Honda prelude is it rare to have a h22A4 in the 97
Re: Honda prelude is it rare to have a h22A4 in the 97
Not sure where you are located Tcubs, but in the US... ALL '97-01 Preludes come with a H22A4, so it isn't rare at all. The H22A1 came in the '93-96 Prelude VTEC. I think that they were both rated at 195 HP... the A4 has a floating pin style connecting rod and the A1 has a pressed pin style connecting rod. Also, the A1 closed deck block is stronger than the A4 open deck block... so if you want to install rods and Mahle Gold series pistons, the A1 block can safely make more power.
H22A1 obd1
hp 190@6800
nm 214@5500
comp 10.0:1
97-98 H22A4 obd2
Hp 195@7000
Nm 212@5250
Comp 10.6:1
99-01 H22A4 obd2
Hp 200@7000
Nm 212@5250
Comp 10.6:1
Obd2 h22s have 55mm mains and obd1 h22s 50mm
hp 190@6800
nm 214@5500
comp 10.0:1
97-98 H22A4 obd2
Hp 195@7000
Nm 212@5250
Comp 10.6:1
99-01 H22A4 obd2
Hp 200@7000
Nm 212@5250
Comp 10.6:1
Ek9.civic
11-19-2011 06:45 AM
