need help
Old Mar 31, 2013 | 08:34 AM
luder23's Avatar
Icon3 need help
so i have my front struts off. i have one spring compressed but i cant get the top nut off!! i worked on it in the rain for like 2 hrs last night! is there any tricks or tips anyone can give me?
Old Mar 31, 2013 | 08:36 AM
xTyFighterx's Avatar
Default Re: need help
Impact gun
Old Mar 31, 2013 | 08:42 AM
luder23's Avatar
i dont have an air compressor.. any way to do it without an impact gun
Old Mar 31, 2013 | 11:06 AM
thirsk66's Avatar
you should have tried loosening the nut a little bit before you compressed the spring. Do you think the nut on there is stripped?
Old Mar 31, 2013 | 12:11 PM
luder23's Avatar
na its not stripped. and i lossened the compressor and it still jus spins
Old Mar 31, 2013 | 12:55 PM
Just take it to a les schwab or something they will get it off
Old Mar 31, 2013 | 01:20 PM
P. Hunter's Avatar
a 3/8" impact guns works best cause it hammers quicker/faster than a 1/2". doing it by hand is going to be near impossible. im not sure if your strut will have it but on top of the stud might be a spot for a 6mm hex to fit in. that will hold that in place as your twist the nut off.. chances are that wont work either
Old Apr 5, 2013 | 06:28 PM
luder23's Avatar
i got it i just used a pipe wrench to grab the pole. and compressed the spring around it and presto came right off
dabiddan
Oct 17, 2004 11:29 PM
clutch33
Apr 15, 2004 11:34 AM
Chip398193
18
Jul 8, 2003 04:57 AM
Chip398193
Oct 11, 2001 06:57 PM
99ls
Aug 18, 2001 10:05 PM
