Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Reload this Page >
2000 Honda prelude H22A4 with series A trans starting issues
Old 03-28-2019, 04:43 PM
FIREFLY2's Avatar
Default 2000 Honda prelude H22A4 with series A trans starting issues
Sometimes when I go to start my car it sounds like it's going to start like normal then kinda stalls unless I add gas even when I hold the clutch or in neutral
Last edited by FIREFLY2; 03-28-2019 at 04:43 PM. Reason: I forgot to add something in the title
FIREFLY2 is offline
Old 03-28-2019, 09:07 PM
Default Re: 2000 Honda prelude H22A4 with series A trans starting issues
maintenance history?
TimiK is offline
Old 03-29-2019, 03:44 AM
FIREFLY2's Avatar
I bought it used with 175 k miles I cannot confirm anything that is my problem. I can say what he told me "changed oil, coolent, and replaced all the hose" but a little after I got a small coolent leak which I replaced the same day and removed air from the system. I don't know if he has replace spark plugs and it's happens on starts when I drive around or after starting and pressing the glass pedal everything is good.
FIREFLY2 is offline
Old 03-29-2019, 03:45 AM
FIREFLY2's Avatar
If anything when I get home I can take a video on how it sounds
FIREFLY2 is offline
Old 03-29-2019, 08:55 AM
So start doing maintenance: new fuel and air filters, spark plugs, wires, distributor cap and rotor, clean fitv, iacv, egr, injectors, adjust valves, check timing...
TimiK is offline
Old 03-29-2019, 08:58 AM
FIREFLY2's Avatar
Lol wow nice how many of those things u suppose a new bee like me can do to cut down on cost
FIREFLY2 is offline
Old 03-29-2019, 09:44 AM
Also if timing belts last change is unknown you should do that as well
TimiK is offline
Old 03-29-2019, 11:21 AM
FIREFLY2's Avatar
Should I use stock factory stuff or try for "premium" or just go performance parts. Because with time over the years I will be adding performance parts. Things like valve camshaft and so on.
FIREFLY2 is offline
Old 03-29-2019, 11:32 AM
Depends about which part youre talking about
Cant go wrong with oem but for example Gates have ok timing belt/water pump kit and Ngk and msd ignition parts
You should forget performance parts - you only lose money with those things. Wrong car for that
TimiK is offline
Old 03-29-2019, 11:34 AM
FIREFLY2's Avatar
Honestly I'm out here asking because I know very little and asking people for opinions to make sure my prelude last for alot longer because it's already a car that didn't sale much when it was new so I know it has that exclusivity.
FIREFLY2 is offline
  • Ask a Question
Question Title:
Description:
