Brake fluid leak
Brake fluid leak
Hello, i own a 93' Prelude Si and the brake fluid is leaking. Traveled about 400km and all fine, but later it completly lost the brakes. Checked the reservatory today and its empty, and the fluid is leaking under the car (under the engine area, not the brakes). Any clues? Could a messy master cylinder do that?
Re: Brake fluid leak
Get someone in the driver seat smashing the brakes and look for the leak. If you lost all your fluid it'll show itself, lol. Otherwise I would look at the front of the brake booster see if there is evidence of brake fluid. Could be the front seal on the master leaking into the booster.
park the car, start it, pump the brakes and look where the fluid is leaking on the ground then go look in that area. Brake lines run under the car to the rear wheels
