Intercooler piping angle
Old Oct 2, 2018 | 08:00 PM
PreludeJunkie91's Avatar
Default Intercooler piping angle
Just looking to see what angle between 45 or 70 to get a straight shot from TB to the original intake hole on a 5th gen. What other angles did you guys use for a tight fitment on passenger side piping.
Old Oct 3, 2018 | 01:21 AM
hondamyheart's Avatar
Default Re: Intercooler piping angle
I used 45 angle. I just cut the pipe to shorten it then straight line then 90 angle to the hole. I welded all pipes, couplers on the intercooler only.
Old Oct 3, 2018 | 05:01 PM
Thanks man, not a pita to get the whole pipe off when welded all the way through?
Old Oct 3, 2018 | 11:22 PM
I have removed it twice because i made a custom wiring. I just undo the clamps from the TB and intercooler, pull the piping from both sides and lift it from the TB side then slowly get it off the intake hole. took less than 5 minutes. Below is old photo while i am still working on the turbo setup, I dont have a clear photo in my mobile.
forcedaccord95
Welding / Fabrication
May 13, 2005 08:19 PM
liam821
Jun 14, 2004 03:24 PM
NeXtLeVeL_TyPe_R
Apr 17, 2002 09:38 PM
