Weird Sound from Engine?
Old Feb 13, 2019 | 02:18 AM
preludesilver's Avatar
Default Weird Sound from Engine?
I have a 2001 Prelude. I think my motor is making a weird sound, but I can't describe it. Please see the clip in the attachment. I recently replaced the water pump since the car was idling between 1,000 to 2,000 rpm. That seems to fix the idling problem, but now the weird sound is a bit louder than before. The shop that I took it to said the timing belt needs to be replaced, but I replaced it at around 120,000 miles. The car has around 160,000 miles now. Does anyone have any ideas what's causing this sound or am I just being paranoid?
File Type: avi
Old Feb 13, 2019 | 03:17 AM
TimiK's Avatar
Default Re: Weird Sound from Engine?
Water pump should be always newd when youre doing timing belt job. And also seals, gaskets (vc, cams etc) + other belts
Did you replaced tensioners as well when you did timing belt job? Did you use oem belt and did you new other belts? What year was that?
Old Feb 13, 2019 | 05:21 AM
Yeah, I replaced the t-belt tensioner pulley roller and brackets when I got the water pump replaced recently. I did the timing belt around four years ago.
clys
Feb 7, 2011 08:32 PM
B18CYAAA
Aug 3, 2009 07:13 PM
SleeperGSR
May 29, 2008 03:27 PM
B18C1NMotion
Nov 20, 2007 11:27 AM
civic_tuned
23
Jul 26, 2005 08:42 AM
