UDSM H22A4 to JDMH22A
Old 03-05-2019, 04:56 PM
Jordan M Keller's Avatar
Default UDSM H22A4 to JDMH22A
I have a 1998 honda prelude 5 speed type sh. The original motor blew due to (I believe a failed oil pump) it was a usdm h22a. I bought a H22a replacement from Chicago jdm. Later I found out it was a jdmH22a. This particular new motor was also newer than 98 and out of an auto. I used my original wire harness with the motor. (One with new motor was cut to pieces) I used my vtec valve (I believe that's the name, correct me if I'm wrong) from my old motor cause my harness has a clip to hook up there. I also took my old dizzy and external coil. I placed them on the new motor as well. (The dizzy on the new motor was internal coil and my harness wasnt compatible with it.) So now to my main issue my old motor/original harness has a spot for the crankshaft position sensor. This new motor does not have that spot to attach the connector. Now does anyone know of a way to bypass this or some type of advice? I believe this is the only thing holding me back. I have fuel up to the rail but not in the injectors and also have no spark. It has great compression and cranks, just doesnt fire. I'm hoping this little issue will fix all of it... I apologize if this is ran on and confusing. This is my first post on this group and I'm only learning lol. Thanks in advanced for any advice you might be able to give!
Last edited by Jordan M Keller; 03-05-2019 at 05:09 PM. Reason: Mistyped the title line.
Jordan M Keller is offline
Old 03-05-2019, 08:19 PM
Default Re: UDSM H22A4 to JDMH22A
which ecu youre using there?
remember that you have to rebuild the swap engine also if you want it to last.
TimiK is offline
Old 03-06-2019, 01:53 AM
I'm using the ECU that was in the car. Also, it is complete engine I'm just looking to get it up and running since it's my only vehicle as well
Old 03-06-2019, 03:43 AM
Even if its complete engine and its not rebuilded you need to do that before you can get it running - if engine stands years in warehouse and seals get dry - theyre gone and soon your engine is leaking oil from everywhere - also its smart to new timing side and clutch.
Swap engines are not direct drop in unless theyre rebuilded
also if you use USDM ecu you need to change USDM oilpump, dizzy and intake manifold to get the sensors working properly
TimiK is offline
Old 04-01-2019, 07:16 PM
Stop telling people to rebuild engines for no reason. If he or anyone wanted to do that they'd just rebuild their original.
I recommend a "refresh" just change all the seals and anything rubber. That is correct about changing the oil pump and intake etc.. basically the only thing from the jdm motor you should be using is the long block and everything should be transferred from the original engine.
OR get the rywire.com adapter harness to run the jdm oil pump and dizzy and not have to change them. I wouldn't do this because the crank sensor is more accurate at the crank and thats what the usdm ecu likes but it does work and is easier than having to change the oil pump.
OR you can wire the usdm harness to the jdm dizzy without using rywires adapter Import Intelligence - Expert Automotive Repair
Slasheshat is offline
Old 04-01-2019, 08:11 PM
stop telling people they shouldnt maintenance rebuild the engine - when swap engine sits in some dusty warehouses seals and gaskets dry and when you just swap the engine without any maintenance it willl leak from every hole and then its A LOT harder to start change stuff
also you dont know what shape is swap engines clutch and timing components, valve seals, LMAs.... so yeah YOU NEED TO DO SOME MAINTENANCE REBUILD
TimiK is offline
Old 04-01-2019, 08:28 PM
Yes if you read my post I said to change ALL seals on the engine. THIS IS DIFFERENT THAN AN ENGINE REBUILD AS YOU SUGGESTED. An engine rebuild is changing piston rings, rod and main bearings, valves and guides, and head gasket. There is no point to change LMAs, if you buy a jdm engine that is damaged and needs any of these replaced you need to get a refund.
Old 04-02-2019, 09:14 AM
You dont obviously know what I ment. One should always inspect swap engine very closely and replace parts which show wear. Thats called also rebuild.
Piston rings are one of h22s main problem so it might be good idea to change or atleast inspect em when engine is out + of course new valve seals and when youre there its smart to check lma's which usually wear little bit faster than other valvetrain components...if engine doesnt have upgraded newer open lma's already
Bottom line - theres a lot more things to do than just buy swap engine and throw it back in and thats I call "rebuild" to make sure you dont end up with problems soon after you get it back together
TimiK is offline
Old 04-02-2019, 10:13 AM
You should learn correct terminology before you go misinforming people. I see you're doing it in multiple threads.
Old 04-03-2019, 04:00 AM
You should learn expand your terminology before YOU go misinforming people - my info is no misiformation theyre just facts and I continue spearing these facts also in multiple upcoming threads.
TimiK is offline
  • Ask a Question
Question Title:
Description:
