5th gen ignition problems
Old Jul 6, 2019 | 11:46 AM
Jigglz's Avatar
Default 5th gen ignition problems
So i bought a 97 prelude and dude said he replaced the whole ignition lock assembley but the car still wouldnt start. So i bought a battery and new ignition switch and tried it but it didnt even crank or anything but the green key light is on the dash.
Old Jul 6, 2019 | 02:12 PM
Aradin's Avatar
Premium Member
Default Re: 5th gen ignition problems
That "green key light" is signaling that the immobilizer is active which is likely what is preventing the car from starting.
Old Jul 10, 2019 | 12:39 PM
Jigglz's Avatar
The new ignition only came with one key and the locksmith said he couldnt do anything and i just got it back from honda and they said they dont wanna mess with it. Im stumped at this point and im not sure what to do.
Old Jul 10, 2019 | 01:10 PM
Aradin's Avatar
Premium Member
It's possible to bypass the immobilizer.
https://www.hamotorsports.com/prelud...ll-bypass.html
Old Jul 10, 2019 | 01:19 PM
Jigglz's Avatar
Ive been looking at that for a while now but does it work? And what do i just cut the grey and blue and twist them together or..?
Old Jul 10, 2019 | 04:38 PM
Aradin's Avatar
Premium Member
Well you want a more secure connection than just twisting them together. I would recommend soldering or at least a crimp connector. To test if it works for you, you could just de-pin the two wires and tape or otherwise hold them together temporarily.
Old Jul 11, 2019 | 09:22 PM
TimiK's Avatar
10 Year Member
chipped ecu will bypass the immobilizer
Old Jul 11, 2019 | 10:27 PM
Aradin's Avatar
Premium Member
That's the equivalent of killing a mouse with a cannon. This guy clearly just bought the car, doesn't know much and just wants to get it going. Chipped ECU will open the door to a lot more issues.
Old Sep 18, 2019 | 05:00 AM
EuwingKelly's Avatar
Can locksmith replace an immobilizer or not ?
Dekorum
10
Sep 17, 2018 05:29 AM
Nasty J
Dec 24, 2013 05:06 PM
fubuallstar
Jul 24, 2008 11:57 PM
APEXI Si
Feb 8, 2007 05:55 PM
GhostBB6
Jan 13, 2006 04:47 AM
