Dash cluster issue
Old Oct 2, 2019 | 08:30 AM
Chris Barton's Avatar
Default Dash cluster issue
I am new to the site and have a problem. I bought a 1992 Prelude So and the dash cluster is not working. The only thing that shows is the battery indicator. The turn signals don't work and no back up lights. It is a manual. I have checked all The fuses inn the lower left kick panel and under the hood. Any body got any ideas on where to start looking next?
Old Oct 11, 2019 | 03:59 PM
atariguy's Avatar
Default Re: Dash cluster issue
When you say the dash cluster, are you referring to the digital information cluster (DIC) in the center of the dash that should show fuel, coolant temp and the system warning lamps, or are you referring to the speedomoter/tachometer that also includes the turn signals, high beam, and SRS and 4WS warning lamps if you have those features?
If is it the DIC, and you have checked all the fuses, there are two likely possibilities.
One - the DIC has become loose from the connectors. There are from memory 3 connectors to the DIC (one of which is the clock adjust controls) which might have become loose - although that's unlikely.
Two - the capacitors in the DIC have swelled and possibly leaked. If you remove and dissassemble the DIC you may see capacitors with raised or split tops. If you are luckly the circuit board has not been damaged and you can just solder in new ones. If the circuit board is damaged you may have to repair that with new traces, or replace it completely.
Old Oct 11, 2019 | 05:10 PM
Two - the capacitors in the DIC have swelled and possibly leaked. If you remove and dissassemble the DIC you may see capacitors with raised or split tops. If you are luckly the circuit board has not been damaged and you can just solder in new ones. If the circuit board is damaged you may have toit is both the fact repair that with new traces, or replace it completely.
it is both the apwwd/tact and the dic. I am going to pull every thing out and looking at the connectors. All the fuse are good, under tbe dash and I set tbe hood. Thanks for the help
ekjdm89
Oct 2, 2011 07:16 AM
jdm_vtec
Dec 2, 2007 12:35 PM
nolen
May 26, 2007 11:44 AM
st0nedstoopid
Jan 20, 2004 05:26 PM
emmo
Feb 24, 2003 07:27 AM
