PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. long post!!! 93 prelude lots of problems!!!!
  2. Radiator hose question
  3. tires
  4. caliper repair kit question
  5. oil pressure gauge
  6. 3d gear problem 92 Prelude S
  7. Auto to Manual Swap Reverse Light Wiring
  8. h23 tranny h22 engine?
  9. What RPM for Longevity with H23 Vtec (stock)
  10. Good reputable place to buy JDM Engines in the present time..
  11. lower ball joint castle nut
  12. walbro fuel pump
  13. header
  14. Problem after problem. Hesitation under load, please help!
  15. Engine Swap - 92-96 H22A vs 97-01 H22A (SH) into 00 SH.
  16. Hey all, newbie planning an all motor 4th gen
  17. Are H23vtec (BLUE TOP) cams the same as Type S cams, Did a search but got mixed answers
  18. throttle body question
  19. Prelude noob--- is this a good buy??
  20. weird tranny/clutch/shifting issue...im stumped!
  21. Coolant problem. (Searched)
  22. OEM Rims?
  23. hard acceleration=loss of clutch!!!!!!
  24. Head ticking (searched)
  25. Obd1 engine harness, obd2 distributor and jdm h22a questions
  26. Are fog lights prewired?
  27. headgasket issue
  28. Ignition issues
  29. JDM Distributor Cap the same as USDM?
  30. have a few questions... (4th gen prlelude h22a)
  31. 2.3 turbo?
  32. Need MAJOR help! my 4th gen won't start!!!
  33. JDM type R steering wheel fit?
  34. My friend just bought a prelude and we need help
  35. 97 Prelude H22 with H23 Block
  36. Need some knowledge
  37. vtec stoped working. no check engine light.
  38. My Prelude wont start (sometimes) and pudders when i hit the gas, and my RPM guage doesn't wo
  39. Hi Im Tyson
  40. Sunday Drive
  41. h22 swap in 92 lude si wiring help
  42. Replacing Hood Hinge
  43. SOLVED: Electrical problems from hell!
  44. obd2 to obd1 wiring
  45. VTEC in and out
  46. 15 inch ITR rims on a 4th gen SRV
  47. H23 smoke from intake monifold, car wont stay on
  48. What CAMS to run on H22? help!
  49. SH Wheel Paint
  50. h22a type-s help...1
  51. how can i make the crank senssor on h22a work
  52. ATTS tranny on H22a
  53. Favorite DIY projects
  54. Battery discharge= Failed Emission
  55. Cam gear placement.
  56. All jdm h22a's have the same power?
  57. Fuel pump help?!
  58. F22B 2.2 DOHC what kind of engine is this???
  59. h22a4 help please...
  60. Cooling Fans Wont come On...? 4th Gen
  61. Howdy - Am new - hoping some experts can help!
  62. seafoamed my egr - now i got a map sensor code
  63. need to know what connects
  64. CEL --09 and 21
  65. car won't start, some power
  66. changed clutch, flywheel, & slave cyl 3 mos l8r clutch slipping again
  67. Won't start
  68. ELECTRICAL EXPERTS READ THIS!
  69. Simple oil light question
  70. hooking vtec to a switch
  71. H22 Cranks
  72. h22a distributor internal coil
  73. Intake Manifolds
  74. Tires
  75. 5th Gen Trouble
  76. Random Front End Shaking
  77. would coilovers for an accord fit on a 5 gen prelude
  78. High idle after valve adjustment
  79. Another no-name Header..
  80. EGR blowing CEL
  81. Preventative Care while motor is out
  82. P13 PGM-FI on Jdm f22b?
  83. BB6 Short Throw
  84. check engine
  85. Prelude SiR
  86. 5th gen question please help!!
  87. 99 Prelude EGR Code
  88. HELP PLEASE!
  89. Antenna timer relay Help!!!!
  90. bb2 intake manifold question
  91. check engine light
  92. Prelude Sir Engine
  93. Vibration during deceleration.
  94. pressing brake=rpm raise
  95. H22A4 auto fit SH model manual tranny?
  96. rubber grommet on shifter cable?
  97. Ground-Control coilovers on 5th gen
  98. where do you install 4 point seat harnesses on a 5th gen?
  99. Does this exist?
  100. Taking bumper off (searched)
  101. help!
  102. mis-fire Cylinder one
  103. H22A Tranny with LSD
  104. axle issue !!! suggestions on pricing for oEM or aftermarket !@!
  105. how to make h22 distributor work in 96 h23 wiring harrness
  106. Replacing a PCV valve
  107. cel help.................... plz
  108. Prelude wheels?
  109. Looking to buy 5th Gen
  110. What to do
  111. Can this be done?
  112. 93 prelude seats
  113. Spring and Strut setup
  114. looking for H22 intake manifold!!! or Sensors!!! Socal Idle probs help!!
  115. HEAD GASKET
  116. valve adjustment..
