Shifter problem, any help.?
Old May 7, 2018 | 09:40 PM
Tic55's Avatar
Default Shifter problem, any help.?
So at the track, my car popped out of first gear and so I smacked it back and it cracked the ball at the bottom of the shaft in half... The pivot point for the shifter.. anyone know how to fix this.? Or replace it.? Or upgrade it.?
Old May 8, 2018 | 07:11 AM
snobordboy's Avatar
Moderator
Default Re: Shifter problem, any help.?
I would just replace the whole assembly, just to ensure nothing else was damaged, if you hammered it that hard. A junkyard assembly should be super cheap.
Old May 8, 2018 | 07:14 AM
Tic55's Avatar
Sounds good to me, Will probably do that. Thanks for the suggestion!
Old Aug 30, 2018 | 07:07 AM
Tic55's Avatar
bringing back in case anyone finds this useful i did replace the whole shifter assembly and it didnt do anything, a few days ago was working on some things and the cable actually broke from the shifter. where it connects to the actual shifter rod, that piece of the cable actually came out the wires inside completely snapped. had to replace the cable.
Mishako129
Sep 6, 2012 03:14 PM
corsport
Performance
10
Sep 14, 2010 09:48 AM
regder
Jul 1, 2005 12:32 PM
Arch-Angel
Apr 13, 2005 01:32 PM
Teal95Coupe
Dec 16, 2002 08:40 AM
