h22a4 compression
Old Sep 21, 2018 | 10:08 AM
Riskorn's Avatar
Default h22a4 compression
2001 prelude se wih an h22a4 showing apparently 120-130 psi across all cylinders, what should the compression be across all pots? 180-220?
Old Sep 21, 2018 | 11:12 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: h22a4 compression
Yup.
Old Sep 22, 2018 | 01:38 AM
Aradin's Avatar
Premium Member
180-220 assuming the test is done correctly with the engine warm and throttle wide open. If the engine is cold and/or throttle closed then the numbers will be lower.
young geezer
20
May 6, 2010 08:22 AM
umair
Dec 7, 2009 10:37 AM
MrMug3n
Jul 14, 2008 04:02 AM
dirtySOHC's
27
Jun 11, 2002 05:38 PM
jaredfmn
May 30, 2002 11:33 AM
