'98 Prelude Check Engine Codes
Old Sep 24, 2019 | 08:34 AM
ashtapia's Avatar
Icon4 '98 Prelude Check Engine Codes
I was recently driving on the freeway when my check engine through the codes: P0300, P0301, P0303 and P1399. I know these all indicate a misfire on Cylinders 1 and 3; however, the car wasn't failing or bogging out, only losing power. It has recently start to bog out only when idling. About two/three weeks ago, I changed out the spark plugs and the wires. Anyone have any suggestions on what to check/look out for?
Old Sep 25, 2019 | 06:06 AM
TimiK's Avatar
10 Year Member
Default Re: '98 Prelude Check Engine Codes
Always change distributor cap and rotor also when wires and plugs need changing
Old Sep 26, 2019 | 04:31 PM
HondaPrelude00S's Avatar
that code right there more than likely is going to be your EGR valve ports plugged up , if you have h22a4-h22a1 , those usually plug up after some time with a carbon you have to a usually tap and remove the plugs on top of it and clean them out and replug them with oem plugs.
Search the p1399 code....
alfiler
Feb 16, 2009 11:55 PM
xxacelinkxx
Oct 3, 2008 12:09 PM
spoon063
Jul 29, 2003 11:09 AM
