h22a4 problem
Old Feb 7, 2018 | 08:15 PM
Tic55's Avatar
Default h22a4 problem
i have a h22a4 boosted. t3/t04e turbo, .60mm, hondata s300, stock everything else. when driving, not racing or running hard just normally driving it starts just fine and runs on a cold start just fine but as soon as it warms up my afr goes from low 13s to high 15-16 and it losses all power over all. its just seems like a semi is tied to back just holding its breaks. its very sluggish untill 2500 rpms exactly and only sometimes, does it pick up in power and act normal but it still doens't have full power. It also doenst go past 7k after 1st gear, first gear will go to 8k ( i havent changed the rev limiter, never pass 8k ) but 2nd and up wont go past 7k. i have checked my tune and i cant find anything wrong with it. ive got multiple ones for racing, and cruising, and for winter, ive ran at the track on my race tune just a few months ago and it ran just fine but even when i apply that tune it deosnt change how it runs.. i have brand new, ngk plugs bkr7e gaped 28, new ngk plug and wires, new distributor, new fuel filter. nothing changes it at all. anyone have ideas on what it could be?
Old Feb 9, 2018 | 11:26 PM
SKO's Avatar
SKO
Default Re: h22a4 problem
You're probably running too much boost for the stock fuel system.
Old Feb 11, 2018 | 06:06 PM
Tic55's Avatar
but i have been running this set up for 2 years. i understand things go bad but it runs just fine on a cold start and then when it warms up it acts up. that doesnt make sense. i have hondata s300 i watch my injector duty cycle and it doesnt go past 90 on percent on WOT and when it does i adjust it because i know that its to much. 10 psi is about all stock 290cc injectors can take. and a stock map sensor wont read more then 11.5 psi. i truly just want this thing running good again.
spitfiremk2497
Oct 3, 2008 10:56 AM
VSBB6
Feb 10, 2006 09:25 AM
CleanLikeJdm
May 23, 2005 08:03 AM
Speedz
Sep 10, 2002 06:06 PM
boomslang
Jun 22, 2001 10:37 AM
