4w
Old Sep 20, 2017 | 09:40 AM
debby4wav's Avatar
Default 4w
What does 4W mean on a vehicle?
Old Sep 20, 2017 | 08:35 PM
TimiK's Avatar
10 Year Member
Default Re: 4w
you mean 4ws?
thats 4 Wheel Steering - and thats basicly means "stay away from that"
Old Sep 21, 2017 | 12:19 AM
motoxxxman's Avatar
Default Re: 4w
Originally Posted by TimiK
you mean 4ws?
you obviously have no clue what you're talking about.
but yes, 4ws means four wheel steering. and if it's a 3g prelude (88-91) it's 100% mechanical, and is extremely awesome. most normal preludes that are 2ws get swapped to 4ws if the owners can afford the parts
Old Sep 21, 2017 | 01:28 AM
TimiK's Avatar
10 Year Member
Default Re: 4w
I do - youll get only more troubles with it
no one does that because it only bring troubles so usually people just want to delete 4ws
Old Sep 22, 2017 | 04:59 PM
motoxxxman's Avatar
Default Re: 4w
name one single problem you'll get with a 4ws 3g prelude.
name one single person who has ever swapped the 4ws out for a 2ws setup [excluding track-only cars].
I bet you can't answer either. unless you're referring to the super rare 92 and newer 4ws preludes
Old Sep 22, 2017 | 09:23 PM
TimiK's Avatar
10 Year Member
Default Re: 4w
almost every 4 and 5 gen?
Old Sep 23, 2017 | 10:07 PM
motoxxxman's Avatar
Default Re: 4w
I did say above "unless you're referring to the super rare 92 and newer 4ws cars", which you snipped out of the quote. and they really are ridiculously rare. 3g preludes on the other hand are a totally different ballgame, as I mentioned
Old Oct 4, 2017 | 07:50 PM
REDLUDE4WS's Avatar
You must know a **** ton of people! Almost EVERY 4th and 5th Gen with 4ws swap to 2ws. How can you say that with any sort of sense at all? If you have ever driven in, owned, or repaired the 4ws system you would realize it’s no different than diagnosing any subsystem. Anyone who has 4ws would never want to remove it, unless they had an issue, and have no idea how to diagnose electronics.
Having vtec is more problematic than non vtec. Attempting to make more power than stock is problematic. Having people like you spit a bunch of regurgitated internet jargon about anything they don’t have or understand is problematic as well. Nonsense.
My 93 4ws has over 450,000kms on the chassis. Only issue I’ve ever run into regarding inoperative 4ws was both rear speed sensors cracking the magnetic pick up due to rust. Which is an ABS component. Some have had issues with their 4ws ecu and required soldering. Which is an hour job at best. Some say it’s heavier. 80lbs is actually a moot point. That’s like 1/3 your girls weight.
Really all I wanted to say was you’re completely ******* wrong.
Trojan Man
Apr 3, 2009 05:17 AM
wxy117
Aug 31, 2007 04:57 PM
