Rebuild my 2000sh motor or swap in a jdm version ??
Old 11-20-2017, 10:34 AM
wantboost1's Avatar
Default Rebuild my 2000sh motor or swap in a jdm version ??
My friends motor has been burning alot of oil . Mechanic said 1or 2 pistons are damaged .... should he rebuild current motor or swap with the jdm one ?
what's needed for the jdm swap ?
Old 11-20-2017, 08:31 PM
TimiK's Avatar
Default Re: Rebuild my 2000sh motor or swap in a jdm version ??
swap engine should be rebuilded as well
and remember that you need Type S engine to match SH transmission - otherwise you need to get JDM engine with transmission
Old 11-21-2017, 06:31 PM
emeralude's Avatar
I'd just rebuild the motor in it. I've read on here somewhere about the FRM sleeves not needing boring, just a hone, but you should probably research it yourself and make sure that the shop can do it.. If you do get a JDM replacement, make sure its for an ATTS equipped prelude. The block is different to make room for the ATTS unit.
Old 11-23-2017, 02:05 PM
H22Honda98's Avatar
No need to go through the hassle of rebuilding and hoping it's done correctly when theres still **** tons of lowish mileage jdm engines available for less than $900. Not to mention that it takes someone who actually knows how to work with FRM sleeves to do anything with the cylinders.
Old 11-23-2017, 08:35 PM
TimiK's Avatar
still you need to new seals, gaskets, clutch, timing stuff etc if you get the jdm engine
Old 11-24-2017, 03:12 PM
Accordian47's Avatar
Keep it original, espically if it's the #'s matching motor for the car. JDM engine swap wouldn't be worth the $ for a small gain in hp and like others have said, it's best to rebuild or at least freshen alot of parts on a jdm engine before putting that in. For the $, i'd just make the original motor as rebuilt and fresh as possible.
Spiffious
10
07-08-2004 08:55 PM
redsled00
09-30-2003 05:11 AM
RJH6
12-02-2002 04:53 PM
threatcon13
12-17-2001 03:38 PM
Quick Reply: Rebuild my 2000sh motor or swap in a jdm version ??
