Help with my 96 prelude
Re: Help with my 96 prelude
It's an h23a dohc, vtech, I've put 2 resistor boxes on it tried 2 different ecu, I have power to the injectors, but no pulse. I've put a noid light on the plugs, no pulse. It's an obd1, have new inline fuel pump, plenty of pressure to fuel rail. It has a distributor with external coil...
92-96 prelude OBD1 not OBD2. Make sure you have the correct injectors for your engine/ecu first. Check the fuses, pull the ecu codes, check the thermostat ground.
illicon2003
04-01-2004 07:49 PM
