Fuel setup
Old Jan 25, 2019 | 07:13 PM
PreludeJunkie91's Avatar
Default Fuel setup
Need help on my fuel setup, which lines run where and upgrading feed and return to AN. Going in tank fuel pump to in line filter to driver side -8 feed on the fuel rail (right side) to -6 passenger side for my return to aem fuel regulator and back to tank. Does this work?
Fuel rail [return (-6)] -======- [(-8) feed] straight through there are no top ports on this rail only for pressures gauge which will be blocked off to have gauge on aem regulator located on firewall.
Old Jan 28, 2019 | 08:22 AM
snobordboy's Avatar
Moderator
Default Re: Fuel setup
You might be able to save some hassle, and use the stock feed pipe, as your return line. How large of a pump setup, what fuel, and how much power are you looking to support?
Old Jan 28, 2019 | 10:59 AM
I have a walbro 450 high pressure in tank, gonna bounce from 100 octane to e85 every so often. Gonna go for atleast 500hp for now limited by the trans gonna go dog box later so rather upgrade everything now. I already have AN fittings and hoses so might as well do it now. Just need to find out which way to route this.
Old Jan 30, 2019 | 10:29 AM
Bump
Old Feb 1, 2019 | 02:44 AM
Bumpy
Old Feb 1, 2019 | 09:25 AM
snobordboy's Avatar
Moderator
Seriously?
There are not many people who have upgraded the fuel system on a Prelude to that extent. The ones who have, have just come up with it as they went, or added a fuel cell in back or in the engine bay. On top of that, they have all moved on from this chassis to other cars, so getting any "information" is going to be basically impossible. Throw the car on a lift, and see where you have space.
What I suggested, by using the stock feed line as a return, has supported 640+ on E85, but it used an Aeromotive pump under the tank, feeding a line run up the drivers side...and it was 12+ years ago.
Old Feb 1, 2019 | 10:22 AM
I enjoy the car and I don't get rid of my vehicles, everything under the hood is brand new and I like everything looking the part, I will be going past 640 down the line as well 500 is just starting point. All I'm asking is if that flow route I explained earlier will work. Check out the work so far if you got the time and if this allowed on here, if not I'll remove. Instagram Bb6_fiend.
​​​​​​Thanks man
Old Feb 1, 2019 | 02:32 PM
snobordboy's Avatar
Moderator
Ok, I gotcha, the theory of the setup is correct, and your line size should be appropriate.
Unfortunately IG links aren't working on here, and I don't use it personally.
Old Feb 1, 2019 | 08:13 PM
Appreciate it man.
B_Swapped93
11
Apr 26, 2017 03:27 PM
building boost
Aug 21, 2008 07:31 PM
LBR92DA-T
Oct 25, 2003 02:21 AM
