PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 [145] 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. water jacket and turbo questions please help wanna buy car soon
  2. Anyone have carfax?
  3. might be picking up a 91 lude. need info.
  4. 5 gen fuel pump
  5. Engine overheats
  6. Anyone have any pics of 5thgens with 18's
  7. small rock made a spider crack on my front window
  8. Stock pulley and flywheel
  9. Rear main seal question, hondabond, rear main cover?
  10. fuel pump gone bad??
  11. heat + cf hood?
  12. wtb 93 prelude oem spring
  13. H22 IABs with p28
  14. half shaft??help plz
  15. need help to do my clutch kit!!
  16. rim width on a 4th gen?
  17. f23a1 headbolt torque?
  18. Cam Gears Recommendations
  19. 5th gen wheelbearing, Can I replace it?
  20. someone help me out with this please!
  21. What Shock/Spring combo do you use?
  22. Glass and door handle removal help
  23. Using MTF as Engine Oil
  24. H22/H23 pistons
  25. Failed emissions test. HELP ME PASS
  26. OBX/Samco hoses
  27. Who honed/bored your FRM liners?
  28. What Tranny
  29. idle drop/surge
  30. Limp suspension...
  31. Hood or Header
  32. help revive my car!
  33. any ludes have a triangular/3 point strut bar?
  34. 16x10 fit?? 4th gen
  35. ground point on tranny, ball joints
  36. 4th gen endlink options
  37. 4th gen recalls?
  38. Grounding Wires/Points
  39. What colour is my Lude ?
  40. which injectors
  41. back up fuse blows. engine doesn't start
  42. 5 gen head light.(driver side)
  43. h22a4 sh ecu
  44. atts system
  45. Advans SA3 for your 4 lug prelude
  46. Please Help Identify!!!!!
  47. 1998 Honda Prelude SH for sale $10,500 obo.
  48. Dinan ecu (searched)
  49. The Endless Debate: Do the bumper support beams actually do anything??
  50. Question To Who Install Their Aftermarket Flywheel (ACT)
  51. Question for those using 60mm catback exhausts...
  52. engine stalls!?
  53. what ecu do I need to run 310's?
  54. does anyone have the flat I need to run my accord r manifold?
  55. 4 to 5 bolt hub conversion
  56. Fog Lights for 5th gen
  57. JDM Fuel Line, fuel rail fitment
  58. prelude h22 swap problem
  59. ATTS
  60. anyone get water flooding when it rains?
  61. SH: Alignment: Caster
  62. how can i get power door locks in my 92 S?
  63. cylinder compression
  64. Smoke from Steering Column
  65. Will pay $5 for help: Vehicle speed sensor(VSS)
  66. Performance Chips
  67. H22a4 block weight . HELP FASSSSSSST
  68. Please Help prelude wont start
  69. where is the stamp for a or b pistons?
  70. VIS Hood
  71. Power Plugs ?
  72. Injectors
  73. Wobbly Steering Wheel
  74. custom bent piping
  75. help with choosing the right rod bearings
  76. First Car..... NEED HELP!
  77. buying exhaust in UK...help!
  78. FOUND: EGR valve-->the cause of hesitation, bogging, rough idle, idle surge and misfiring!!
  79. 89 prelude sluggish
  80. f22 throttle body on h22 head?
  81. Aftermarket engine mounts
  82. My car starts by itself....WTF!
  83. what to buy for tensioner.
  84. OaksRacing - bumper is finished
  85. skunk2 high compression valves
  86. VTEC- hard sometimes, sometimes not so hard
  87. Missing keyhole cover, where can I buy one?
  88. 1998 Honda Prelude Emissions test failed.
  89. What would be the compression if I put the h22 type S pistons on my h22?
  90. got a tranny installed....still have problems
  91. EVAP .. hows it work ..? how to remove it ..?
  92. AEM CAI 4th and 5th gen compatability
  93. Totaled my Turbo Prelude (Pics)
  94. who knows about obx cams
  95. Anti-Freeze Resevior
  96. Right rear quater pannel
  97. Turbo Muffler?
  98. Chepest youve seen Apexi WS2 Universal go for?
  99. manifold help
  100. 4th Gen Door air vents(searched already)
  101. anyone know if a jdm h22 lsd will fit in a usdm tranny
  102. Cat Question
  103. vtec head
  104. Rims size
  105. Paint code for dark metallic green 1993 prelude
  106. 91 Lude 2.2i Vtec - vrs - 99 Accord Type-R ?
  107. road race prelude for 75,000$.....wow.
  108. PGM-FI light coming on?
  109. Headlight Problems (Headlights Won't Come On!!)
  110. H22 EuroR Intake Manifold
  111. Throttle Cable Slack
  112. All the H22 dyno graphs you could ever want here!!
  113. Just Installed a new Megan Header - Heat Issue?
  114. competition clutch is installed
  115. accord axles on prelude...oops!
  116. Opinions on all motor setup
  117. ignitor
  118. ATTS issues... need HELP!
  119. How would u know if u own a SH or a Base Model Prelude?
  120. 5th gen Headlamp Assembly DIY
  121. Cleaned up the bay a bit (pics) 56k beware
  122. Do you like your Skunk2 Valve Train
  123. Girlfriend put cheap gas in my car
  124. Blue smoke under pressure
  125. could this be shift linkage problem?
