Passenger tail light not lighting up when braking only?
Old 03-27-2013, 10:31 AM
caseythefalcon's Avatar
Default Passenger tail light not lighting up when braking only?
It lights up fine when I turn all of the the exterior lights on, just not when I'm braking, it also shows "brake lamp" would it be a fuse or short?
Old 03-27-2013, 11:36 AM
thirsk66's Avatar
Default Re: Passenger tail light not lighting up when braking only?
Could be either one so I would check your fuses and brake light wiring just to make sure everything's in good condition.
Old 03-30-2013, 03:14 PM
TorontoHonda's Avatar
Sounds like a bulb issue. Brake light bulbs are dual filiment. Try replacing the bulb before you dive into wiring.
Old 03-30-2013, 03:24 PM
h22god's Avatar
I had an issue with the bulb lubricant before. Had to
wipe some off and it worked fine after
racerx413
09-20-2014 02:38 AM
smurf357
07-20-2008 02:33 PM
94civicoupe
10-16-2006 06:09 PM
blaster834
11
04-26-2004 09:05 PM
david90
12-09-2003 04:13 PM
Quick Reply: Passenger tail light not lighting up when braking only?
