h22 died shifting to 3rd
I have 94 integra with h22a. I was driving down road nailed 3rd. and car died....thought I ran outa gas but put gas in and still won't start.fuel pump cutting on and getting fuel. Upfront could it b fouled plug ?
Re: h22 died shifting to 3rd
Could have, pull off the valve cover and line the crank up to tdc, see if the cams are still aligned correctly. I have had an engine set up with the manual tensioner somehow skip one cam 2-3 teeth off, and it wouldn't run to save it's life, but nothing was damaged.
Ok I went to checkcell for code and realized no light there's a screw there instead opened cell and its a kb20 chip inside. Anybody know y its there and is there another way to check codes
moderator emeritus
moderator emeritus
it takes 4 things for an engine to run. Fuel, Timing, compression and fire.
you are missing one of those.
if you have spark and your injectors are firing (spraying fuel into the chamber) then you have bad cam timing or you have no compression..or both
Gonna get timing checked again today. ...car fires but shuts back off. If I had no compression wouldnt it just keep turning and not fire? If it is compression how do I fix it? And I don't thinks I over revved I shifted round 6k car is too fast to b sitting gotta get it running again .
main fuel relay maybe? I know when mine was starting to go bad, it would start to run and then die again quickly. this would not give a CEL either i dont think.
Sure, you coulda just jumped a tooth or two too. You can verify that first before buying the compression kit.
Ok I worked on car yesterday my timing good tdc! I know its a guess but could it b ignition coil? Its getting fire to coil but its like its not getting enough fire im getting plenty of fuel almost to much...all my fuses are good . Maybe ecu has to b reset hell idk wtf it is but I know it not my timing cuz its set not fuel so wat else could it b ??????
