What replacement for JDM OBD1 H22A internal coil TD-60U dizzy?
Old 04-22-2019, 12:34 PM
toki's Avatar
Default What replacement for JDM OBD1 H22A internal coil TD-60U dizzy?
My dizzy has been leaking oil from the internal seal for quite sometime and Im starting to have issues. I replaced the outer seal and tried to get to the inner seal but the phillips head screw just want to strip no matter what I do. Im starting to get an intermittent code 8, TDC sensor. I want to just replace it but an OEM from Japan costs $1000. I dont want to buy some Chinese crap either. I have plans for boost in the near futute so I need a decent dizzy obviously.
Anybody got any brands they recommend for a TD-60U ?
Old 04-22-2019, 09:15 PM
JRCivic1's Avatar
Default Re: What replacement for JDM OBD1 H22A internal coil TD-60U dizzy?
You need an OEM one... either find a clean one from a JDM inporter and take a shot at it working for some time OR pony up the coin and get that high dollar new one.
Old 04-23-2019, 05:41 AM
ross2004's Avatar
Why not go to an external coil TD-61U?
Old 04-23-2019, 08:26 PM
JRCivic1's Avatar
I would... but that is NOT the question that you asked. Removing the coil from inside of the distributor housing pulls a ton of heat out... extending the life of all parts inside by reducing the heat exposure.
bauergold
06-08-2017 07:11 AM
94CDMeg
01-13-2009 01:40 PM
Quick Reply: What replacement for JDM OBD1 H22A internal coil TD-60U dizzy?
