98 Prelude turbo installation question
Hi
I am trying to install a turbo but it hits the engine mount bracket. Can i cut from the bracket to gain the needed clearance? I know that i have to replace the radiator with smaller one but any ideas on the bracket? I am attaching a photo.
Re: 98 Prelude turbo installation question
just run better mounts and you dont need the front mount at all. I use hasports, no front mount, and have absolutely no engine movement at all. certain manifolds put the turbo/mani/wg dump in a way that you just cant use a front mount. I run an ESP traction bar and couldnt get their front torque mount in there either. at the end of the day, if you have stiff mounts, it wont be a problem. my setup:
If youre looking into the ESP traction bar and front mount, make sure you can get that torque mount in there because i could not. Its hard to tell by your pic how low your compressor cover is sitting. If its right in the way, you may not be able to get it in there either. I only run the bar itself to make room for my downpipe and wastegate dump.
This post made me question it and I went outside to check haha. I actually do have innovative mounts...got mixed up between the prelude and my civic. The innovative mounts are very nice, ive had them in the car for 8 years with no issues at all. be aware that stiff mounts will send vibration into the car though. Doesnt really bother me.
BryanPendleton
03-22-2006 07:57 AM
97civicdx
02-09-2005 12:32 PM
0554
10
03-05-2003 10:29 PM
