97 prelude cant shift problems
Old Nov 26, 2018 | 08:26 PM
Kirt Thelander's Avatar
Default 97 prelude cant shift problems
just bought a 97 prelude...
for the first time after 2 months of owning a decently hard driving mostly in hard rain in Seattle....
my car will not shift...
it has always had a hard time shifting into 5th unless i double shift but i have googled that and thought it was a bad fork that causes that.
but for the first time tonight i literally could not shift into any gears with any amount of strength unless i turn the car off and then rode first all the way home.
between letting the car cool and or pumping the clutch fixed the problem and now it shifts just fine again.
what could be the long term problem?
i checked my master fluid and it is fine.
my clutch is hydraulic and has its own master cylinder.
it does have a steel braided line but it leaks between the steel braid and the vinyl/plastic outer covering.
could this be the problem?
any suggestions would help thank you
Old Nov 26, 2018 | 08:39 PM
TimiK's Avatar
10 Year Member
Default Re: 97 prelude cant shift problems
5th gen is known of failing 5th gear synchros
Old Nov 26, 2018 | 09:53 PM
yeah i know 5th gear is a problem... but would that cause ALL gears to have hard time going into gear..?
Old Nov 27, 2018 | 04:17 AM
TimiK's Avatar
10 Year Member
depends is it damaged and gone into pieces
when your clutch have changed? and is it instelled properly?
transmission fluids changed last time when?
teg969
May 4, 2008 04:16 PM
superking
Sep 9, 2005 07:03 PM
Wiseguy619
Nov 26, 2003 03:39 PM
mike2016
May 20, 2001 03:03 AM