  117. I hurt my baby('94 honda prelude)
  118. Horn and Cruise control go out at same time....
  119. H22A4 bearings - which ones?
  120. manual or electric
  121. Cheapest place to get a Knock Sensor?
  122. Can someone tell me what color my Prelude is?
  123. Vtec problem
  124. Brainstorming Ideas: What aluminum parts should be made?
  125. Lighting Issues
  126. differnce between the sh and base exhaust
  127. SPARK PLUG WIRES
  128. 1992 Prelude Stock Molding Assembly Roof Color
  129. do i need to take out my shocks if i get coilovers need help before i buy
  130. Hole behind fusebox and where it leads to...
  131. koyo Radiator fitment
  132. Prelude wanted to buy thread? What happend?
  133. header question
  134. i wanna go fast!!!
  135. Searched - car shakes at low speeds after turns
  136. new head & cams but engine will not start?
  137. Noob
  138. Car Stalls out for No Reason
  139. HELP!
  140. 5th gen prelude tranny quest?
  141. Fast idle control valve 92 Prelude S
  142. Totaled my Lude, how much will I get from insurance company?
  143. Turbo OR Supercharger
  144. manual rack conversion w/ 4ws. anything different?
  145. suspension setup
  146. hytech replica headers
  147. freshly built h23/vtec..... help please
  148. I need help finding Camp 1320 website
  149. 4th and 5th gen radiators
  150. Intake manifold problem on H22A4
  151. 1997 witha H22 - Vtec going bad??-
  152. my friends car has been stolen. please help!!! 92 civic hatch si
  153. bored out intake manifold (blacktrax)
  154. Gearbox Rebuild
  155. tb install no fitv help
  156. Bearings gone bad?
  157. h23 vtec
  158. Help a Honda Out! (if you're nice)
  159. any honda meets in san diego?? oceanside area?
  160. How to Tune an A/T H22a
  161. M A P/B A R O Circuit High Input
  162. Re-Installing Power steering: Fitting Sizes and q's
  163. once aging i need yalls help
  164. Caz
  165. injectors
  166. Recently switched from Civic to prelude, with problems
  167. Exhaust
  168. Do I have to lapp the valves?
  169. mugen
  170. new prelude owner on the streets of cincy!
  171. PS removal. comments.
  172. 98 itr specs on a 5 gen. lude looks nice or not
  173. Prelude noob
  174. fuel filter
  175. H22a4 in eg
  176. A/C problem please look
  177. Storing/Keeping an odyssey 680P charged and usable
  178. Bad news for the Prelude forum.....
  179. 4thgen and 5thgen mirrors
  180. manual conversion
  181. NEED HELP!!
  182. Nordic mist JDM lude, some problems
  183. Timing belt seal
  184. H23 VTEC seized
  185. stepping down as your moderator
  186. no vtec function on my 99 prelude
  187. type of motor oil is best?...
  188. p28 in prelude?
  189. need help!!!
  190. Main Girdle Bolts Left Loose!!! Need help with options
  191. Torque mods for a 5gen..
  192. Write up: 65mm ITR Throttle Body on 90-91 B21A1 Intake Manifold
  193. Wiring harness swap question
  194. turbo options
  195. Running Rich
  196. looking for muffler/resonator combo
  197. H23 dilemma.
  198. pedal question auto to manual
  199. questions on an H22 swap
  200. k20 swap good or bad
  201. K&N Typhoon Kit
  202. removing a/c
  203. Complete Noob
  204. Brake Master Cylinder or Brake booster?
  205. Where to get H23 intake manifole?
  206. Prelude 89 SI H22A Swapped Thread
  207. h22 wiring harness
  208. My B20A5 Engine Detail: Before&After
  209. N/A header that allows you to keep A/C
  210. GReddy Headers...
  211. Lip Kits
  212. 4th gen turn signal question
  213. What's wrong here - can't remove my front wheels
  214. Honda meets??
  215. Need Information on Swapping. Please Help.
  216. Changing h22 PS, Alt, Crank Belts
  217. Will Prelude 36mm outers work for JDM ITR hub's?
  218. H22 Type S??
  219. Odd engine noise...
  220. Oil Pan Removal
  221. Bouncing RPM's?
  222. Help. Lude won't turn over.
  223. heat wrap
  224. DIY: 4th Gen USDM Black Housing Headlights
  225. gtx eclipse fuel injectors on 95ls?
  226. Worn valves?
  227. 5th Gen +1 tire size suggestions
  228. flat spots on tires
  229. O2 sensor problem, maybe more????????
  230. What mod brings the best gain for the buck?
  231. h23 injectors h22 motor
  232. can anyone give me a rundown on how to change my tranny fluid? i searched
  233. 5th gen prelude hid install help
  234. Auto Trans problem.
  235. One of those days. Help please.
  236. Has anyone used this valve spring compressor?
  237. Oxygen Sensor Problem HELP
  238. Is my H23vtec safe?
  239. CAR IS BLOWING UP!!!!
  240. STILL GOT A PROBLEM......
  241. What engine do I have in my 95 prelude?
  242. 4th gen Sunroof measurements
  243. intake air temp sesor question
  244. Quick idle question
  245. Civic alternators
  246. lovefab manifold, civic alternator Qs'
  247. H23 & H22
  248. what is IACV?
  249. green light on shift column (blackat)
  250. brakes staying soft after bleeding 3 of 4
