine bay......... Please Help
  147. SH or the Base? Nitrous and bolt ons... Confused now plz help
  148. no clutch pressure plz help..very desperate!!!! tried about everything...
  149. H22 MSD Ignitions more spark!?
  150. shorten 92 prelude throttle cable?
  151. power steering debacle
  152. ITR boot in a 4th gen Prelude?
  153. difference in 4th and 5th gen mounts?
  154. FIRST HONDA...I NEED A BOTTOM END FOR MY H22A1
  155. H22 oil leak!
  156. Camgear question
  157. 5th gen Prelude: Best projector/HID solution and what have you guys done?
  158. 97' sh....what is this and where does it go?
  159. Transmission Seal
  160. noise in the suspusion
  161. BOLT, SPECIAL (M8X1.25)
  162. H22 OEM Cam Help Indentify
  163. air intake tube question
  164. H22a or a1 cams for turbo?
  165. 1995 honda prelude si startin problems!
  166. Pulling motor out. Doing a minor overhaul few questions
  167. What Exhaust is everyone running
  168. need pics of h22 manifold wiring
  169. AH! 01 prelude..CEL 71, 72, 73, AND 74
  170. skunk 2 tb getting stuck
  171. Power And Ground Reference for PLX wideband
  172. Clutch Pedal Assembly Picture
  173. Getting no power
  174. 92-96 VTEC Sub-Harness (S & Si, h23a to h22a)
  175. What to use to rotate rear brake piston?
  176. LSD Transmission going on a H23A?
  177. can all H series transmissions bolt on to one another
  178. h23 base emanage map
  179. Finally finished my E85 set up...
  180. balance shaft eli.
  181. anyone in CT wanna change my clutch???
  182. honda prelude 90 strut bars
  183. idle problem with a h22a4
  184. Car stalls during drive, now won't turn over...
  185. RPM Jolt from 3k-0.5k While Crusing
  186. Va
  187. Do springs generally go bad?
  188. in the process of removing my a/c
  189. spark plug gapping?
  190. 88 prelude si
  191. anyone know the part number?
  192. shifter linkage bushings
  193. 95 lude project. . .
  194. Where to mount gauges in 5th gen ?
  195. cam gears
  196. 92 si needs a new transmission
  197. p13 maps
  198. Major problem plz help
  199. To all JDM H22A owner
  200. 4ws Suspension Set-up
  201. Brakes...don't work.
  202. Need Help on Fuel PRessure
  203. ignitions???
  204. H22 in 93 prelude type s dizzy wiring???
  205. H23A vtec with dual valve springs stock?
  206. Chipped p28 or JDM p13
  207. H22 Crank Walking!!?? Crazy Noises, shifting belts, loosing coolant and oil, major problems.. Please
  208. does any have pics
  209. airbag installation
  210. Catback: Skunk2 or Evo2 for 97 base?
  211. Swapping out pistons in rods in a H22
  212. Purchasing a 93 lude.. good deal?
  213. OBDII H22a4 Subharness to Engine harness PinOuts (shocktower connectors)
  214. OBDI H23 Engine harness to Subharness Pinout's (shocktower connectors)
  215. Auto Down Window (Driver's side)
  216. OBD2A ECU pin Diagram
  217. brian cower or skunk2 valve springs?
  218. valve spring help needed
  219. H22A Megan Header vs. Stock JDM Header
  220. wats the best way to go NA??
  221. H22A rebuild
  222. weird clutch problem "searched" friction point
  223. No Temp Guage!
  224. right parts for my build
  225. H22 temperature problem
  226. why wont the key come out the ignition???
  227. 5th gen. header non sh
  228. Brake lights not working. Not becoming bright
  229. neeeed help
  230. 5th gen shifter assembly removal
  231. prelude integra light swap?
  232. i got a? about the tranny solinoide!! help
  233. +-Throttle position screw setting-+
  234. Clutch
  235. engine light
  236. Clarity behind ABS deletion in a 93 Si
  237. timing light Q read please
  238. dc sports rear lower tie bar?
  239. Shift linkage question
  240. clutch line is leaking
  241. Coolant leak by timing belt
  242. rad fan question
  243. Adjusting Clutch position
  244. People using MFactory 5.2 pro/5.15pro FD
  245. H22 emanage mapping
  246. WTB 5th gen Headlight or just the Passenger Headlights..
  247. type s front clip conversion
  248. are 1996 preludes obd1 or obd2?
  249. 1992 H23 NoN-V-tech 170k Trannie Question Please Help
  250. Rusted Pedals
