Do any of you have problem with freezing door?
Old Oct 20, 2003 | 03:49 AM
TRN's Avatar
TRN
Default Do any of you have problem with freezing door?
I seem to have a problem with my drivers side door. When ever the temperature drops to around 30 or so like it did this morning the door freezes.
Seems the the actual mechanism in side is what causes the problem.
De-icers don't work at all. Has anyone had this problem and found a way around it?
Getting in and exiting through the passenger door really is a hassle.
Old Oct 20, 2003 | 04:42 AM
rjr162's Avatar
Default Re: Do any of you have problem with freezing door? (TRN)
the only thing I can think of is take your interior door panel off and pack all the peices on the inside with greese to help keep any moisture off
Old Oct 20, 2003 | 04:53 AM
Jagan'92's Avatar
Also some buddies of mine in WVA spray WD40 with the little red hose into the key mechanism (keyhole) in the winter, and put some vaseline along the rubber seals. Both of these repel moisture too.
Dan110024
Jan 5, 2012 07:31 AM
rubber
Honda Civic (2006 - 2015)
Sep 21, 2007 09:34 PM
01PYTypeR#1140
Apr 29, 2002 03:36 PM
synester302
Apr 7, 2002 06:50 PM
