Alarm install - Where is passenger side door harness located on 93 vtec?
Check the manual and googled. Found the location in the manual but the brownish connectors are nowhere to be seen.
Re: Alarm install - Where is passenger side door harness located on 93 vtec?
Found them. I should have just pulled the harness out where it enters the body but I had a brain cramp because the manual said they were somewhere else. On my 93 vtec they are located behind the flap where the sunroof drain pops out. There are 2 covers or flaps. One lower one you can see clearly. I checked in there but could not see any harness. The upper flap or cover not clearly seen is the money pit. Both connectors are wrapped in foam and tape so I assume this was like this from the factory. The green arrow points to the flap.
stackz
09-05-2007 09:06 AM
South Bay Surfer
11-19-2002 05:41 AM
