Compression test?
Old Dec 26, 2017 | 01:02 PM
underknown's Avatar
Default Compression test?
I have a 98 base model prelude H22a4 I done a quick (dry) compression test and here it sits
cyl1 205
cyl2 185
cyl3 220
cyl4 215
then redone it again dry
cyl1 200
cyl2 190
cyl3 215
cyl4 205
shpuld I rebuild? Valves in spec on lash
Old Dec 27, 2017 | 10:13 AM
LiteraCola's Avatar
Corvette Forum Member
Default Re: Compression test?
To be honest, a compression test doesn't really tell you all that much. Do a leakdown test. It will better allow you to diagnose your issue! A leakdown tester is a simple (and cheap) DIY.
Old Dec 27, 2017 | 01:20 PM
holmesnmanny's Avatar
your numbers look around spec, how does it run ?
crazyhouse2011
Mar 18, 2013 07:50 PM
F120man
Oct 20, 2002 03:30 PM
Slick GS-R
Apr 23, 2002 02:15 PM
