Distributor Compatibility
Old Oct 12, 2017 | 03:24 PM
JDMJUMA's Avatar
Default Distributor Compatibility
Hey Guys
Need some help
I have a 94 JDM Prelude Si (distributor has an internal ignition coil)
I also have a 96 Prelude SRV (external ignition coil) _=>so that doesnt help me
BUT
from my understanding the Accords with the F22a - or w/e the engine is because some came with the internal set up and others with an external set up.
Would -for example a 92 Accord distributor that has an internal ignition coil match well/be compatible with my JDM 94 prelude?
Would I have an outstanding issues if the parts looked correct and i wanted to replace the part with an accords distributor?
ANY and All help would be greatly appreciated!
thannks guys!
Old Oct 12, 2017 | 03:29 PM
holmesnmanny's Avatar
Default Re: Distributor Compatibility
they got "external coil to internal coil conversion" how-to's in the faqs sticky at the top of this subforum
Old Oct 12, 2017 | 04:58 PM
JDMJUMA's Avatar
And if I wanted to bypass that process, any knowledge as to weather the 2 distributors would be the same?
Old Oct 13, 2017 | 08:48 PM
the conversion is the bypass
you just need a distributor that fits your existing harness, the td-61u distributor for preludes is for external coil setups while the td-60u distributor is for internal coil setups
Old Oct 13, 2017 | 09:07 PM
JDMJUMA's Avatar
Thank you very much -that information is a nice reassurance
TD-60u- I'm on the right track -perfect!
Kind regards- & much thanks.
Old Oct 14, 2017 | 02:38 PM
keep in mind that the 90-91 accords use the same td-60u internal coil distributor as well so if you wanted to save money you can pull one from a 90-91 accord at the junkyard
Old Oct 14, 2017 | 09:22 PM
JDMJUMA's Avatar
Thank you for this information
I looked it up and the pics do seem to match (internal Ignition)
-But the part/type Distributor shows TD31u and TD 34u as the Distributor type/ replacement part (and my JDM does show td60)
SO I'm just curious- and I imagine so -but that they would differ and not be compatible -possibly with the Main end of the distributor (teeth/camshaft side -not cap side)
Any thoughts?
Again your insight and time and help is much appreciated!
Kind regards
Old Oct 15, 2017 | 12:27 AM
Any thoughts?
Kind regards
td-31u is the usdm equivalent of the td-61u jdm internal coil distributor for the 90-91 honda accords I previously mentioned.
Sprayteg
Apr 14, 2020 09:20 AM
gdrew888
Feb 26, 2013 08:59 PM
b16hatche
Dec 14, 2005 07:31 PM
3gLudeH22A
Mar 3, 2002 05:37 AM