  126. Turbo question. (searched recent archived info)
  127. Painting a Oem front lip
  128. My crank pulley just broke into 2 pieces! WTF?!
  129. 4th gen turbo pix
  130. Anyone using F22A accesories on H22A swap?
  131. Can I fit VTEC Rotors/Pads into Si?
  132. rough idle in the morning. please help.
  133. Car not starting!
  134. P14 ECU Question
  135. What to specs to torque head?
  136. Prelude SH suspension
  137. Exhaust fitment for 5th gen Base and SH.. are they the same??
  138. 98 early rev limit and check engine
  139. Resistor box install
  140. Accord suspension in a Gen4 prelude
  141. jd3jdm got a new header ...STAINLESS
  142. jdm h22a in a 99sh
  143. h22 in limp mode???????
  144. would a BB4 intake fit a BB6?
  145. suck to blow 1985 Prelude DX problems
  146. Which Camshaft for best Low and Midrange Power?
  147. reverse light switch problem
  148. ecu options??
  149. 4th gen seat options
  150. head rebuild now very loud rattle sound
  151. O B X oil pan opinions
  152. F22/H23 crank and rods in a 93 JDM H22 block, which F22/H23 to use???Build up help!
  153. Prelude Turbo? Was there ever an option from the dealer?
  154. knock sensor. Can it be Fixed?
  155. is my 5th gear synco going out?
  156. Installed Tanabe Ultra Medallion, now getting black smoke. suggestions?
  157. Paint problem
  158. Got bored and Dyno'ed my car.
  159. One Broke Lude
  160. Need pics of engine bay 5th gen.
  161. spoiler crack
  162. JDM H22 LSD tranny help 5th gear grinds what could it be???
  163. Best header for my setup?
  164. 89 Prelude SI HELP!!
  165. Dyno'd my prelude :)
  166. Is it possible?
  167. h22a tranny
  168. Guy cut me off, so I'm rebuilding the front-right side.
  169. 94 Prelude ignition switch part#
  170. AEM V2
  171. something wrong with my jdm motor
  172. h22a injectors topic
  173. Axle/ABS Question
  174. Problems out of F22 with H23 ECU
  175. governor on 92-96 si
  176. hoods
  177. 94 prelude h22a tranny problem.....need help
  178. H22 head shaving on h23 compression?
  179. MSD + H224= which cap?
  180. FGK header 2.5collectors
  181. 5th gear from accord swapable with a 5th gear in H22 tranny???
  182. euro r questions
  183. Strut Perch Clunk?
  184. New Lude Owner - What Model Do I Have ?
  185. how much are youse guys spending on projector housings?
  186. JDM prelude
  187. gram lights question
  188. h22a idles at 1500rpm
  189. RPM guage isn't accurate after 6500 rpm
  190. Timing Belt
  191. Need help with Engine Swap - Looking for local performance shop -SF. Oakland, San Jose Area
  192. Noobish cam seal question question?!?! h22a
  193. How to install a radiator
  194. Scratching, Rubbing Sound with clutch.
  195. HELP 5th gen lude rear rebar measurements
  196. Will 17x7.5 and +35 offset work?
  197. Limiting Issue???
  198. H22A
  199. headlight covers question
  200. JDM bb4 lights copies
  201. needed honda mechanic in NC with idling and any info! thanks
  202. Manual shift cable DIY
  203. exhaust
  204. Head Gasket for boost
  205. Code 61 Exhaust problem... Advice?
  206. help me out h23a3
  207. Knocking noise
  208. interior
  209. have problem with idle reving
  210. shhhh! Quiet Prelude exhaust
  211. For Sale - 17in Katana Tezza Chrome
  212. ***** QUESTION: ACCORD SPRINGS On 98 Prelude *****
  213. APEXi filter adapter
  214. ABS problem, code 11, need help!
  215. 92preludeSI ,digital thermometer&gas guage dont work
  216. My AEM air/fuel ratio gauge is fluttering too much
  217. JDM Conversion
  218. USDM Cluster To JDM Cluster Conversion Write-Up
  219. my ECU
  220. H22 in EG hesitation question
  221. Competition Clutches & Timing Belt
  222. Block guards + sleeving
  223. aftermarket mini radiators, what are my choices for a 5th gen..
  224. F20b Intake Manifold
  225. a question for $2,000
  226. CEL codes? for an JDM h22 in an EG. thinking of buying
  227. Exhasut spitting liquid
  228. Cleaning EGR Valve/Ports but......
  229. which jdm prelude came with the m2b4?
  230. ABS Removal! yay!
  231. DEQ...Air Injection System Problem
  232. Drove the car for the first time in 3 mth. PROBLEMS!
  233. Help Needed! Looking for 5th Gen sun visor pics!
  234. Code 14
  235. what kind of oil do i use???
  236. stock clutch power limits,
  237. 4th gen cig lighter problem (searched)
  238. loose timing belt -searched
  239. Dynoed h22a1 AEM EMS and minimal mods
  240. 95 low-end problems
  241. Help... ECU DIAGRAM...
  242. heater = buzzing sound?
  243. need some direction (f20b mods)
  244. 1986 Prelude-Upgrade
  245. prelude sway bars
  246. jdm h22a, how to tell exactly what year and what dizzy cap do i use???
  247. External to Internal coil OBDII
  248. installing blue top 450cc injectors in a 5th gen lude
  249. eg h22 sedan- boost or itb- input, not preference
  250. What would be better to build an h22 or h23vtec?
